2023 Tundra Oil Change Interval
Discussion in '3rd Gen Tundras (2022+)' started by drcuface, May 24, 2023.
  1. Oct 13, 2023 at 4:57 PM
    #211
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Fantastic. Good benchmark data. Thanks for posting.
    Mattedfred[QUOTED] likes this.
  2. Oct 14, 2023 at 8:14 AM
    #212
    AZBoatHauler
    So.Arizona
    When it’s on sale. Full price online is $39 for 10 quarts. It’s a buck cheaper in the warehouse.
  3. Oct 14, 2023 at 9:24 AM
    #213
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Both Retired Toyota and Nissan Engine engineers said that no matter the oil (Syn or non-Syn) oil, in their vehicles, they change it every 3K miles. That is what I have done so far, using Pennzoil Ultra Platinum Full Synthetic. Some good insight on youtube from Car Care Nut channel and FordBossMe Channel.
    Tundrastruck91 and Rcflyersd like this.
  4. Oct 14, 2023 at 2:52 PM
    #214
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Ted, Thanks again for sharing your lab info. Numbers are looking great and headed in the right direction. Just an fyi, the “Make Up Oil Added” field is the amount of oil you added (if any) since the last change because the engine was low. ie - your engine burns or leaks oil and you have to add some along the way to keep it full. Blackstone uses that amount in their calculations since contaminants would be diluted in more than the 7.7qts the engine usually holds. Looking forward to your future numbers. Thanks again.
  5. Oct 15, 2023 at 4:23 AM
    #215
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I hit 5114 on the odometer yesterday, and was at a crossroads of what to do. I'm a 7/23 build date. I decided to run it to Toyota and have them change the oil. Worth the money for hopefully peace of mind. This 10K interval seems nuts to me. However that's an opinion from old man, not anything scientific. I used to race a Mitsubishi Starion on the strip, and found that the more fluid changes on the engine, the turbo would last longer between rebuilds. Used to even have to change out a turbo oil feed pipe more often than even Mitsubishi suggested on their maintenance schedule. Back then we used to add turbo timers to keep the car running idle after you turned the key off to let everything cool down after hot runs. I guess I'll see if the peace of mind changes actually provide anything down the road.
    Randy B
  6. Oct 15, 2023 at 4:37 AM
    #216
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    I have a 24 with an 8/23 build. I will do the same as you. The older I have gotten the more I value peace of mind. :)
    machd08 likes this.
  7. Nov 11, 2023 at 11:32 AM
    #217
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  8. Nov 11, 2023 at 1:14 PM
    #218
    Markysharky
    Markysharky New Member
    With a twin turbo and 0w-20. I’d change it sooner especially if you tow or run it hard. I’ve been doing it every 5-7k intervals since new. FYI the diff takes close to 5 quarts if you ever change it.
    22whatwedo and Tundrastruck91 like this.
  9. Nov 16, 2023 at 11:12 AM
    #219
    Edwardo
    Edwardo New Member
    2023 Off-road TD Limited
    I had a 2010 Tundra and changed the oil every 5000 Kms. I did the same with my new 23 rather than waiting for the recommended 8000. I am on a trip in the US and when it hit the 8000 mark I contacted a US dealer to have its 1st service done (I wanted to have it done because it is covered free of charge by the dealer — or at least that is what the dealer told me in Canada). When I brought it in all they did was rotate the tires and told me the recommended oil change interval was 10,000 miles! I thought 8000kms was too long but that is like 16,000kms between changes. To me oil is way cheaper than an engine job. I also don’t understand the difference in recommended maintenance between Can/US for the same truck.
    PS. I always use Mobile-1 full synthetic. Not sure what brand the dealer will use and now I am not sure I want to let them touch it either.
  10. Nov 16, 2023 at 7:52 PM
    #220
    PNW Tundra Mike
    Back in So Cal
    I changed the original oil at 2K mi prior to a 3K mi trip. The oil was pretty dark but for initial break in it was expected. Just changed it again at 6K mi, another big trip coming, and again it was pretty dark with only 4K mi on the oil. No heavy loading or towing. I’m sure break-in is still in play. I’ve had clearer oil with 7500mi on it from my Tacoma (thought it was fully broke in) I sent a sample off to Blackstone today from this one.
    *UPDATE - Sample Recd. Happy with results. (Couldn’t add here as an edit. Added further down)
    Mattedfred and AZBoatHauler like this.
  11. Dec 18, 2023 at 6:02 PM
    #221
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I changed my oil at 5K and had to argue with the Service guy. He said, “fine, if you want to be wasteful then we will do it”. I said, “It’s $49.95 with a coupon”. That’s worth extending the life of my truck.
    I don’t get why you have to argue to spend money with these people on a $65K+ investment.
    Kap1, cmiles97 and Mattedfred like this.
  12. Dec 18, 2023 at 6:35 PM
    #222
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    When did a depreciating asset become an investment? Change your oil whenever you want but a vehicle is not an investment. I will stick with the maintenance guidelines Toyota stipulates, I am sure the engineers are smarter than me .
    BossDawg24 and Philipl like this.
  13. Dec 18, 2023 at 6:41 PM
    #223
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    For me, it’s 5k, takes me 20 minutes and gives me the nostalgia of being 10 years old again, changing the oil on my dads 1987 f-150 while he smoked a cigarette and drank beer, carefully supervising.
    the dealership can take their oil changes and shove them right up their you know what.
