  1. Oct 11, 2023 at 7:40 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Whatcha' drinkin'... :boink:
    CaptRussia253[QUOTED] likes this.
  2. Oct 11, 2023 at 7:51 PM
    coTony
    Tony
    Montrose, CO
    Another Circuit from the SwithPro would be just fine.
  3. Oct 11, 2023 at 7:52 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Checked.
    The issue I am having is with TWO of the 20A (single wire) circuits. I've got the BD S8 30" hooked into one circuit (12A load) - Switch 2 to be exact. Currently I'm running the backlighting on the S8 on one of the switches that keeps tripping out with the lightbar load. And if I turn down the current setting to 15A on circuit 2, it will trip out instantly as well.
    If I run a multi-meter inline with it and measure amperage, I am seeing the following:
    Truck OFF (no ignition or engine)
    • Light running directly probing the battery –11.9A power draw(this is in line with the MFGR data stating 12A)
    Truck OFF using Switch Pro app to turn on and off
    • Switch 1 – light remains on –10.8-11.1A power draw
    • Switch 2 – light remains on –10.8-11.1A power draw
    • Switch 3 – light remains on –10.8-11.1A power draw
    • Switch 4 – light remains on –10.8-11.1A power draw
    Truck ENGINE ON (still using Switch Pro app to tun on and off)
    • Switch 1 – light shuts off almost instantly with three flashes -12.5-13.5A power draw
    • Switch 2 – light remains on –12.2-12.8A power draw
    • Switch 3 – light remains on –12.2-13.2A power draw
    • Switch 4 – light shuts off almost instantly with three flashes –12.3-13.5A power draw
    I really need to make the time to reach out to their tech guy and try to troubleshoot it.
    RobertD likes this.
  4. Oct 11, 2023 at 8:03 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are you saying you’re running the backlight AND the light bar load at same time? I think I’ve seen from @TundraPHX that the light bar no likey. He was having weird flicker issues on his bar with his SPOD.
  5. Oct 11, 2023 at 8:05 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Hahaha nailed it
  6. Oct 11, 2023 at 8:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I've had no issues there at all. I have the backlight tied into switch 4 and set to run at power on.
    but all of this testing is with the backlight disconnected. Actually, EVERYTHING disconnected except the single hot lead for the S8.
    TRDFerguson[QUOTED] likes this.
  7. Oct 11, 2023 at 8:17 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I love red wine haha
  8. Oct 11, 2023 at 8:38 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Correct, just black matte paint for the rims but yes in that picture doesn't look like that. Here are other pictures with different angles and exposures.
  9. Oct 11, 2023 at 8:39 PM
    bobbilly
    bobbilly New Member
    Weird thing is, doesn't matter which switch I turn on. I only have 2 connected to a light currently but even if I turn on a blank it flashes. I will try when I get a moment to get under the hood.
    Do your circuits ever come back or function?
  10. Oct 11, 2023 at 8:41 PM
    RainMan_PNW
    Casey
    Clark County, WA
    the two that will trip with the S8 light bar and the engine running will work fine if I turn the engine back off. And they work fine if I plug the backlight into that circuit.
    bobbilly[QUOTED] likes this.
  11. Oct 11, 2023 at 10:35 PM
    Welcome from NY.
  12. Oct 12, 2023 at 3:41 AM
    Bergy24
    Bergy24 New Member
    Do you remember if you ordered the smaller or bigger wheel lock cover?
  13. Oct 12, 2023 at 3:43 AM
    biebs96
    PA
    If they are OEM wheel locks, order the smaller cover. One size down.
    bulldog93 likes this.
  14. Oct 12, 2023 at 3:45 AM
    Bergy24
    Bergy24 New Member
    Are you 100% positive?
    I am seeing conflicting info.
  15. Oct 12, 2023 at 5:28 AM
    biebs96
    PA
    Yes.
