General Supercharger Thread
  1. Oct 13, 2023 at 5:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Cruise Control might contribute to this as well, I know that mine can be kind of aggressive in it's efforts to maintain speed...
    nobodyintexas likes this.
  2. Oct 13, 2023 at 6:04 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Does the AFR from the factory o2 sensors w/obd2 show full rich (11.9) when this is happening?
  3. Oct 13, 2023 at 6:21 AM
    nags
    nags New Member
    Learned this the hard way. After bricking my ECU.
    reywcms likes this.
  4. Oct 13, 2023 at 6:51 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I don't know, until last week the Innovate was reporting to HPT, I had to use Logworks yesterday.
  5. Oct 13, 2023 at 7:43 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    This is all I have to go off of for being weird, this is a 30 second strip and as you can see minimal TPS change (enrichment isn't set until ~35% TPS), no shifts during this time, but AFR is swinging wildly from one side to another. Way beyond the normal bouncing around. The big humps on the left and far right are the truck switching between Closed Loop and Open Loop for some reason, the middle ground is Closed Loop the whole time including the "smaller" spikes.
  6. Oct 13, 2023 at 8:25 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, nothing really jumps out to my eye. I'd like to get something like that layout setup so I could get a log of what mine is doing for a possible comparison, More data.
  7. Oct 13, 2023 at 8:38 AM
    e30cabrio
    47 miles into LA TRIP has not happened
    Wynnded likes this.
  8. Oct 13, 2023 at 8:39 AM
    snivilous
    SW UT
    I just sent the layout over.
    Wynnded[QUOTED] likes this.
  9. Oct 13, 2023 at 9:02 AM
    Vizsla
    Vizsla 2 = 2.5
    Maybe a misfire is activating COT? Have no idea if that’s even possible without setting a code.
  10. Oct 13, 2023 at 9:05 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    The more I read, the more I question the reliability when getting an extra 230-250hp out of these engines.
    Is the standard 160-180hp gain that you used to get from the dealer (called stage 1 by some shops) typically problem free?
  11. Oct 13, 2023 at 10:44 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    My setup can be considered "standard". I'm right at 200hp gain.
    it's trouble free.
    nags, 19PlatinumCrew, Mdl and 2 others like this.
  12. Oct 13, 2023 at 11:39 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Zero issues here and im sure im pushing close to at least 630 crank
  13. Oct 13, 2023 at 12:33 PM
    1UP
    1UP Truck Gang
    Lol, meant more of an install and forget about it.
    For you sir and a few others in here. Yall tinker, upgrade parts, replace bad parts,, upgrade tunes, gold plate sheeeet....
    I have to create a calendar appointment to cut my own grass. I was just worried about the follow on attention required with this mod, and it appears that the +200hp crowd spend more time with stuff than the sub 200hp crowd.
    Would that be a fair assessment?
    HulkSmurf14 and reywcms[QUOTED] like this.
  14. Oct 13, 2023 at 12:37 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes
    HulkSmurf14, Mdl and Wynnded like this.
  15. Oct 13, 2023 at 12:46 PM
    Silver17
    Eastern PA
    Same! Probably in the 220+ over stock range but. No dyno to verify it unfortunately. Not much inherent difference, either way you’re getting a new fuel pump, injectors and a tune. It’s just a matter of sizing them appropriately at that point, and going with the most “drop in” options available helps reliability wise IMO like the DW 650 injectors and the DW 300C pump for a reliable setup. Aside from getting closer to the max power limits of the engine, “stage1” isn’t really more reliable than “stage 2” by any metric.
  16. Oct 13, 2023 at 12:55 PM
    snivilous
    SW UT
    If the guys doing the work don't suck and the tune is good I think it's about as reliable as anything else.
    But I might be biased since my truck works. I also have one of the least modified trucks in this group (as well as an early year so no issues with ethanol shit), I just upped the boost and called it good.
  17. Oct 13, 2023 at 2:23 PM
    snivilous
    SW UT
    I was just thinking, even if you don't have a wideband there should be a calculation from datalogging injector duty cycle or pulsewidth to approximate AFR. I'll have to put some brain power into that later, off the top of my head it'd cylinder volume divided by fuel injected, which is flow rate times pulsewidth?
