Finally got the ok for a Supercharger
Discussion in 'Performance and Tuning' started by 19PlatinumCrew, Aug 10, 2023.
  1. Oct 18, 2023 at 9:19 AM
    #421
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    As long as you're aware what your setup is and should be reading it doesn't matter imo. As to why "we" do it, well the instructions say to install it there :D and it's where the stock sensor is too so you can double check the stock sensor and vice versa.
  2. Oct 18, 2023 at 10:06 AM
    #422
    JustDSM
    JustDSM New Member
    Justin
    Great Question!
    Let's take a look at this very thing with some actual data. All collected at the same time.
    2G Tacoma, all stock other than a ProCharger kit as our test subject. Stock exhaust, stock ypipe w/ 2nd cats, and stock manifolds with primary's. Let's look at what the factory O2's read (before all 4 cats) what the wideband read (it was installed by ProCharger after the merge in the ypipe so after all 4 cats). and we'll look at what the tail pipe sniffer said.
    Stock ProCharger tune:
    How's that for "lean"..... :)
    To a work in progress configuration with a bit richer mixtures..
    There you have it. I'll let you guys digest on that for a bit. :)
  3. Oct 18, 2023 at 11:57 AM
    #423
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    3 hours just to weld a bung or install the wideband setup? I installed my wideband and it was fairly annoying running the wiring but took around 3 hours. I had a local shop weld the bung for $150
  4. Oct 18, 2023 at 2:31 PM
    #424
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    570 bucks for gauge install basically to set it up and wire it in I had already mounted it in the ac vent and ran the wires to the driver's side fuse pannel. National Speed was to pull cat pipe and weld in bung,wire up the gauge and I told them passenger side before primary cat...again NO COMMUNICATION OR JUST DONT CARE...didn't mean to yell
  5. Oct 18, 2023 at 4:21 PM
    #425
    Saltyhero13
    Saltyhero13 Throbbing Member
    You are justifiably emoting frustration. For the money they ask for they certainly didn't treat you well nor do the job correctly.
    Shame on them. Reputations are hard to rebuild.
  6. Oct 18, 2023 at 5:05 PM
    #426
    19PlatinumCrew
    Dave
    At this point I think that ANYONE looking to have National Speed do work for them should be aware of my situation. We are adults and can make our own choices, I am not going to rant and rave and call out anyone personally all I will do is relate MY experience with them,what has and may happen in the future as I use my truck.
    We have a trip planned Nov 1st and I will be towing the camper so that will be interesting to see how it towes with the Supercharger. I do worry about the installation since we all have seen how many things that have gone wrong with my installation, just hope it doesn't leave us stranded on the side of the road.
    As far as the afr gauge and sensor location I'm attempting to resolve that before our trip. Thanks to ALL the forum members that have commented, offered information and advice.....to be continued
  7. Oct 18, 2023 at 5:17 PM
    #427
    JohnWhicker
    JohnWhicker New Member
    Just curious, how many HP did you gain after 12K? I am kind of new to this so excuse my ignorance please.
  8. Oct 18, 2023 at 5:19 PM
    #428
    19PlatinumCrew
    Dave
    Hp 488 tq 490....Headaches 100%
  9. Oct 18, 2023 at 5:26 PM
    #429
    JohnWhicker
    On a 5.7 I assume, so about 100HP gain from stock, give or take. Man that's a stiff price to pay. No turbo options on these engines? I have a V12 5.7 with dual turbo but that's a BMW. Just curious.
  10. Oct 18, 2023 at 5:30 PM
    #430
    19PlatinumCrew
    Dave
    I have read that someone is developing a turbo option don't know if it's in production just yet.
  11. Oct 18, 2023 at 5:32 PM
    #431
    JohnWhicker
    Thanks brother and enjoy it. The headaches will pass :) and stay positive
    19PlatinumCrew[OP] likes this.
