General Supercharger Thread
  1. Nov 5, 2023 at 9:32 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I saw Brian Zacuto who owns SCOL responding to questions about the tundra mag 2650 and he said smaller pulleys are available. I’d hit them up.
    ARES35, Mdl, snivilous[OP] and 2 others like this.
  2. Nov 5, 2023 at 9:43 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    smaller pulleys are good for the soul
    Danimal86, ARES35, Mdl and 3 others like this.
  3. Nov 5, 2023 at 10:45 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Absolutely agreed! I'm currently running @snivilous 2.2 — at 6,300 ft I saw a 3psi bump, with an average 2.5psi increase - went from ~4psi to ~6.5psi. Truck feels a lot less anemic. Looking forward to that 2.0!
    snivilous[QUOTED][OP], ARES35 and Mdl like this.
  4. Nov 5, 2023 at 10:52 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I haven't really opened it up since the 2.2 pulley and 4.5 intake. It's dry today so will upload @snivilous new tune and see where we're at.
    snivilous[OP], ARES35 and Wynnded like this.
  5. Nov 5, 2023 at 11:09 AM
    ARES35
    ARES35 New member for life
    Mile high
    Pulley much needed I can't be pulling over 3lbs of boost. Challenger R/T just made me his bitch:notsure:lol
  6. Nov 5, 2023 at 11:10 AM
    ARES35
    Mile high
    Getting on it asap
    Mdl and snivilous[OP] like this.
  7. Nov 5, 2023 at 11:13 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I poked about on their website for a moment, but couldn't discern exactly which pulley(s) was(were) applicable for the Magnuson Magnum. FWTW
    Mdl and ARES35[QUOTED] like this.
  8. Nov 5, 2023 at 11:13 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Remind me…what pulley came with the mag 2650? 82mm?
  9. Nov 5, 2023 at 11:15 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Pictures posted so far show them with an 86mm.
    Mdl and ARES35 like this.
  10. Nov 5, 2023 at 11:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    there’s your problem
    Mdl, ARES35 and Wynnded[QUOTED] like this.
  11. Nov 5, 2023 at 11:28 AM
    ARES35
    Mile high
    Not cutting it haha
    Mdl, nobodyintexas and Wynnded like this.
  12. Nov 5, 2023 at 11:53 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    When I talked to SCOL about smaller pullies for the 2650, they said it was too new, no idea what they'd use.
    I talked to our contact at Magnuson and we're looking at doing a run of 3.2" pullies, which would be 81mm (stock/default is 86mm)
  13. Nov 5, 2023 at 12:01 PM
    ARES35
    Mile high
    Looks like ZPE carries a slew of pullies..... But not sure what TVS kit the Tundra falls under:confused:
    Mdl and Wynnded like this.
  14. Nov 5, 2023 at 12:05 PM
    ARES35
    Mile high
    That is correct, Magnuson states warranty is invalid if a smaller pulley is used.... I'm going to reach out and and ask about the guys running the kit at high elevation. 86mm may be great at sea level but up here it's no bueno lol
    HulkSmurf14, Mdl and Wynnded like this.
  15. Nov 5, 2023 at 12:45 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Best guess as to what that might yield, +2-3 psi?
  16. Nov 5, 2023 at 1:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Got @snivilous tune loaded and headed out before the rain starts up again. I was hitting about 10.7psi before 2.2 pulley and 4.5 intake. I do have an ASP overdrive pulley and LT with full 3 inch dual exhaust with 200 cell single cats. I hit 11.4psi and it was pulling nice and strong! Even with 4.5 intake MAF hit 4.92v.
    I hit an on ramp that is a little over 1/4 mile and went WOT but I hit a wet spot and it shifted right when I went over it and started spinning and fishtailing...Fun times. All in all it runs great and have an awesome tuner that aims to get it right!!!! Thank you @snivilous
  17. Nov 5, 2023 at 1:08 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's some boost!! Start the new budget!!
  18. Nov 5, 2023 at 1:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @HulkSmurf14 I have the tune on the rich side for protection and am also spraying, just re-adjusted from 10psi, W/M at a 70/30 mix at 9psi to aid in cooling. At some point when I get off my butt and sell my house to get away from Seattle/Tacoma area I'll start on a forged build, built transmission and replace my Auburn with Powertrax... Hopeful thinking!
  19. Nov 5, 2023 at 1:25 PM
    HulkSmurf14
    2014 Tundra Limited
    Oh damn that's right!! You're good to go man... I'm jeally of that boost!! I need to get my damn injectors, fuel pump and Sniv-awesome thrown on!! Ooooh man!!
    snivilous[OP] likes this.
  20. Nov 5, 2023 at 1:40 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I went to go throw a zip tie on my boost line supply from SC and it was split. Guess I'll have to recheck it. May be a little more psi. Of course it's raining again!
    The W/M pump fits just aft of the airbox. I also wired in a switch to shut off fuel pump, IC pump, inside fuel psi gauge and AFR/boost gauge. Gotta come up with a wire management system.