    Mdl and reywcms like this.
  18. Oct 13, 2023 at 3:07 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Call me a simpleton, but have you checked to make sure O2 sensor is tight and all wiring connections?
  19. Oct 13, 2023 at 7:35 PM
    e30cabrio
    Nope all tight.
    400 miles to LA. Oddity never happened. In stop and go taking off it went to 9.x then right to 14x
    Gaaa none of the 9s are legible.
    That's where it happened on the 10 West.
  20. Oct 13, 2023 at 10:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @e30cabrio safe to assume using Denso O2's? Have you tried re-writting the tune. Seems the ecu is trying to compensate for something awry based on @snivilous post of the jumping from open to closed loop on both o2's. It's a head scratcher for sure.
    snivilous[OP] likes this.
  21. Oct 14, 2023 at 2:35 AM
    e30cabrio
    O2s are original. Outside looking at them I have no interaction. I think the one that came with the Innovate is Bosch but I'm not sure.
    Mdl likes this.
  22. Oct 14, 2023 at 3:01 AM
    e30cabrio
    Picked up the BMW about 1:30, had an 80 mile drive that took almost 3 hours thanks to a bad crash & typical L.A. traffic. Car was a champ, runs great & no issues until when we got to the hotel with it's 5'10" underground parking that my 6'3" Sequoia driven by my wife got stuck in. When I tried to back out I ripped a sprinkler head out. Big fun.
  23. Oct 14, 2023 at 4:57 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  24. Oct 14, 2023 at 5:03 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Between my Supercharger install bad luck and yours I don't think we should be in the same room
  25. Oct 14, 2023 at 5:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, it sounds like it's going to be a tricky one to figure out with it appearing to be intermittent. If it becomes reproducible at will, that will help a great deal.
    I've had a few oddities as well:
    1. My SAIS bypass harness going out of spec (solved).
    2. My starting issue with the FiveO 750s being dirty out of the box (solved).
    3. Strange rpm hunting while coasting at low speed. (current)
    The first two being components unrelated to the tune, and the third possibly the same or may be tune related.
  26. Oct 14, 2023 at 6:53 AM
    HulkSmurf14
    2014 Tundra Limited
    The weird thing is, MANY auto trans autos have an issue between 30-45mph...there's always rpm hunting there...whether Audi, Toyota, Chevy, etc...that's a transmission variable that can be helped by torque converter lockout tuning, with either a valve body upgrades like TransGo Jr or IPT updates. The RPM hunting is greatly improved/reduced by such... I'm not certain tunng can fix it alone though...at least my experience with D2 S8s, LBZ-era duramaxes and 7.3 fords...but these were all older tech compared to our trucks...same thing happens in mine so I lock a gear or drive to 46mph to eliminate the nuance...
  27. Oct 14, 2023 at 7:10 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine has recently appeared, right after I got rid of the dirty injectors. I should say that it's more rpm related than speed. It's in the 700-1500 rpm range, in any gear. There was a suggestion that it was in the Flex Lock tuning of the tune, but it's the same as stock, and I'm not able to disable Flex Lock. That suggests that it's something else, I just need more time. I have an idea, but have to wait a while before I can see if I'm in the ballpark.
  28. Oct 14, 2023 at 7:17 AM
    e30cabrio
    Another oddity, Normally for these trips I put it in 2WD (thinking less gas) no, I forgot and got the same mileage.
    The tree has never gotten "good" mileage (my '10 CM Tundra (2WD) got 15/17)
    If this is my only issue so be it. the truck runs like a dream. I embarrassed a '24 760 BMW repeatedly on the freeway yesterday. He expected to walk all over me, NOPE. I kept him at bay & ran away from him repeatedly!
    (I'm shocked too) lol
    mustang67408, V10Ace, Mdl and 4 others like this.
  29. Oct 14, 2023 at 7:20 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :rofl:Well, I might have an idea about the difference in your mileage....
  30. Oct 14, 2023 at 7:29 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I forgot about the howling when I initially changed from the 2.3 pulley to the 2.0, which has not returned I'm happy to relay.:muscleflexing:
