  1. Nov 4, 2023 at 5:42 AM
    How many miles on it?
  2. Nov 4, 2023 at 7:26 AM
    Follow up daytime pics. Very clear. Very happy.
    bmf4069, txagg, 912 and 6 others like this.
  3. Nov 4, 2023 at 7:27 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Nice. Curious to see how long it lasts. All the brands I've tried lasted six months give or take
  4. Nov 4, 2023 at 7:44 AM
    The sun hits a little different in the southwest
    NUDRAT and dirtnsmores[QUOTED] like this.
  5. Nov 4, 2023 at 8:50 AM
    Houston, we have a problem(s)
  6. Nov 4, 2023 at 8:56 AM
    Getting the full Monty today. Brakes bled, driveline lubed, tires rotated, oil change, throttle body and MAF cleaned, rear brakes adjusted and looks like new steering rack bushings. Lower ball joint boots are fucked, so ordering some new OEM LBJs. Axles are Advanced auto, lifetime warranty. This will be my third exchange due to failing boots.
    oscardog86, bmf4069, txagg and 8 others like this.
  7. Nov 4, 2023 at 9:54 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Dude. You're not selling your truck. That's just crazy talk. If you lose all your marbles and do something so foolish, make sure you sell it to me. You have got one of the cleanest 1st Gens on the planet.
  8. Nov 4, 2023 at 10:06 AM
    Same with skin cancer I suppose.
  9. Nov 4, 2023 at 10:09 AM
    Most definitely, Melanoma capital of the world!
    I was on accutane as a young lad, and sun exposure is super bad when your on it; I was a lifeguard, my mom would drive by the pool while I was on stand and scream “put on a fucking shirt!!!!”
    I went thru chap stick like it was going out of style!
    oscardog86, bmf4069, txagg and 3 others like this.
  10. Nov 4, 2023 at 10:12 AM
    More carnage
    bmf4069, Voss and Jack McCarthy like this.
  11. Nov 4, 2023 at 10:13 AM
    Simple solution…… sway bar delete
    oscardog86, bmf4069, Voss and 3 others like this.
  12. Nov 4, 2023 at 10:14 AM
    For some reason I was just thinking you were going to respond “Was that an attempt at a burn?”
    :rimshot:
  13. Nov 4, 2023 at 10:14 AM
    gonna try some washers under the lower bushing cup first to lessen the angle. Or get extended ones.
  14. Nov 4, 2023 at 10:16 AM
    I try and be smarter about it now, same with the boys, thankfully my youngest doesn’t mind wearing a hat, and he looks super cute with one on.
  15. Nov 4, 2023 at 10:17 AM
    Also if you don’t have that rack bushing, I think I have an oem one I can send your way.
    bmf4069, Voss, NUDRAT and 1 other person like this.
  16. Nov 4, 2023 at 10:20 AM
    Fixing it today, grabbing an Oreilly’s available one so I can change it again in 3 years
  17. Nov 4, 2023 at 10:21 AM
    Hahah I like your method
    KNABORES[QUOTED] likes this.
  18. Nov 4, 2023 at 11:36 AM
    Got one side done here. The YouTube videos on this are helpful.
    Are most of you still running your original drums?
    oscardog86, bmf4069, 912 and 3 others like this.
  19. Nov 4, 2023 at 11:42 AM
    Yep. I am. As crusty as they are.
    oscardog86, Voss and JasonC. like this.
  20. Nov 4, 2023 at 11:45 AM
    Done with maintenance day. Mostly. Happy with my sway bar “spacer” results. Sits pretty level now. The upper bushing isn’t the correct style. Another round coming soon for LBJs, bearing and CVs.
    oscardog86, bmf4069, txagg and 4 others like this.
  21. Nov 4, 2023 at 11:50 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Got my 1G rustproofed today. Woolwax.
    Always fun getting on the highway & watching the sea part behind me as the overspray on the exhaust & engine create an impressive blue plume.
    oscardog86, bmf4069, KNABORES and 8 others like this.
  22. Nov 4, 2023 at 12:04 PM
    This thing is driving great now. Brakes feel awesome, steering is tight again and of course the motor always runs smoother after an oil change.
  23. Nov 4, 2023 at 12:04 PM
    I think I need to unhook mine. I'm pretty sure it's the source of most of my quiet pops and thunks at the moment.
    I got under the truck today, greased driveline, double-checked LBJ bolts. I really need to confirm torque on bolts at some point tomorrow too. I need to start thinking about swapping out my rack bushings for poly bushings too.
  24. Nov 4, 2023 at 12:52 PM
    daveeasa
    I got new drums, springs, shoes and wheel cylinders. Not sure what else I could replace other than going to 4 wheel disks. Jason felt that it wasn’t worth the cost and effort. Drums are fine by me, they work.
    Jack McCarthy, Voss, JasonC. and 3 others like this.
  25. Nov 4, 2023 at 12:53 PM
    Next brake job I’m replacing drums and discs instead of turning them, start from ground zero
  26. Nov 4, 2023 at 12:55 PM
    This is the way now. Rotors are not thick enough to turn anymore. They will just warp sooner after turning.
    bmf4069, Voss, FirstGenVol and 4 others like this.
  27. Nov 4, 2023 at 3:04 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Boy, I worked in the yard and everybody else did shit to their trucks. Rock on!
    bmf4069, txagg, Voss and 2 others like this.
  28. Nov 4, 2023 at 4:08 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I mowed out back too. Somehow the yard turned into a mushroom field - bogging down the lawn mower thick mushrooms. Where'd they come from?
  29. Nov 4, 2023 at 4:09 PM
    Finished up the other side earlier. I confirmed both self adjusters seem to be working as designed when I press the parking brake, even the Napa adjuster on the passenger side. Happy this job is over.
    https://youtu.be/Zi1t2npPdEo?si=7cbYMVOmSK7oIvGn
    bmf4069, txagg, Voss and 6 others like this.
  30. Nov 4, 2023 at 4:12 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Suck it @txagg
    bmf4069, txagg, KNABORES and 3 others like this.