  21. Nov 5, 2023 at 1:56 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    That is extremely cool! How is the water meth activated? Is it stand alone or controlled by the gauge or something else?
    You guys pushing a lot of power are super cool and fun to watch. I think it'd be a lot of fun to have a Tundra dedicated to maximizing the power stock internals can handle for street use. Maybe when I get a tow rig to replace the Tundra some day.
  22. Nov 5, 2023 at 2:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous my brother gave me his meth/water kit. But the tank was broke the controller was fried and nozzle was trashed. The pump was good though.
    I am utilizing the W/W tank with a 70/30 mix. I'm using a Snow activation switch #81014, which is full flow, and a 325cc aem nozzle. Activated by boost sensor at 9psi but is adjustable. It's the smallest nozzle and only want it for cooling at the higher psi. You don't want it set low as it can bog the engine under 3000rpm. I added a green activation light so I know when it's doing its thing.
  23. Nov 5, 2023 at 5:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    How are you doing today!
    reywcms and snivilous[OP] like this.
  24. Nov 6, 2023 at 3:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    <Cannon Fodder>
    As I was driving home Sunday from the lake…
    I was pondering all the mods to this truck….well, really really, the wife asked why I do all this crap to the truck*.
    My summary is - everything I’ve done to this truck has been perfection.
    Blower – everything about it. Everything. The cherry on top is the ease in upgrading (pulley) It’s the Jekyll/Hyde nature of this thing. It’s damn quiet till you hit the gas. It doesn’t affect mileage till you hit the gas. <I got 19.2mpg on the 93 mile trip Conroe to South Houston – small tailwind)
    Caltracs traction bars–once you pass the adj phase - perfection
    TRD Exhaust – only loud when you want it to be. No drone.
    Gauges - AFR & Boost with a Cravenspeed mount – is monitoring perfection. Add in the SG3 on the left side of the steering wheel (cravenspeed mount)& bam….even better.
    Brightbox fog mod – bright light perfection
    Hot-tails tail light mod…super bright tail light perfection
    OPT-7 rear brake light bar – super bright. I love the Reverse lights.
    The only thing that has been lackluster – the center console wireless charger. I don’t use it since I use Carplay.
    This is where I say – “I’ll stop the mods here, because I'm now satisfied”, and then continue doing shit.
    I’m watching all y’alls intake mods with eager eyes. Or…let’s just get busy doing a built block with 900hp + mondo transmission. Harrop 3100 needs me.
    *Her automotive perspective is a Tesla Model S Plaid. Which is like driving a big iPhone. It’s perfect in every imaginable way. The world is flat to her.
  25. Nov 6, 2023 at 7:02 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Heres a quote from 4firemandan
    "Well... My WIFE says it's a sickness. She calls it "cantfreakingleavethatstupidtruckalone"... But I don't know if that's the official medical name."
    Sounds good to me!
  26. Nov 6, 2023 at 12:01 PM
    ARES35
    Mile high
    Alright so I was able to get some info on pullies for the TVS 2650. SCOL said that they are looking into it but the cone nose may be to small for a smaller pulley?! I was confused by that statement. ZPE does not carry any pullies yet for the TVS. They said if I shipped them my stock 86mm they could fab some up that would work for our application. Magnuson confirmed changing the pulley will void the warranty..... Don't matter if your a mile high, on the moon in a black hole shits voided. Good news is they do have a 2.9 pulley but it isn't shown on there website. Was told I could order through sales. Part number for said pulley is as follows, 57-99-08-029. He said it'll produce around 3/4 more psi fyi
  27. Nov 6, 2023 at 12:36 PM
    Silver17
    Eastern PA
    Well, I guess it’s clear SCOL was wrong if they don’t think you can run a smaller one but Magnuson tells you there is a 2.9” pulley a available. 2.9” is like a 73.5ish MM pulley which would normally not be advised for most to run at sea level, but if you’re at elevation then it’s probably fine? Hopefully they will offer smaller than that at some point, since that’s still less flow than Snivs 2.0 on a 1900 by a good margin, as well as the smaller Harrop offerings (65/70mm) on their 2650.
    Maybe you can order that pulley through SCOL using that part number to prevent magnuson from being aware you have a smaller than stock pulley installed if issues arise.
  28. Nov 6, 2023 at 3:50 PM
    ARES35
    Mile high
    Fawc, SCOL's response on smaller pulley
    Land Bruiser likes this.
  29. Nov 6, 2023 at 4:35 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What fuel pump and injectors come with the kit?
    ARES35[QUOTED] likes this.
  30. Nov 6, 2023 at 4:58 PM
    ARES35
    Mile high
    Mines the flex fuel although I did get the non flex kit with pump. Pump wasn't changed and the injectors with kit were the greens, not exactly sure of the CC's for the bill of sale shows "high flow". Will have to inquire with Magnuson on exact specs