  14. Dec 18, 2023 at 9:40 PM
    #224
    TundraDan723
    Not every investment has a positive financial return. ;)
    Mattedfred and PNW Tundra Mike like this.
  15. Dec 18, 2023 at 11:16 PM
    #225
    PNW Tundra Mike
    Back in So Cal
    Very informative. Thx or sharing. The Additive Package chemistry is way over my pay grade but a lot made common sense. Interesting to learn OEM oil is from Exxon Mobil
  16. Dec 19, 2023 at 6:34 AM
    #226
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    If they were really making money doing oil changes, they would have to charge double or triple that amount. I think most places do losses on oil or try to break even. This is where the $75 cabin filters come in, upsell, and so on. A small garage with a $100+ oil change is probably going to be a little more upfront and charge the rates they need to charge to keep the doors open and the lights on.
  17. Dec 19, 2023 at 7:15 AM
    #227
    GilFavor
    GilFavor New Member
    according to the guy in the video above…gotta keep the leased vehicle somewhat functioning to get it thru the warranty period…hence free and/or long interval 10k (lol) oil changes
  18. Dec 19, 2023 at 10:46 AM
    #228
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    I had to do the same with a 2021 Toyota Sienna. I remember the older 2nd Gen prius had issues with an inferior head gasket issue at high mileage that would be eliminated or postponed longer with 5k mile oil changes. Those that did the 10k interval had the issue show up sooner, like lower 100k miles range.
    I had to force the service advisor to do it. It was a free one. I guess they want the repairs later or want you to trade it in if problems show up after warranty.
    I was a by the book guy until I bought 2 Ecoboost Fords. The F150 forums were full of examples of issues with their 10k interval and others with high mileage and no issue simply by changing the oil sooner. The oil being used to cool the turbos was my main reason to go against my nature and do oil changes more often. NA motor like this ancient one in my 2018 Tundra will be done later like 7,500 miles depending on how it looks when I check it.
    Tundrastruck91 likes this.
  19. Dec 19, 2023 at 3:31 PM
    #229
    PNW Tundra Mike
    Back in So Cal
    Another interesting video discussing Start/Stop having a positive effect on oil oxidation. I’m curious, never heard of Speediagnostix Lab. Blackstone has been around a long time and I’m very familiar with them. Anyone have Pros/Cons of one over the other?
  20. Dec 19, 2023 at 4:37 PM
    #230
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    The wear and tear on the engine and the starter/battery probably isn’t worth it. Change the oil every 5k and have the auto stop start disabled. You’ll get best of both worlds
  21. Dec 19, 2023 at 9:55 PM
    #231
    HLR_NM
    HLR_NM New Member
    Harry
    The sump holds almost 8 quarts of oil.
    The turbos are water cooled.
    10k OCIs work for me.
    Woocawachie likes this.
  22. Dec 22, 2023 at 5:06 PM
    #232
    Tundrastruck91
    Eh, AMD the car care nut knows better and no reason to lie unlike a big corporation needing to sell future units.
  23. Dec 28, 2023 at 9:32 AM
    #233
    PNW Tundra Mike
    Back in So Cal
    My first Blackstone Labs report @ 5725mi. First change was at 2K mi but I didn’t sample that one.
    Dealer will be doing the next at 10K
    Mattedfred and Tundrastruck91 like this.
  24. Dec 28, 2023 at 9:43 AM
    #234
    PNW Tundra Mike
    Back in So Cal
    My research found these turbos are still oil cooled like all others but this new block has water cooling jackets around the exhaust ports ahead of the turbos cooling the exhaust flow headed in.
    HLR_NM[QUOTED] and GilFavor like this.
  25. Dec 28, 2023 at 9:53 AM
    #235
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    Future sales... meh.... more like ever tightening EPA regulations driving manufacturers oil change, and other "hazardous" to the environment waste products, intervals
  26. Dec 28, 2023 at 1:29 PM
    #236
    OLV1071571
    The comments in the report bring me comfort regarding my post about fine metal in my oil. Thanks for posting.
  27. Dec 28, 2023 at 3:30 PM
    #237
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    I would send your oil in. I don't think you should be seeing that much forbidden glitter on the first drain in my opinion.
  28. Dec 28, 2023 at 6:13 PM
    #238
    Tundrastruck91
    Glad we can all agree the 10k oci is not optimal.
    edit; sure mask wearer's won't notice
    Hank Hill, TundraDan723 and GilFavor like this.
  29. Dec 29, 2023 at 6:15 PM
    #239
    HLR_NM
    HLR_NM New Member
    Harry
    :boink:
    Y'all remind me of my buddy who insisted on a fresh sump of Royal Purple every 3K in his diesel 6.2L F250 :rofl: There's keeping up on maintenance - and then there's just wasting money.
    If Toyota's engineers specify 10K then I'm going to take that as acceptable - and I will run shorter intervals for severe duty like dirt, towing etc. There's almost 8 quarts of full synthetic in the sump and there is no reason to dump it before it shears out of spec as long as the filter is doing its job.
    FWIW I had my first OC ~7K and didn't bother with an analysis. I'll take a sample at the next OC, probably around 15K, and share with the collective. If shorter OCIs are indicated by the science, well then I'll eat my hat. Or my mask...
    Nm6300'asl likes this.
  30. Dec 29, 2023 at 9:15 PM
    #240
    AZBoatHauler
    So.Arizona
    Have you seen the oil analysis reports showing 2% fuel dilution in 1500 miles?
    Rcflyersd likes this.