  16. Oct 12, 2023 at 6:02 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    20% windshield tint. cant see through the cab! :rofl:
  17. Oct 12, 2023 at 8:53 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @RainMan_PNW,
    I just wanted to make sure that you're not having issues with the S8. Have you done a bench test on the bar to make sure everything is working as it should? If you notice any sort of issue with the unit please feel free to reach out and we can help diagnose the issue further. Here are the specs as well for our S8 30" just in case you may need it.
    https://www.bajadesigns.com/products/s8-straight-led-light-bar/
    Amperage Rating (A) 12.0
    Wattage (W) 180
    Back Light for a 30" S8 will pull
    1.2 (A)
    Best,
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.comPhone: (760)560-2252
    Wallygator, 1UP, bulldog93 and 3 others like this.
  18. Oct 12, 2023 at 9:24 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Did you ground your SP directly to the battery? For some reason (and I’m not trying to call you out here), I vaguely remember thinking “Casey didn’t ground his SP to the battery and did bus bar instead (*tisk *tisk)” when I was looking at your install photos. But given how much smarter you are with 12v than me I just went :notsure:
    you also could have grounded it correctly and I just missed it :rofl:
    Wallygator and bulldog93 like this.
  19. Oct 12, 2023 at 9:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I recently had an issue on mine randomly not working. Sent it in and apparently had corrosion in the pins. Great customer service and warranted my whole setup. Shoot them an email
  20. Oct 12, 2023 at 9:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    As far as I've been able to tell, the S8 is fine. I get 11.9 amps when it's pulling directly off the battery (run in series through the multimeter). The backlight is on a separate circuit on the switch pro and it works fine on the "problem circuits"
    It is grounded directly to the battery. I did originally run it to the BlueSea bus bar, but to ensure there were no "it's not installed per the instructions" issues, I ran it directly to the SDHQ battery block.
  21. Oct 12, 2023 at 9:43 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Well if anyone is ever on the fence about who's lights to run, this is a very clear message about the level of support to expect from BD. I run some of their lights on my Husqvarna and KTM motos and love them!!!!
    Wallygator, 1UP, kingpin3919 and 4 others like this.
  22. Oct 12, 2023 at 9:51 AM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I like it. Thanks for the pics. I am also thinking of tossing my wireless tray. Thing turns red all the time, don't charge and your right is seemingly useless.
    bulldog93 and nasher75[QUOTED] like this.
  23. Oct 12, 2023 at 10:54 AM
    Baja Designs
    San Marcos, CA
    Hey @nasher75,
    Thanks for rocking with Baja Designs! We really appreciate all the support the community gives us. As riding season is coming up I hope you get some solid rides in! Would love to see some photos of the epic rides you find yourself on.
    Best,
  24. Oct 12, 2023 at 11:02 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Dude, those rims are beautiful! Excellent choice on the MGM.
  25. Oct 12, 2023 at 11:56 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Planning a trip out to Death Valley over Thanksgiving so hopefully the weather holds out.
    Baja Designs[QUOTED] and reywcms like this.
  26. Oct 12, 2023 at 1:38 PM
    Baja Designs
    San Marcos, CA
    Hey @nasher75
    That sounds like a rad trip! I've been out to Death Valley once and it's definitely on my list to revisit here soon!
    Best,
    kingpin3919 likes this.
  27. Oct 12, 2023 at 2:03 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Promise this will be the last hijack... From spring 2023 in Death Valley.
  28. Oct 12, 2023 at 2:10 PM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Finally built my other platform so now my “modular camper/storage” setup is near complete. Throw on a 3” egg crate & my 2 boys or I (solo) can sleep nice and cozy. The plywood I used is light enough to lift up for access of deep items underneath. Drawers are heavy and time consuming to build. I’m stoked on this for now.
  29. Oct 12, 2023 at 2:23 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Hopefully they're able to get the park open by then, it's still under full closure.
    nasher75[QUOTED] likes this.
  30. Oct 12, 2023 at 2:43 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Quoting myself here. I've had this cork shift knob installed for a few weeks now. 20231012_162745.jpg
    I've had it stained, didn't like it, sanded it down. Clear coated, nope, sanded it down. Jacked up the trim on the base *shit*
    Here's the problem: It's never cold or hot to the touch. It's comfortable in the hand, super solid., and just doesn't LOOK right
    Maybe Ill just make cup holder inserts/trim pieces from the same and see if it blends in better.
