1st Gen PSA: Clean your battery terminals, you lazy sods
Discussion in '1st Gen Tundras (2000-2006)' started by shifty`, Oct 8, 2023.
  1. Oct 9, 2023 at 10:47 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Yes its better to replace the cables as well. I had a no start issue on my 07 Tundra. I thought it was related to starter. I even bought the original OEM starter to replace. But the issue used to happen intermittently. I observed that my battery cables were in bad shape. i.e. light green in color going into the wire sleeve. After some mulling around. I thought f-it let me replace the battery terminals..when I dug into it I found at least 4-5 inches of light green stuff on my cable. Thats where I said to myself I have to replace this cable.. so let me do it right.. which is why I got the correct equipment to properly fix the battery terminal. I spliced the wire with new wire and waterproof heatshrink. Never had a problem with starting again. My new starter will sit on the shelf for another day.
    txagg[QUOTED] likes this.
  2. Oct 9, 2023 at 11:59 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  3. Oct 9, 2023 at 12:05 PM
    bmf4069, NWPirate, baraynavab and 3 others like this.
  4. Oct 9, 2023 at 12:08 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
  5. Oct 9, 2023 at 12:09 PM
  6. Oct 9, 2023 at 1:43 PM
    baraynavab
    Atlanta
    txagg and DJenerated like this.
  7. Oct 10, 2023 at 10:45 AM
    @shifty` I'm offended you didn't call us lazy sods.
  8. Oct 10, 2023 at 10:55 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
  9. Oct 10, 2023 at 1:12 PM
    shifty` [OP] Like Fred Flintstone, drivin around with bald feet
    Fixed.
    bmf4069[QUOTED] and FrenchToasty like this.
