The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    27.6%
  2. Alpine ILX-F509
    3 vote(s)
    2.4%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.6%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.6%
  7. No - I was late to the party
    52 vote(s)
    40.9%
  8. No - I didn't need a new head unit
    19 vote(s)
    15.0%
Multiple votes are allowed.
  1. Oct 7, 2023 at 5:55 PM
    #721
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  2. Oct 8, 2023 at 6:10 PM
    #722
    TaquitoBandito
    Joel (AKA Bif)
    Kenwood DMX1037s is installed (I did have to contact @RainMan_PNW 911 a few times just to make sure I was hooking up the front cameras right).
    I got distracted and forget to attach the damn idatalink wire and when I was shoving everything to the sides I disconnected the backup camera. Of course I buttoned everything up and then checked. :) Took some searching but I found the missing cable and reattached the backup camera. So far so good.
    I also installed my wife's front camera on her 4runner and have everything already wired up for the Tundra and will take care of it when I get my shim.
    Something that is cool on the Kenwood is the backup camera lines turn with the wheels. I need to read the instructions but is there a why to turn off the OEM lines?
  3. Oct 8, 2023 at 6:21 PM
    #723
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    unfortunately, you're stuck with the OEM lines that I know of.
    On the alpine, you can adjust the aftermarket ones to line up with the OEM ones, but they also don't turn.
  4. Oct 8, 2023 at 7:48 PM
    #724
    TaquitoBandito
    Joel (AKA Bif)
    @BiggHertz - wondering if you can help since you are a Kenwood guy. The call volume is super low on the Kenwood I installed. It sounds like it's only coming from the center speaker and even at level 40, it's a little low. Am I missing a setting somewhere?
  5. Oct 8, 2023 at 7:55 PM
    #725
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    bluetooth or wired connection from phone to the headunit?
  6. Oct 8, 2023 at 8:00 PM
    #726
    TaquitoBandito
    Joel (AKA Bif)
    Bluetooth Apple CarPlay
  7. Oct 8, 2023 at 8:05 PM
    #727
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    When connected via bluetooth, be sure to turn up the volume on your cellphone.
    TaquitoBandito likes this.
  8. Oct 8, 2023 at 8:07 PM
    #728
    TaquitoBandito
    Joel (AKA Bif)
    I did that. Still sounds like a whisper
  9. Oct 8, 2023 at 8:10 PM
    #729
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  10. Oct 8, 2023 at 8:11 PM
    #730
    Azblue
    The Dirty T ( ^_^)_且
    Try 41
  11. Oct 8, 2023 at 8:12 PM
    #731
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Strange.
    I don’t even have a center channel and don’t have any issues…
  12. Oct 8, 2023 at 8:14 PM
    #732
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Maestro programming, maybe? I know some that use a DSP off the JBL have weird channel issues with some CarPlay functions, though I don’t remember the specifics.
    TaquitoBandito and bulldog93 like this.
  13. Oct 8, 2023 at 8:19 PM
    #733
    TaquitoBandito
    Joel (AKA Bif)
    The front door speakers sound really muddled. I'm wondering if I pulled the RF & LF a little when I pulled it out the 2nd time and missed it.
    TRDFerguson[QUOTED] likes this.
  14. Oct 8, 2023 at 8:22 PM
    #734
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’d recommend the @Fotnot approach: Never pull out.
  15. Oct 8, 2023 at 8:22 PM
    #735
    TaquitoBandito
    Joel (AKA Bif)
    I never want to.. :oops:
  16. Oct 8, 2023 at 8:23 PM
    #736
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  17. Oct 8, 2023 at 8:23 PM
    #737
    TaquitoBandito
    Joel (AKA Bif)
    Thinking about it and I did make a call on it before I pulled it the second time and I don't remember it being quiet. I bet I pulled the RF & LF. :mad:
    TRDFerguson likes this.
  18. Oct 8, 2023 at 8:26 PM
    #738
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If I had a nickel for every time I disconnected the mic when I pulled out my old Pioneer… I eventually started to test major functions before bolting everything in. Usually. (Okay, almost never)
  19. Oct 8, 2023 at 8:30 PM
    #739
    TaquitoBandito
    Joel (AKA Bif)
    I'm getting really good at pulling my dash apart.
    WFD473 and TRDFerguson[QUOTED] like this.
  20. Oct 8, 2023 at 8:58 PM
    #740
    RainMan_PNW
    Casey
    Clark County, WA
    Technically, wireless CarPlay isn’t Bluetooth.
    It uses BT to negotiate the initial connection and then it uses wifi for the actual connection/stream.
    when connected via CarPlay, none of the phone buttons will do shit for volume.
    siri is also a bit of a bitch to get set up just right - her volume is tough to set over CarPlay without turning it up or down while she’s talking.
    are there any gain or volume settings in the HU for phone calls? Seems like the alpine had something for those in it, but I’ve already forgotten.
    bulldog93 likes this.
  21. Oct 9, 2023 at 6:04 AM
    #741
    wackyhacky
    wackyhacky New Member
    Keith
    Berthoud, CO
    2020 Limited Double Cab
    On the Alpines, you can also just turn off their lines so you only see the OEM ones. I figured this out after trying to adjust the aftermarket lines to line up with the OEM. lol...
  22. Oct 9, 2023 at 6:05 AM
    #742
    RainMan_PNW
    Casey
    Clark County, WA
    I haven’t been able to find that setting
  23. Oct 9, 2023 at 6:11 AM
    #743
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You have to do it while in camera mode, not in the settings menu. Tap the screen while you have the cam up and you can change it.
  24. Oct 9, 2023 at 6:13 AM
    #744
    RainMan_PNW
    Casey
    Clark County, WA
    :facepalm::thumbsup:
  25. Oct 9, 2023 at 7:58 AM
    #745
    wackyhacky
    Keith
    Berthoud, CO
    Yeah, it wasn't intuitive. Discovered it in the manual I think....
    RainMan_PNW[OP] likes this.
  26. Oct 9, 2023 at 11:26 AM
    #746
    TaquitoBandito
    Joel (AKA Bif)
    Updated the Kenwood and calls sounds better, I think. It's weird that you barely hear it ring when it calls but then the voice is louder when the person pics up. Also, when someone calls me, my phone rings instead of it ringing over the car stereo. I actually kind of like that though.
    I guess I get so try to set this up... I wish it could just magically set itself up. I'm almost 51 and tired of learning new shit. :(
    (Yes I live across the street from a pink and green house.)
  27. Oct 9, 2023 at 12:10 PM
    #747
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Easy to tell people where you live. Yeah, look for the pink and green house. We're across the street.
    TaquitoBandito and TRDFerguson like this.
  28. Oct 9, 2023 at 12:12 PM
    #748
    coTony
    Tony
    Montrose, CO
    That is how I describe where I live on the Golf Course, when you come to the house with a 6’ metal rooster in the back yard, I am the big house next door
  29. Oct 9, 2023 at 12:16 PM
    #749
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, except people get distracted by it. Hell, for the first two weeks we lived here, I’d drive past our house because I was looking at that one…
  30. Oct 9, 2023 at 4:53 PM
    #750
    Bigshow7938
    Bigshow7938 New Member
    So after my radio install my range for my fuel is way off, it says that I know have 600 miles of range for a full tank. Has anyone else experienced this?
    AZTundra likes this.
