Souped up sleeper
Discussion in '1st Gen Tundras (2000-2006)' started by Zoxics, Nov 8, 2023.
  1. Nov 8, 2023 at 11:11 AM
    Zoxics
    Zoxics [OP] New Member
    Jack
    03 Tundra AC 4.7
    I have an 03 4.7 2WD with 103k on the dash. Id like to soup it up a bit, the mods I’m planning on are:
    Thicker Sway Bars front and back
    New suspension (perhaps lowering it)
    Big brake kit
    Wheel Spacers
    I’d like to get a noticeable power increase alongside handling improvements and I’m looking for suggestions for both that would be worth my while. Also cosmetic mods would be appreciated, just nothing that draws too much attention. thanks!
  2. Nov 8, 2023 at 11:17 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  3. Nov 8, 2023 at 11:23 AM
    Just sayin', and not trying to be a smartass, but you picked the wrong vehicle for that.
    Don't install 'hot air intake', you'll lose power.
    Don't bother with oiled filters, you'll clog the MAF.
    You can eek out a little extra power with long tube headers, other than turbocharge/supercharge, you're not going to see much for gains with that 2UZ-FE. It's designed to run a million miles, not to run races.
    I'm biased, but this thread is worth a read: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    GeezePlease, bfunke and FrenchToasty like this.
  4. Nov 8, 2023 at 11:30 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    LS swap it!
    bmf4069 and JasonC. like this.
  5. Nov 8, 2023 at 11:35 AM
    :yes:
    Now that's how you get power! And tons of bolt-on easy mods to choose from!
    And it's also how you turn your 100k-150k engine into something that needs to be rebuilt in 30k-60k miles. Been there, done that.
    bmf4069, FrenchToasty and JasonC. like this.
  6. Nov 8, 2023 at 11:56 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  7. Nov 8, 2023 at 1:46 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    some of us are here for a good time, not a long time.
  8. Nov 8, 2023 at 1:51 PM
    It's a spectrum, I'm here for a moderate amount of both.
    And I'm definitely on the spectrum, also.
  9. Nov 8, 2023 at 2:20 PM
    5.4L stroker kit if you’ve got money and want to keep the 4.7L block and look.
  10. Nov 8, 2023 at 5:20 PM
    bfunke
    bfunke Tundra Curmudgeon
    LT4 crate motor swap would be fun. Only $17K from GM.
    bmf4069 and ColoradoTJ like this.
  11. Nov 8, 2023 at 5:27 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I dont think i'd want an aluminum block or high compression on a truck (i know the titan is aluminum, but its 2wd & doesnt have a hitch. Basically a crossover.). Low rpm and cool would be the ticket. Thats my main beef with the 2uz, it wants to spin, but has 2 bolt mains & '03+ has weak rods.
    im not happy with ethanol gas, wouldnt hurt my feelies to swap in a diesel.
  12. Nov 8, 2023 at 6:42 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Lets go be real for a moment.
    Headers - $800 - $1,200
    Exhaust - $500 and up
    Suspension drop kit - $800+
    Hellwig Sways front/rear - $1,200
    Supercharger - $7,000 - $10,000
    Built forged w/ARP long block - $9,000+
    Turbo - $900 (kit only, no engine managment)
    Cams with valve springs - $2,000+
    Ring/pinion (RWD) - $1,200
    Injectors - $400
    And that's if you do your own work. Some of those parts require specialty tools. Pick your poison, and how much you want/care to spend.
    I have a dyno proven 30ft-lbs of torque at the low end and only 5hp at the top end by headers, exhaust, injectors, and having all maintenance items new. Spent maybe $2,500. Granted, I designed my system to make low-end torque.
    Want to feel quick? Re-gear your rear end to 4.30:1 or 4.56:1 with stock sized tires and get some headers. You'll zip around town and have some nice passing power on the highway. Trust me, it will feel plenty quick enough.
    Want to race Mustangs and Corvettes? Spend $20,000+ on a built bottom end with a supercharger at 12+ psi. Your stock rods are only good for under 6psi.
