General Supercharger Thread
  1. Oct 24, 2023 at 9:10 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    On the Harrop, the boost reference port is on the driver's side of the unit. In the picture below you can see my vacuum line (black) running down to the port from my vacuum manifold.
    reywcms likes this.
  2. Oct 24, 2023 at 9:11 AM
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    For what it's worth, I can confirm the truck is running as it should. You're entering enrichment and getting into boost. It's a gauge/installation issue 100%.
  3. Oct 24, 2023 at 9:13 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @19PlatinumCrew look on your intake back side there is a vacuum port for your fuel regulator. See if they teed your boost reference there. The boost ref should be on drivers side rear of blower by fuel disconnect.
  4. Oct 24, 2023 at 9:21 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I've snapped two different URD pulley studs just like that...
    not that it really matters, but were you able to tell the difference in the way it was cast? I bought a TB for the tundra off Amazon to troubleshoot my issues, and you could very definitely tell it was a Sand Cast process, with all the bumps on the outside metal. The OEM is smooth.
    Wynnded likes this.
  5. Oct 24, 2023 at 9:22 AM
    M3Tundra-JK
    Scott
    2005 GX470
    I went with OTT custom/remote tuning
    19PlatinumCrew likes this.
  6. Oct 24, 2023 at 9:25 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    I am certain you have done it correctly, you guys were the 1 good thing out of all the problems
    JustDSM[QUOTED] likes this.
  7. Oct 24, 2023 at 9:27 AM
    19PlatinumCrew
    Dave
    Will check it tonight I'm away from the truck
    Mdl[QUOTED] likes this.
  8. Oct 24, 2023 at 9:29 AM
    19PlatinumCrew
    Dave
    Justin can you show me the graph when we did my last run, it was scooting pretty good
  9. Oct 24, 2023 at 9:37 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Mine are aftermarket. Don't quote me, but from my understanding, if the 1st set of catalytic converters are of good quality, then you shouldn't run into downstream O2 errors, as the secondary set of cats aren't monitored.
    I live south of Denver but was staying at a Marriott in SLC when they were stollen. East California, I mean Colorado, follows CARB which UT couldn't care less about. That said, my options for my situation were EPA approved cats. A shop was able to source Magnaflow cats, the drivers side being "OEM Grade" and the passengers side being a lesser quality "EPA Approved." Since everyone else's cats were being stolen at the time, cats were scarce, and I needed to get back on the road, so I went with what they could find. Unfortunately my codes are coming from the passenger side (the lesser quality), so it looks like I'm buying another bank of cats.
    I thought I'd try my luck as I had heard from others good fortune using the URD tool. In retrospect, I wish I waited a month for the 4-bolt hub 2650 Maggie :rofl:(I unknowingly purchased my S/C shortly before the 2650 was released)
    But yes, a press would have been the way to go. I am loving the pulley though! I'll shoot you an email about getting a 2.0 pulley.
  10. Oct 24, 2023 at 9:42 AM
    M3Tundra-JK
    Scott
    2005 GX470
    In my experience using the URD tool, it's required to heat up the pulley so it slides on better. Not in instructions, but it's what I had to do. Wish I had the press I have now from the beginning. 20-ton Harbor freight press made it super simple. Could've bought the smaller one and it would've still been an infinitely better experience over the URD tool.
  11. Oct 24, 2023 at 9:49 AM
    PolishedTRD
    CO
    Funny you should mention adding heat, as that is exactly what I did! I think what happened is I added too much heat, the heat transferred to the tool and fatigued the stud.
    The second round I cooled the pulley shaft by spraying it with an upside-down can of dustoff, then added a moderate amount of heat to the hub. Went on like butter!
  12. Oct 24, 2023 at 10:53 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Interesting to see such a performance difference between the two sets of cats.
    PolishedTRD[QUOTED] likes this.
  13. Oct 24, 2023 at 11:03 AM
    PolishedTRD
    CO
    Agreed! I use OBD Fusion (when not logging with HP Tuners) and have a stock pile of data logs. I found that on average, the cats run about 200º hotter now, than they did prior to supercharging. I imagine the larger volume of gases during acceleration exacerbated the poor performance of the lesser quality cats, as my P0430 didn't appear until after adding the S/C. Just a theory.
  14. Oct 24, 2023 at 1:06 PM
    ARES35
    ARES35 New member for life
    Mile high
    Just wanted to give an update on my TVS 2560 install. I was planning on starting once I received my Mazdaspeed shift cables so I could get that car out of my garage. Problem is wouldn't be shipped out till the 29th so I wouldn't have started until beginning of November. So Figs engineering, the shop I bought my kit from offered to do the install at a fair deal. On top of that they will be documenting the whole install since unbeknownst to me my Tundra will be the first Magnuson 2650 installed in Colorado. So I dropped the truck and kit off this morning. They have started the tuning process but as of now the HP tuner is having trouble communicating with my 2017 ECU to pull the ID. They have reached out to Magnuson to see what needs to happen. Once that's figured the kit install will commence. I'll keep this thread updated as I hear back:cool:
    ssmokedz, e30cabrio, Wynnded and 7 others like this.
