2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Oct 11, 2023 at 5:48 PM
    #1531
    Levipooh
    Levipooh New Member
    2014 Black Tundra SR5
    Hi, I’m I little confused, what I do with the red wire that comes at the end of the fuse by the underdash relay?
  2. Oct 11, 2023 at 5:51 PM
    #1532
    AZBoatHauler
    So.Arizona
    From the first post -
    1lowlife and Levipooh[QUOTED] like this.
  3. Oct 11, 2023 at 6:10 PM
    #1533
    Levipooh
    Levipooh New Member
    Thanks, I figured out now but any idea why my blinkers light in dash blink so fast and on the front they won’t work?
  4. Oct 18, 2023 at 11:45 AM
    #1534
    ronrich
    ronrich New Member
    @iHacker I am interested in purchasing one of your conversion harnesses. I have a 2015 Tundra Limited which does not have the white strip DRL, but just a single amber replaceable bulb which acts as both the DRL and turn signal. I've read through your installation instructions and am leaning toward the DRL full brightness version $110.00 because it appears to be plug and play. But in the instructions it states you have to disconnect some wires in the cabin to make the turn signals work properly. Did I misread or misunderstand this? Just want to make sure I'm not getting in over my head with this installation. Do you have this version of the harness available? What is the best way to place the order? Thanks!
    iHacker[OP] and AZBoatHauler like this.
  5. Oct 18, 2023 at 11:48 AM
    #1535
    AZBoatHauler
    So.Arizona
    If you don’t cut the wire you’re referencing you will have both the LED strip and the amber for DRL. No big deal - I ran mine that way for a few months before cutting the wire to kill the amber DRL.
    iHacker[OP] likes this.
  6. Oct 18, 2023 at 1:43 PM
    #1536
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    As he said keeping the wire under dashboard untouched do not affect your turn signal and just keep your amber DRL, some people like that.
  7. Oct 24, 2023 at 8:30 AM
    #1537
    blakec177
    blakec177 New Member
  8. Oct 27, 2023 at 8:26 PM
    #1538
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    Shoutout to iHacker for a high quality product & quick shipping! I got my harness within the week I ordered it & had no issues while installing these LED headlights on my 2017 Limited CrewMax. Everything was plug & play & worked the way it was supposed to. I could not be happier with how the truck came out. Don't hesitate to get your harness from him, he's got a great quality product.
    Here are some before & after pics:IMG_20230805_103354413_HDR.jpg IMG_20231027_181056560_HDR.jpg IMG_20231027_181028629_HDR.jpg
  9. Oct 30, 2023 at 6:11 PM
    #1539
    ronrich
    ronrich New Member
    Just completed the install of my TRD Pro black headlights and fogs on my 2015 supercharged Tundra Limited. It took around 6 hrs. over a couple of days, but I took my time. I'd first like to extend a special thanks to @iHacker for putting out a first class quality PNP product with fast shipping and great instructions. Much appreciated! Should have done this a long time ago, because the stock halogens were terrible. I've attached the before and after beam patterns and a couple pics of the new lights. I am real pleased with the result. Again, thumbs up to @iHacker for his harness.
    old beam pattern 1.png new beam pattern 1.png new lights day.png new lights night.png
  10. Nov 25, 2023 at 7:58 AM
    #1540
    BR33ZY
    BR33ZY XP Rockstar ha
    I have a 2016 SR5 that I want to put 2019 black OEM LEDs in. I'd rather have DRL on all the time than run through the firewall. I'm pretty sure I have single amber DRL but it does look like there is a light strip on the bottom. I've never seen it on in the two weeks I've owned the truck though.
    What harness do I need? Also, any recommendations on where to get OEM LED lights?
  11. Nov 25, 2023 at 8:14 AM
    #1541
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Message @iHacker about a 1lowlife setup.
    I didn't want the bright white LED strips for DRLs.
    Ask him if your 2016 headlights are like my 2014, and it sounds like they are.
    He can make you a plug-and-play adapter that keeps the amber DRL and turns on the upper and lower white strips on dim with the parking and headlights.
    If your headlights look like this, there is no LED strip on the bottom.
    5D7E009A-7757-4E27-94C2-C7981799DDA7_zps_ed3a583133cde85b62d92cffcc1fd1f2a41d2613.jpg
    E9F0D5CF-2127-42AC-B5EC-D61C8AB50038_zps_3b4b4a40c7fcc0810d9ee7c6dc4683242d428cca.jpg
    TRD Pro halogens.
    2018+ OEM TRD Pro LED headlights
    Daytime DRL
    Parking lights
    Headlights
    And welcome to the forum..
  12. Nov 25, 2023 at 8:21 AM
    #1542
    iHacker
    Mario
    Hello, welcome to the forum
    Your SR5 truck have a fake DRL strip but isn’t working is just an empty line without any LEDs and is just for looking only not a working LED strip.
    To get the LED strip on the new lights working as you describe I recommend using the Non dimming harness and you get constant power from the fuses box and the LED strip is switched with the ignition.
