  1. Nov 2, 2023 at 1:23 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    When I swapped all of my cluster bulbs to LED, it’s screwed with everything. Once I put them back to incandescent, everything worked properly
  2. Nov 2, 2023 at 1:23 PM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    NUDRAT and bmf4069 like this.
  3. Nov 2, 2023 at 1:24 PM
    These are just incandescents. There shouldn’t be a polarity now that I think about it.
    BroHon likes this.
  4. Nov 2, 2023 at 1:28 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The low fuel light isn't just a regular incandescent it's got some witchcraft in it. Not sure if the check engine is the same
  5. Nov 2, 2023 at 1:31 PM
    Ok I’ll check it with the multimeter.
  6. Nov 2, 2023 at 1:33 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I just so happen to have my truck in front of me at the time
    Voss, JasonC., BroHon and 2 others like this.
  7. Nov 2, 2023 at 1:39 PM
    Dakillacore
    Georgia
    You do have one good lookin truck.
    Voss and The Black Mamba[QUOTED] like this.
  8. Nov 2, 2023 at 1:44 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Thank you. Balance and rotate today.
  9. Nov 2, 2023 at 1:48 PM
    Got my check engine light back by using the adjacent bulb but now one of them is out and it’s difficult to tell if the fuel light is working. Ohmmeter jumps all over the place.
    Appears these 194s are huge and do not fit the shifter light sockets. Anyone got a breakdown on the different bulbs for the dash console?
    Fuel bulb is bigger than check engine bulb. Check engine bulb is bigger than the shifter bulbs. Here’s a comparison of the 194s I bought and the tiny shifter lights which say T80 on the back.
    Voss likes this.
  10. Nov 2, 2023 at 1:52 PM
    Dakillacore
    Georgia
    Gauge cluster: 4x T10 bulb - https://amzn.to/3HXQNoj 19x T5 bulb - https://amzn.to/3X49pac (Only 1 is needed for backlighting, the rest are for warning/indicator lights) 7x 4.2mm NEO bulb - https://amzn.to/3HBHhpe (OEM non-led option)
    I got it from this videos description: https://www.youtube.com/watch?v=H1MKCgnfCu4
  11. Nov 2, 2023 at 2:02 PM
    BroHon, txagg, shifty` and 1 other person like this.
  12. Nov 2, 2023 at 2:13 PM
    Well swapped my non-existent wiper fluid low sensor light with whatever is between check engine and a/t oil temp lights. My owner’s manual doesn’t seem to tell me. I believe my fuel light is working. I can get a better read on resistance with the bulbs mounted in the console circuit. This thing is finicky.
    The Black Mamba likes this.
  13. Nov 2, 2023 at 3:54 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Tires balanced. This was a long time coming. I’ve been putting it off and should have done it sooner. Truck drives great.
    BroHon, NUDRAT, bmf4069 and 1 other person like this.
  14. Nov 2, 2023 at 4:01 PM
    Holy cow, they shipped?! I haven't heard back from them still. Did they notify you before shipment?
  15. Nov 2, 2023 at 4:12 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Yes, I got two emails: 1) Shipped, and 2) Tracking
  16. Nov 2, 2023 at 4:14 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    When you wire them backwards they get dark instead of bright. :annoyed:
  17. Nov 2, 2023 at 4:20 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I'm pretty certain @Tundra2 posted a list of all the bulbs for all the dash positions back when he was doing dad's truck.
  18. Nov 2, 2023 at 4:25 PM
    I’ll have to check his build thread. @bmf4069 did a pretty good job with his spreadsheet listing.
    Tundra2, NUDRAT[QUOTED] and bmf4069 like this.
  19. Nov 2, 2023 at 4:28 PM
    As much as I'd like to take credit, I stole that from someone here back in 2020.
  20. Nov 2, 2023 at 4:29 PM
    No, you passed it on. It’s like a baton in a relay race.
    Voss, NUDRAT and bmf4069[QUOTED] like this.
  21. Nov 2, 2023 at 4:34 PM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    EDIT: scratch all this, you are not doing LED, my bad o_O
    I kept the low fuel incandescent when I did my LED conversion. I heard it needed the resistance.
    Take a super close look at those wires that are supposed to make contact with the traces on the cluster.
    I even used a tiny tiny swab of dialectric silicon after cleaning the contact areas
    Try a different one, could be a Dud right out of the box?
    A couple of them looked like this
  22. Nov 2, 2023 at 4:39 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Yesir, grey is low fuel
  23. Nov 2, 2023 at 4:47 PM
    Hell yeah, I guess I'll leave the order open then. I still haven't called them, and still haven't gotten an 'order canceled' email yet. Fingers crossed they come this month :D
    Congrats!!
    Although someone on here posted recently they got a reman, and the damn thing had something wrong with it. I forget what the issue wast. I just though, "man, that sucks!" and I swear it was something under-the-inner-boot.
  24. Nov 2, 2023 at 5:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Trim it, and file it. In the words of chains "Don't act dumb."
  25. Nov 2, 2023 at 9:14 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    in the special Olympics
    artsr2002, Voss, RUSTYNUTS and 5 others like this.
  26. Nov 3, 2023 at 3:25 AM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Yeah, I don't remember exactly what I did but it's way small to think about filing. Just some cheap LEDs, I def checked the rest of them though. QUOTE is good for life in general, to bad more people don't follow it.
  27. Nov 3, 2023 at 5:12 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    When I pulled out the LED bulbs in mine, I found that the LED bulb contact base had stretched the housing contact points out. I had to take a small flat head and massage the contact points in to get them to make a good contact with the incandescent bulbs. Not sure if that's what is going on, but it was my experience.
  28. Nov 3, 2023 at 6:59 AM
    Dakillacore
    Georgia
    I'm not sure what's in the middle but the TPMS is on the far right per my truck.
  29. Nov 3, 2023 at 7:21 AM
    That's where the "A/T P" light is. It's a warning light for the 4wd system when your in park instead of neutral switching between 4hi and 4lo.
  30. Nov 3, 2023 at 7:33 AM
    Yeah, no tpms for me.
    Thanks, @KNABORES. It’s good to know what it’s for since the light appears to have always been out for me.
