Tips for bedlining Leer topper / suspension questions
Discussion in '2nd Gen Tundras (2007-2013)' started by kanger328, Oct 12, 2023.
  1. Oct 12, 2023 at 10:03 PM
    kanger328
    kanger328 [OP] New Member
    Anchorage, Alaska
    2012 DC 4x4
    So I finally found a used mid-rise topper for my '12 DC. It's the Leer 180. I bought the Raptor Liner kit and am planning to bedline the topper to color match my truck. Hoping some of you have experience with this to answer a few questions. I already google searched and looked up youtube, but still have a few questions.
    1) If I remove all the windows, then spray it, will the windows be difficult to fit back into place? I'm wondering if the windows won't seal as well if I go this route.
    2) Planning to add rooftop tracks for a rack. Should I drill the holes before I bedline or would it not be a big difference to drill after?
    3) I'm considering spraying with black paint instead of the bedliner. I already have an air compressor to paint. Opinions on paint vs bedline?
    Now a request for suspension tips. I have the Bilstein 6112 up front set to 1.9" lift. Rears have Bilstein 5160s with stock leafs. I have a wooden drawer system in the bed along with the topper. With the weight, my rear sags about an inch or so. Considering 1"-1.5" blocks or a shackle. Wondering if I should also add an expansion pack for better weight support?
  2. Oct 13, 2023 at 6:30 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    Look into the RAS Road Active Suspension. Should solve your issues. I just added a topper a couple months ago. This is what I am leaning towards. 2 levels - Standard Duty $539 and Heavy Duty $589. Standard Duty lifts your rear an inch and a half. Heavy Duty is 2 to 3 inches.
    www.activesuspension.com
    kanger328[OP] and 2mchfun like this.
  3. Oct 13, 2023 at 7:01 AM
    2mchfun
    Another vote for RAS HD kit. Unless of course you have the funds to go the right way and grab some aftermarket leaf packs. I did both and the results are phonomenal, but also costly. Very minimal sag and the headlights are in focus with literally a ton of cargo in my truck. As for the camper, you could mask the window sealing lines. Just use a body pen to draw around them before removing them. Mask down to the line, paint the sealing area black. Wait for cure. Mask the newly painted black sealing area. Then shoot the rest. You'll have black sealing areas that will blend in with the seals and it'll look decent.
    kanger328[OP] likes this.
  4. Oct 13, 2023 at 7:15 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    With the stock leafs I went with +1 shackles and it sits level with the front, which is 5100 in +1.5" setting.
    When I load it up for wilderness trip, it sags quite a bit in back. I'm considering Dobinson leafs.
    If you plan to have a dry topper then don't drill it.
    This style of cap actually looks nice and matching to your gen2 curvy lines.
  5. Oct 14, 2023 at 12:17 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Check out the Line-x dealer in your area. I was quoted $500 for them to cover the cab roof on my 07 SR5 crew cab. They can color match too...they said. The hard part of painting a topper like that is LOTS of prep labor, to get it decent looking...and then the sun & UV rays get to it anyway. It will only take 3.5 to 4 hours for my cab roof...start to finish, and they apparently heat their product before applying.
  6. Oct 16, 2023 at 2:14 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Plastic dip the wheels red. Then everything will match.
    kanger328[OP] and 831mic like this.
  7. Oct 16, 2023 at 2:47 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Durabek has custom colors and can be rolled on. Really good results. I'd leave the windows on and just tape them. Pull tape after 2nd coat of liner when still wet. Stuff is great.
    https://www.durabakcompany.com/collections/bed-liner
    bedliner is rough textured. You can also get a smooth textured one.
  8. Oct 16, 2023 at 6:31 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    I got a quote for professional bedliner job for $800. The market sucks up her in Alaska. Decided to bedline myself with the windows still on. Not worth the hassle of taking them out.
    Suspension I'm still deciding. Will probably go with add-a-leafs. Thanks for the responses.
  9. Oct 16, 2023 at 6:43 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    I just sprayed some raptor liner on my 07 bed and it was VERY forgiving to spray. First coat I used higher pressure like 60psi and it had a smoother texture (great for one coat on bedrails and probably on a cap) then turned it back to 35 psi and a longer spray distance for a rough bed liner texture on next two coats on bed floor. It coated so easily, no streaking once dry, easier than rattle can spray paint. And it hardened super tough in a couple hours although it says 72hrs to cure before getting wet. I would easily use this product again to spray other project.
    I used a degreaser and a garden hose for initial strip, then used a dura-gold abrasive nylon cup brush on a harbor freight polisher to prep the old bed liner, paint, and metal. Then cleaned with degreaser and pressure washer, then final alcohol wipe down. A quick spray with UPOL adhesion promotor. And finally the raptor liner. First coat on 8ft bed and rails took less than 25 mins to spray. I used 6qts total for a heavy coating all over.
  10. Oct 17, 2023 at 11:49 AM
    Trdripper
    Trdripper New Member
    Bronze 2nd Gen
    King 3.0 front Coilovers with TC UCA King 3.0 rear Bypass shocks
    On the suspension part I would say a 1 inch block or even an ADD a leaf would be helpful in itself. Super easy install and will give you a tad more functional support
    kanger328[QUOTED][OP] likes this.
  11. Oct 17, 2023 at 5:44 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    That's very helpful info. Think the adhesion promotor is necessary for a topper? From the vids I've seen, doesn't look like people use it for toppers.
    Yeah, I'm now just thinking about doing a simple block. Maybe in a year or 2 do a complete suspension overhaul.
  12. Oct 17, 2023 at 5:49 PM
    Trdripper
    Bronze 2nd Gen
    Good call. I have some aluminum lifting blocks and hardware laying around for a rear lift. I was gonna do that same thing to offset my rear being lower than the front but I went ahead and put on some kings haha
  13. Oct 17, 2023 at 8:48 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    If you're going to go the bed liner route, have you considered doing the front and rear bumpers to match while your at it?
    As far as your lift options I've always been a fan of add a leaf over blocks/spacers. Provides better overall value without going all out on kings or the like.
  14. Oct 17, 2023 at 9:04 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Twinkies!
    After a couple days the color quit bugging me.
    OldGuy03 and kanger328[OP] like this.
  15. Oct 18, 2023 at 6:45 AM
    blackoutt
    Indy
    OEM+
    Probably not as long as you can easily scuff everywhere that's getting painted to give the liner something to stick to. Probably most concerned around windows. But for the $20 I figured I'd unload a whole can on the inside corners of the bed and bed rails as long as I was doing it!
  16. Oct 18, 2023 at 11:14 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    ^^^this
    any painting project requires proper preparation. The prep you put into it will directly correlate to the results. Kinda like this 7 P's rule.
    proper
    prior
    planning
    prevents
    piss
    poor
    performance
    kanger328[OP] and KNABORES like this.
  17. Oct 18, 2023 at 3:32 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    That escalated quickly, lol.
    Yeah, I'm considering spraying the bumpers too. I'm guessing the metal bumpers would need an adhesion primer for the bedliner to stick well. I did find some Hooke Road front and rear bumpers that look pretty good, but they don't ship to Alaska...
  18. Oct 22, 2023 at 10:13 PM
    Optic15
    Optic15 New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    I used to have an ‘03 ranger xlt that I rhino lined the whole truck. Came out nice and was definitely a neck breaker lol would I recommend painting even just a camper shell let alone a whole truck? Not really, unless you’re looking to really thrash it hauling material or off roading.
  19. Nov 21, 2023 at 5:56 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    RAS Road Active Suspension just posted their Black Friday Sale yesterday. Glad I waited, I saved over $100 and free shipping.
