General Supercharger Thread
  1. Oct 16, 2023 at 4:32 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine does that all the time. It always come back though. I haven't really bothered to try to figure out what the deal is yet though. My first guess would be that it's the heater circuit. :notsure:
    e30cabrio[QUOTED] likes this.
  2. Oct 16, 2023 at 5:13 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Hopefully it does that, I got it in February, is there a warranty? Need to call Innovate later.
  3. Oct 16, 2023 at 5:28 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Oh great just had one installed, something else to keep an eye on
  4. Oct 16, 2023 at 5:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hmmm, I haven't considered that. I've had mine for much longer, well over a year, so I'd likely be beyond any basic warranty. Mine always eventually displays, sometimes it takes longer than other times.
    snivilous[OP] likes this.
  5. Oct 16, 2023 at 5:53 AM
    e30cabrio
    I let it sit about 10 minutes, got the normal HTR message, then back to the error, I'll see next time I start it up. Need to get the car off the trailer (when the sun comes up) & then dump the trailer.
    Averaged 9mpg, had a few instances where I was going flow of traffic & leaving a reasonable amount of space between me & the car I was behind where an asshat wanted to pass, I was able to say nope & close the gap. The truck really is amazing!
    After it got dark, I turned on the BMWs markers.
    Silver17, Wynnded and HulkSmurf14 like this.
  6. Oct 16, 2023 at 6:35 AM
    nags
    nags New Member
  7. Oct 16, 2023 at 6:36 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes!
  8. Oct 16, 2023 at 6:36 AM
    nags
    nags New Member
    Wish this increased the whine a little but still absolutely none
    Land Bruiser and Black@Blue19 like this.
  9. Oct 16, 2023 at 6:37 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Let us know the boost gain after you drive it a bit, I've got this an an 80 sitting in my garage.
    Land Bruiser and Saltyhero13 like this.
  10. Oct 16, 2023 at 6:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Interesting no increase of whine at idle?
  11. Oct 16, 2023 at 6:39 AM
    nags
    nags New Member
    I had this installed at the same time as the boost gauge so I have no idea what I was making before this, unfortunately.
    HulkSmurf14 likes this.
  12. Oct 16, 2023 at 6:40 AM
    nags
    nags New Member
    When first installing the supercharger it had the absolute slightest whine under boost. Once installing headers I could never hear it again. I noticed no difference with the smaller pulley. I was used to my SC Tacoma before this that screamed like a cat getting raped by a Pitbull.
  13. Oct 16, 2023 at 6:45 AM
    e30cabrio
    Just took the car off the trailer, e8 still :( Hopefully Innovate sends a new one, otherwise, I'll be buying one. Could it have been failing & that was the cause of the odd AFRs?
    Boo
    Wideband O2 sensors are not covered under warranty with Innovate.
  14. Oct 16, 2023 at 7:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine is pretty random. It'll be fine on the first start, and then at some random point during the day on a warm start it won't fire up for a while and I'll notice it at some point during the drive that it's working again.
    Mdl and e30cabrio[QUOTED] like this.
  15. Oct 16, 2023 at 7:17 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just to add to the "knowledge of AFR and gauges" in this badass thread...where, or can we add a link/column to the draggy spreadsheet, is the O2 bung welded in at? Can you all, whose having annoyances with the AFR gauges reading, remind us where you have your bungs welded in at? Which side, approximate locations..
  16. Oct 16, 2023 at 11:23 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Likely just for your wide-band afr readings. Your logs from the narrow band were showing an odd oscillation that @snivilous posted. Did those two coincide?
    The wide band sensors need to be angled 10-15deg up form the 9 or 3 o'clock position depending on what side they are installed to prevent condensation/water build up that cause them to fail.
  17. Oct 16, 2023 at 11:25 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My AEM wide band started reading all over the place. AEM tech said that what they do when they fail. Not sure about Innovate but could be the same. Replaced sensor and back in the game.
    ZPhilip, Wynnded and JustDSM like this.
  18. Oct 16, 2023 at 11:54 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Had no issues towing with the smaller pulley this weekend. This is the hilliest trip we take each year by far. It pulled great as always, lots of glorious sounds coming from under the hood and out the tailpipes. On a lot of the long steep grades I was watching my Throttle position, boost, AFR and IATs. Long sustained uphill pulls I was seeing around 6psi at about 45-55 (degrees?) TPS or roughly half throttle at around 2800-3000 RPM. I also saw typical rich AFRs above 40%TPS, and the highest I saw the IATs level out to by the top of the hills was 50 degrees over ambient. It would be cool to see how the other SCs on the market compare on post IC temps in that particular scenario.
  19. Oct 16, 2023 at 4:52 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Noice. I see this only escalates with the "75 club".
    HonorNotInner and HulkSmurf14 like this.
  20. Oct 16, 2023 at 6:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I looked the first time, I didn't notice that the gauge was indicating "02 E8". When mine isn't indicating it shows "02 HTR".
    And back to the subject of "anomalies", I collected this log on Saturday. Didn't notice a thing until I happened to glance at the screen. I don't really know of a reason to be worried about it though.
  21. Oct 16, 2023 at 6:18 PM
    e30cabrio
    Yup google says fubar sensor
  22. Oct 16, 2023 at 6:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    So it hasn't come back even intermittently at all for you?
    Mdl likes this.
  23. Oct 16, 2023 at 6:24 PM
    e30cabrio
    Nope, E8 all the time (after 30 seconds or so on O2 HTR)
  24. Oct 16, 2023 at 6:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Well, bugger. I guess that now we know if anyone else sees that, it's done.
    Mdl likes this.
  25. Oct 16, 2023 at 7:25 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Im no expert but I wouldn't be worried since the truck is commanding the change and executing it, and a pretty small change in AFR. Though it might be something in the tune causing it? But if it feels fine I wouldn't be too concerned.
    You can probably buy that sensor from a number of places, as I recall it's made from Bosch.
    Mdl and Wynnded[QUOTED] like this.
  26. Oct 16, 2023 at 7:42 PM
    e30cabrio
    Yup, it is 7.5 months old, hoping they will warranty it. Innovate says it's Bosch, sorry. RCA is intervening, said maybe buy another brand.
    Anyone know what will connect to the harness?.
  27. Oct 16, 2023 at 11:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @e30cabrio do you have both valve covers vent to atmosphere? Any issues with that setup?
    Also for wide bands, know AEM is pretty specific to model and year for sensors. Not sure about Innovate.
    reywcms likes this.
  28. Oct 17, 2023 at 2:26 AM
    e30cabrio
    Nope I have a catch can.
  29. Oct 17, 2023 at 5:49 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Re: pinned Trans Thermostat
    I now run hwy temp at 165-170 degrees. I used to run at 192-195.
    call me crazy...I would have never thought it would have made the trans run cooler.
    I thought it would just take longer to heat up.
    live and learn.
    19PlatinumCrew, Mdl, nags and 5 others like this.
  30. Oct 17, 2023 at 6:47 AM
    e30cabrio
    So, asked in ask a Toy Mechanic thread but crickets, anyone know how/if I can reset oil interval in TS?
