2022 tundra 34k miles blown engine
Discussion in '3rd Gen Tundras (2022+)' started by Needanewmotor22, Oct 14, 2023.
  1. Oct 14, 2023 at 6:18 PM
    Needanewmotor22
    Needanewmotor22 [OP] New Member
    22 tundra
    Well we can add another blown up tundra to the grave yard
  2. Oct 14, 2023 at 6:27 PM
    hairychestedfrog, T-Rex266 and Bob like this.
  3. Oct 14, 2023 at 6:38 PM
    Needanewmotor22
    22 tundra
    Have a 2022 tundra limited trd off road was just driving down the road rolling about 45 when what sounded like a machine gun going off inside my motor ... 34,440 miles blown
    ColoradoTJ likes this.
  4. Oct 14, 2023 at 6:39 PM
    Use the link above. Tell us how your truck was used, mods, oil change intervals, etc.
    Tundrastruck91 and T-Rex266 like this.
  5. Oct 14, 2023 at 6:43 PM
    Needanewmotor22
    22 tundra
    Truck was used for a business truck moving trailers from job to job 7,000lb trailer, giving estimate , truck was stock had upgraded air filter lol
  6. Oct 14, 2023 at 6:44 PM
  7. Oct 14, 2023 at 6:45 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Sorry to hear about OP.
    This is becoming more and more common.
  8. Oct 14, 2023 at 6:47 PM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    I hope not . 22-23 sold well over 200 000 Tundras but engine failure is not in Toyotas vocabulary. Definitely concerned.
  9. Oct 14, 2023 at 6:48 PM
    I seen it, just don't want to move it. :rofl:
  10. Oct 14, 2023 at 6:48 PM
    Coal Dragger
    Kung Fu Dick
    Well engine failure is now in Toyota’s vocabulary.
    IEsurfer likes this.
  11. Oct 14, 2023 at 6:49 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Did you do 5k or 10k oil changes? Any other maintenance details?
    Sorry to hear about this. Totally sucks.
  12. Oct 14, 2023 at 6:50 PM
    Oh, I know. Was pointing it out to OP:cool:
  13. Oct 14, 2023 at 6:53 PM
    This is member #25 with a major engine failure.
    IsaiahCanada and NWPirate like this.
  14. Oct 14, 2023 at 7:04 PM
    Needanewmotor22
    22 tundra
    Recommended 10k oil change what I went with
    Tundrastruck91 likes this.
  15. Oct 14, 2023 at 9:54 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Toyota can't fault you there !
  16. Oct 15, 2023 at 3:37 AM
    Needanewmotor22
    22 tundra
    Nope 32 ,765 dollars Toyota has to pay
  17. Oct 15, 2023 at 5:01 AM
    If I was out of warranty and was looking at that cost....
  18. Oct 15, 2023 at 5:05 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Original owner?
  19. Oct 15, 2023 at 5:26 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Ouch. 32.7k vs 9.1k, why so much that is 1/2 the cost of the truck (in most cases). Did more than just the motor fail that caused other issues?
  20. Oct 15, 2023 at 10:22 AM
    Coal Dragger
    Kung Fu Dick
    Well there’s also over 24 hours of labor on the bill too.
  21. Oct 15, 2023 at 10:27 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    the engines are blowing up to parts failure (I believe the bearing) has nothing to do with maintenance
  22. Oct 15, 2023 at 10:38 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    There's also a risk that something may not go right with these upgraded engines, or the shop installing it.
    I decided against replacing engine on my ram 1500 to avoid the risk or replacement not go right (plenty of stories on forums), and then having to throw more good money after bad... But now I have a 22 Tundra which isn't that great either :(
  23. Oct 15, 2023 at 10:47 AM
    BoulderGT3
    Glen
    You should only need a couple of adapters, electronic harnesses and engine mounts to be ready to go. Shouldn't cost more than a couple of $1000 to get it installed and sorted. :)
    Eurodriver[QUOTED] likes this.
  24. Oct 15, 2023 at 10:58 AM
    Coal Dragger
    Kung Fu Dick
    That would leave $$$ left over to put turbski’s on the glorious LS3.
    4genRunner likes this.
  25. Oct 15, 2023 at 11:23 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    What does a brand new 3UR-FE engine go for? Maybe it is time for a real engine swap?
  26. Oct 15, 2023 at 11:24 AM
    I would do it myself. Now there are a few state laws one might have to follow. Emissions could get tricky in some places.
    For you kind sir, look around. Very popular swaps.
    https://www.jjmechanicshop.com/gm-ls-engine-swap.html
  27. Oct 15, 2023 at 11:24 AM
    Not sure on that one. Hell, a used one is 5-7k with some miles on it.
    IsaiahCanada[QUOTED] likes this.
  28. Oct 15, 2023 at 11:25 AM
    IsaiahCanada
    Isaiah
    Calgary, Alberta
    Someone needs to try it.
  29. Oct 15, 2023 at 11:29 AM
    Coal Dragger
    Kung Fu Dick
    Nah I’m not a reflexive NA V8 leg humper.
    I like the idea of a forced induction 6 cylinder, but I have this silly notion they should actually be reliable.
    DMC11 likes this.
  30. Oct 15, 2023 at 11:32 AM
    You got my mind wondering. :rofl:
    So Toyota doesn't to crate engines that I could find. So long blocks are 8300-8600.00 and then you would need to buy all accessories like intake, pulleys, power steering, etc. this would add another couple grand I'm sure.
    Another thing would be looking into adapting any engine to the 10 speed transmission.