  12. Oct 18, 2023 at 5:49 PM
    #432
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It’s more like 200+ hp/tq increase over stock. That was measured at the wheels on a chassis dyno. A stock tundra dynos at 280-320 at the wheels, so this setup is easily over 600 crank hp. FWIW I have basically the same results for around 10k but didn’t have it “professionally” installed. Sure, it’s a lot of money but it’s nothing compared to a new truck.
  13. Oct 18, 2023 at 5:51 PM
    #433
    19PlatinumCrew
    Dave
    Hey Silver17....I didn't have mine PROFESSIONALLY installed either
  14. Oct 18, 2023 at 5:56 PM
    #434
    Silver17
    Eastern PA
    Yes, hence my quotation marks. Unfortunately.
  15. Oct 18, 2023 at 6:03 PM
    #435
    Vizsla
    Vizsla 2 = 2.5
    Doubt it will make you feel any better, but the white mark on the pipe near the factory sensor is more than likely from manufacturing/assembly. Every one I’ve seen had some kind of white paint pen graffiti in that spot.
    Saltyhero13 likes this.
  16. Oct 18, 2023 at 6:14 PM
    #436
    JohnWhicker
    200+ is nice. I think is worth 12K
  17. Oct 18, 2023 at 6:46 PM
    #437
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    574, 537. Belt was slipping at full beans
    Mdl, 19PlatinumCrew[OP], 1UP and 3 others like this.
  18. Oct 18, 2023 at 6:48 PM
    #438
    Saltyhero13
    Was hoping to hear if the TRD intake and stock TB is a restriction with the 80mm pulley or if the wheels and tires account for all the loss.
    Mdl and nobodyintexas like this.
  19. Oct 18, 2023 at 6:49 PM
    #439
    Saltyhero13
    911....I would like to report a murder.
  20. Oct 18, 2023 at 6:52 PM
    #440
    JohnWhicker
    NICE. I may do a SC on my 18 since is outta extended warranty. Still debating
  21. Oct 18, 2023 at 7:15 PM
    #441
    Saltyhero13
    These trucks definitely pull when supercharged. Flat torque across the whole range is amazing for tow/hauling. 0-60 as low as ~4.5s
    reywcms likes this.
  22. Oct 18, 2023 at 7:34 PM
    #442
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Plenty of power to be had with the 5.7 and blower many here are making over that power.
    e30cabrio likes this.
  23. Oct 19, 2023 at 4:39 AM
    #443
    19PlatinumCrew
    Dave
    Seems kinda suspect that there looks to be an x where the sensor should have gone.....doesn't change that it's not installed in the right location
    HulkSmurf14 likes this.
  24. Oct 19, 2023 at 4:40 PM
    #444
    19PlatinumCrew
    Dave
    The local guy took a look at my psb1 sensor location said shouldn't be a problem to move...scheduled for next week then we can see if the gauge was set up or not. I'll keep yall posted......truck seems to be running great
    Mdl and HulkSmurf14 like this.
  25. Oct 21, 2023 at 12:22 PM
    #445
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yeah the angle is good but seems too far down stream.
  26. Oct 21, 2023 at 3:01 PM
    #446
    19PlatinumCrew
    Dave
    Boneheads put it after secondary cats.....directions said after primary factory sensor
  27. Oct 21, 2023 at 3:08 PM
    #447
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wow! Did they read directions? Aem and Innovate say about 18 inches from manifold. Should be right around front of primary cat or a bit closer.
    Some shops will put it further down but I'd like a quicker read.
    snivilous likes this.
  28. Oct 21, 2023 at 3:29 PM
    #448
    19PlatinumCrew
    Dave
    I think since they were upside down on this install get it out a quickly as they could, I have about 300 miles on it and it seems to be running well....time will tell
    JustDSM, VWTim and Mdl[QUOTED] like this.
  29. Oct 23, 2023 at 4:30 AM
    #449
    19PlatinumCrew
    Dave
    Getting ready for our camping trip to Nashville, truck is running well since install...no lights,weird sounds.....fingers crossed. Heading out November 1......will keep yall updated on how it tows.
    JustDSM likes this.
  30. Oct 23, 2023 at 6:25 AM
    #450
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Good luck!!
    what will you be towing?