  15. Oct 24, 2023 at 1:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Freaking exciting Cole! Woot woot!
    ARES35 likes this.
  16. Oct 24, 2023 at 1:16 PM
    ARES35
    Mile high
    Thank you sir! Just hope this damn HP RTD tuner shenanigans gets sorted sooner rather then later ..... but shit happens so:fingerscrossed::D
    HulkSmurf14[QUOTED] likes this.
  17. Oct 24, 2023 at 1:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Weren't there a few Tundras that had the same issue with HPT reading the file. It just needs to generate a generic file for that year?
    ARES35 likes this.
  18. Oct 24, 2023 at 1:32 PM
    ARES35
    Mile high
    The HP RTD connects but will not pull the ECU ID/information. Mike used his VF tuner and it connected and read the ECU no problem so not sure why the HP is having troubles....
  19. Oct 24, 2023 at 1:32 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Not RTD, but my HPT wouldn't communicate to read the file until I updated to the latest beta version. Works perfectly now. My truck is an '07 tho...
    snivilous[OP] and ARES35 like this.
  20. Oct 24, 2023 at 2:04 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    He might need an update on the firmware. From my reading of the instructions for the RTD. But if he has the mpvi cable he doesn’t need the rtd at all
  21. Oct 24, 2023 at 2:48 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I've seen files that has garbled data too. It'd pull the tune but some of the variables were all jacked up.
    Mdl[QUOTED] and reywcms like this.
  22. Oct 24, 2023 at 5:19 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    So you got yours installed then? Tell us what ya think!
    mZiggy[QUOTED] and HulkSmurf14 like this.
  23. Oct 24, 2023 at 5:58 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Oh yeah, it's been excellent!
    And while I don't care about fuel economy as long as it sits above single digits, I did have to laugh at the 21.4mpg average while on a road trip at 75-80mph lol
    Been having plenty of fun with it already though. Hardware is really well made as you'd expect as well.
    Magnuson's full color install guide (while available online nonetheless) included as a nice booklet was a nice addition too.
  24. Oct 24, 2023 at 6:17 PM
    Silver17
    Eastern PA
    I’m glad to hear you’re enjoying it so far! It definitely transforms the truck IMO. Is it also a quieter whine like the Harrop seems to be? You’re probably not getting worse MPG, but if you were going by the dash readout it was probably optimistic by at least 5mpg from the difference in injector size. If you want to track it accurately I recommend the scangauge 2 or 3 and you can calibrate the fuel usage to get an accurate MPG, distance to empty, and gallons used/remaining readout. It’s invaluable info in my case towing a TT long distances at 8mpg lol.
    Saltyhero13, HulkSmurf14 and reywcms like this.
  25. Oct 24, 2023 at 6:34 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I was not paying attention, it was 100% oem
    Here are the pictures I took
    ARES35, Saltyhero13, Wynnded and 2 others like this.
  26. Oct 24, 2023 at 6:41 PM
    HulkSmurf14
    2014 Tundra Limited
    With 535cc injectors, I have averaged the last 40k miles at 5.3mpg off from what my computer says to what is actual hand-calc'd...it's perfect for those sitting next to you that complain about MPG...I mean the boss :hattip:
    mZiggy[QUOTED] likes this.
  27. Oct 24, 2023 at 6:42 PM
    mZiggy
    mZiggy Honey badger
    Marc
    I was just tracking by the dash, I've never cared enough to actually track it more accurately or account for my 285's. And I've always taken the numbers with a healthy grain of salt due to my commute to work being only 9mi, 50% city...skews the numbers too much so I only really pay attention on road trips.
    Whine is definitely quieter than the tvs1900, right about on par with what I remember the Harrop to be like but it's been a bit since I heard that one.
    HulkSmurf14 and Silver17[QUOTED] like this.
  28. Oct 24, 2023 at 7:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @e30cabrio were your idle rpms high on first startup with RCF? System has to relearn?
  29. Oct 24, 2023 at 7:46 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Mine were not at all ran and drove normal. I drove it awhile before a tune update
    Fastlane47 and Mdl[QUOTED] like this.
  30. Oct 24, 2023 at 7:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I fired it up to check for leaks and was about 2500rpms. Didn't run long as it started pouring out.
    I do need to data log to see where the tune is after the 4.5 intake and 750's.
    reywcms likes this.
