Windows don’t go down
Discussion in '1st Gen Tundras (2000-2006)' started by Frnco, Oct 4, 2023.
  1. Oct 4, 2023 at 2:32 PM
    Frnco
    Frnco [OP] New Member
    Hello, I was wondering if you guys knew why my back 2 windows and the back glass don’t go down anymore, only the driver window and passenger one go down. I put power on the motor and it worked and if I press on switch it just makes a clicking noise. TIA.
    It’s a 2004 tundra sr5
  2. Oct 4, 2023 at 4:41 PM
    shifty` Animals and insects don't do drugs
    Does the passenger window go up/down? And you confirmed you didn't accidentally tap the window-control-lockout button on the driver side (pic)? It's the square button on the driver's control only, and easy to tap by mistake.
    Has anyone been inside any of the door panels recently, like to change speakers or replace handles or anything?
    EDIT: If you haven't had any door panels off recently and there's no fuses blown, and the lockout button isn't set, you may want to heed this thread: https://www.tundras.com/threads/interior-electrical-issues-‘06-dc.122071/
    Frnco[OP] likes this.
  3. Oct 11, 2023 at 12:38 PM
    Frnco
    Hello, thank you for the suggestions, but no the window lock out button is not pressed, and yes the front passenger window does go up and down as well as the main driver, it is just the back 2 windows and the back glass that do not go down only making switch sound, ive gone over the thread you linked and the box has no signs of it being corroded.
  4. Oct 11, 2023 at 2:21 PM
    Has anyone been inside any of your doors lately, or have you had any door controls out?
    I'd need to look in the EWDs to check whether or not those three circuits are linked in some way. Or I guess you could. Links to the EWD (elec. wiring diagram) are in this thread near the top: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
  5. Oct 11, 2023 at 4:22 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Do the 2 rear windows go up/down with their respective switches ?
    The sound you hear, is that sound happening when you're attempting the 2 rear windows or back window.
    Which window motor were you testing that worked ?
    The 2 rear windows and the back window are somewhat separate systems electrically, meaning if driver main switch was the culprit, it should not affect the back window.