    As stated by other folks in here the 2UZFE is built for the marathon, not the sprint. These motors are proven to make some serious power but the Supra and Lexus guys who swap in the 1UZ and 2UZ engines are doing it with fully built motors. The 1UZ can handle 700hp with an MLS headgasket and head studs. 2UZ has the displacement but weak connecting rods.
  13. Nov 8, 2023 at 6:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'd like a day to play with fuel pressure, compression, and cam timing to find my perfect 200hp @ 2000 rpm engine. Might be neat to see what a 2uz can do as a 2v engine. 12 hole injectors & golf ball intake ports & polished exhaust ports.
    Wanna win stop light races? 4.88's and a sonnex trans with a compushift controller. Could launch in 2nd and wet any panties within earshot.
    bmf4069 likes this.
  14. Nov 8, 2023 at 7:19 PM
    Tundras.com Forum Santa
    Tundras.com Forum Santa Milk and Cookies
    Santa
    3" Lifted Sleigh. sPOD lights on each reindeer. HeftyFab sliders
    Santa isn't sure how he feels about wet panties... :santa2:
  15. Nov 8, 2023 at 7:21 PM
    Never gotten snow in your britches before?
  16. Nov 8, 2023 at 7:33 PM
    Actually not bad. Look up the 632.
  17. Nov 8, 2023 at 7:35 PM
    Came in hungry...left hungry. Looking for soup recipes.
  18. Nov 8, 2023 at 7:36 PM
    Santa
    Santa does not wear panties; shame on you for assuming Santa's involved in those kind of fetishized perversions... :mad:
    ... it'll be the naughty list for you this year :santa2:
  19. Nov 8, 2023 at 7:44 PM
    This year? Pffffffttt. It would be easier to list the years he's not on the naughty boy list. :rofl:
  20. Nov 8, 2023 at 7:44 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    gonna like it. Unless he wears skinnyjeans.
  21. Nov 8, 2023 at 7:47 PM
    Santa
    Good point; I'll have the elves knit up some custom panties for him and make sure to leave them unwrapped under the tree...
    That should make for an interesting Christmas morning conversation in the Toasty home :thumbsup:
  22. Nov 8, 2023 at 7:48 PM
    Thanks Santa...you're the best.
    Remember, my kids get two lumps of coal this year.
  23. Nov 8, 2023 at 7:51 PM
    If I were Santa…….. I’d be selling Santa’s wet panties in Asia during the off time to keep the elves employed. Happy elves, happy shelves
    bmf4069 likes this.
  24. Nov 8, 2023 at 7:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Dads getting a telescopic mirror, and mom is getting a henry mare's leg. Gotta talk to my brother to see if he wants anything engraved.
    Polo will probably get some deer bones.
    bmf4069 and FrenchToasty like this.
  25. Nov 8, 2023 at 7:55 PM
    Santa
    Well, thank you :hattip:
    Now on to the other topic... :eek:
    Santa did not see them on the naughty list; what kind of shenanigans have been perpetrated in TJ household this year that warrant coal lumps??
    PS>>> I'm going to have to get back to checking my lists twice :santa2:
  26. Nov 8, 2023 at 7:58 PM
    Santa
    Santa does not own or operate an OnlyFan's account and therefore cannot be involved in vending used, moist, heavenly scented, textiles :santa2:
    Riverdale21 likes this.
  27. Nov 8, 2023 at 7:59 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    But he could. Probably should.
    c'mon santa bump those 6112's up to kings or fox qs3's. How often would you need my services to go LT?
  28. Nov 8, 2023 at 8:02 PM
    Oh my kids have been great. They just need to get disappointed every now and again.
  29. Nov 8, 2023 at 9:23 PM
    Santa
    LT Santa Sleigh???
    Hell yeah...:fistbump:
  30. Nov 9, 2023 at 6:35 AM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    That's 525 lb-ft of torque. Surely not something the 2UZ is going to eek out willingly, even with forced induction.