    For the best place to buy you can check Toyota Parts online site they are offering a thanksgiving sale in some parts you select the dealer where you decide to buy, I just checked and selected a dealership not too far from me and the price is really a great deal
    https://autoparts.toyota.com/
    I used dealership Fowler Toyota in Tulsa Oklahoma
    Part Numbers for TRD PRO black headlights
    Right Hand Side
    - Headlamp Assembly RH - 81110-0C211
    Left Hand Side
    - Headlamp Assembly LH - 81150-0C211
  13. Nov 25, 2023 at 8:24 AM
    #1543
    1lowlife
    DADA
    2014 MGM DC SR5
    I thought he meant he wanted to keep his amber DLRs..:eek2:
    It's too early for me....:cool:
    Those bright white DRL strips are pretty bright at night..:p
    BR33ZY and iHacker[QUOTED][OP] like this.
  14. Nov 25, 2023 at 7:15 PM
    #1544
    BR33ZY
    Ok Good info guys! I ordered the lights from the dealer in town, less than $500 so thanks for that info.
    I'd like to order the Non dimming harness so please PM me.
    1lowlife and iHacker[OP] like this.
  15. Nov 26, 2023 at 9:05 AM
    #1545
    iHacker
    Mario
    I sent you a PM
    BR33ZY[QUOTED] and 1lowlife like this.
  16. Dec 1, 2023 at 7:25 AM
    #1546
    tundraal
    tundraal New Member
    Question - I've upgraded to the OEM LED lights... is the drivers side headlight supposed to dim after about a minute? It’s bright when I first crank up and then it dims after about a minute. Here’s two pictures I made this morning in my garage. First picture shows when I crank and put in drive- both headlights are bright. Then second picture shows about a minute later that the drivers headlight dimmed about 50%.
    I DMd ihacker, but wanted to see if anyone else had this issue before.
  17. Dec 4, 2023 at 5:22 AM
    #1547
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    What brand of Aftermarket did you get?? I purchased a set from TYC about five months ago and the light output is worse that my Halogens. I have already replaced them under warranty once with no improvement
  18. Dec 8, 2023 at 7:22 AM
    #1548
    Cronion
    Cronion New Member
    It looks like this pnp harness easily accommodates new LED headlight assembly packages but I only replaced the bulbs *meaning my directional bulbs are still the oem ones*. Is there a package here that someone can recommend that needs no further fuss or do I need to first buy additional LED directional bulbs or an entire LED headlight assembly?
    My Tundra:
    2014 Toyota Tundra SR5 - no special edition anything.
    4WD Truck Double Cab
    5.7 Liter V8
    6-Speed Automatic Transmission
    w/tow pkg.
    My new LED bulbs:
    SEALIGHT H4 9003 Powersports LED Bulbs for ATV, Super Bright Hi/Lo Dual Beam H4/9003/HB2 Powersports LED Bulbs, 6000K Eye-Protection White, Quick Installation Halogen Replacement, Pack of 2 - which, b.t.w., are no longer sold on Amazon for some reason
  19. Dec 22, 2023 at 2:56 PM
    #1549
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
    Anyone know of a sale going on? Cheapest I can find is 322/per and free shipping
  20. Dec 24, 2023 at 2:51 PM
    #1550
    ronrich
    ronrich New Member
    Here one running a sale on a used one (right side). Says it is in great condition.
    https://www.ebay.com/itm/144785096567
    Here is one with repaired tabs (left side), if your interested.
    https://www.ebay.com/itm/134847680996?epid=19044174335
    Plus it looks like ebay is running some kind of special.
    Enter a code at checkout to redeem another $10.00 off. Coupon expires Dec 29, 2023. Terms and conditions apply.
    dan8906[QUOTED] and iHacker[OP] like this.
  21. Jan 7, 2024 at 3:48 PM
    #1551
    iyaman
    iyaman New Member
    2016 platinum
    @iHacker, sent you a message. Thank you.
  22. Jan 7, 2024 at 5:33 PM
    #1552
    1lowlife
    DADA
    2014 MGM DC SR5
    He is the best...:thumbsup:
    iyaman[QUOTED] and iHacker[OP] like this.
  23. Jan 7, 2024 at 8:55 PM
    #1553
    iyaman
    iyaman New Member
    2016 platinum
    I'm curious about your headlight set up. I like the idea of the amber light as DRL as it will match the DD SS3 fog light backlight. You think it's possible for @iHacker to do the harness so my DRL will be the same as your parking light? Thank you.
  24. Jan 7, 2024 at 9:37 PM
    #1554
    iHacker
    Mario
    Thanks James.
    Sent you a PM.
  25. Jan 8, 2024 at 3:19 AM
    #1555
    Geo505
    Geo505 New Member
    Hello everyone!
    Just joined. I have a 2019 SR5 and I’m looking to do the headlight conversion to the OEM LEDs.
    How do I get this Ihacker harness so I can install my headlights and what options do I have for the harness?
    Are all the harness options the same? I saw there’s a dimming and non dimming one?
  26. Jan 8, 2024 at 5:20 AM
    #1556
    PermaFrostTRD
    Northern NY
    page 1, post 1 of this exact thread.
  27. Jan 8, 2024 at 7:24 AM
    #1557
    iHacker
    Mario
    Sent you a PM
    Tundrastruck91 likes this.
  28. Jan 11, 2024 at 12:51 PM
    #1558
    rickneedsabeer
    rickneedsabeer New Member
    I would like to convert my 2014 1794 Tundra headlights to the 2018 oem version. How do I obtain the harnesses to do so?
  29. Jan 11, 2024 at 12:59 PM
    #1559
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    First page, first post on this thread
  30. Jan 11, 2024 at 1:31 PM
    #1560
    iHacker
    Mario
    PMed
