DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Oct 6, 2023 at 1:49 PM
    #3061
    shmabs
    shmabs New Member
    Any more pics or build thread on this truck?
  2. Oct 6, 2023 at 1:53 PM
    #3062
    coTony
    Tony
    Montrose, CO
    Beware, there are sway bar Police that lurk!
    I took mine off, I have Icon 3.0 coilovers and a secondary shock. Adjust the knobs on the front and it is not bad as folks think. Does it lean in a corner? Uh, yeah no sway bar but not bad. I have been making quick motions on the highway because I wanted to see what I was dealing with and I was surprised because it is not that bad. That is just my opinion and it is not for everyone
    tundznoff, reywcms, 831Tun and 2 others like this.
  3. Oct 6, 2023 at 2:03 PM
    #3063
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    My front spring is 750 and I have no issues. It does lean more than with the sway bar but I can still rally around a corner faster than I have traction for most of the time and I have never had any complaints from others about the increased body roll.
    CaptRussia253[QUOTED] likes this.
  4. Oct 6, 2023 at 2:55 PM
    #3064
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Just cut up the oem skid plate as it was rubbing too.
    I ran no sway bar with OME hd coils on my frontier with no issues. But these trucks are so damn heavy I was worried. Maybe I’ll remove and try it out.
  5. Oct 6, 2023 at 2:57 PM
    #3065
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Took mine off years ago and never looked back. 700lb spring and the extra width of LT probably help a little.
  6. Oct 6, 2023 at 3:01 PM
    #3066
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    shmabs[QUOTED] and CaptRussia253 like this.
  7. Oct 6, 2023 at 3:12 PM
    #3067
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Don’t believe warren he babies his truck :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
  8. Oct 6, 2023 at 3:53 PM
    #3068
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's funny!
    reywcms likes this.
  9. Oct 7, 2023 at 7:31 PM
    #3069
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    I got a chance to take some more pictures of her. 37s with 17 or 18 inch wheels look perfect on this gen Tundra IMO.
    Deaner, BillyB, TundraTEX518 and 13 others like this.
  10. Oct 8, 2023 at 1:21 PM
    #3070
    CaptRussia253
    Ruslan
    Those Mickeys are looking :muscleflexing:
    2TunGet1[QUOTED] likes this.
  11. Oct 8, 2023 at 2:03 PM
    #3071
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Looks amazing!
    What's your suspension setup and wheel/tire combo? Looking to make the switch to 37s after this winter hopefully
    CaptRussia253 likes this.
  12. Oct 8, 2023 at 4:33 PM
    #3072
    2TunGet1
    Thank you!
    FRONT: ADS 3.0 Coilovers w/ resis, MCM UCA w/ Icon Delta Joint, Spindle Gussets
    REAR: ADS 2.5 w/ resis, Dobinson’s L59-120-R Leaf Springs, Durobumps.
    Wheels: Method MR305, 17x8.5, +25 offset
    Tires: Mickey Thompson Baja Boss M/T, 37x12.50x17
    BMC, Pinch Weld Mod, front liner cut, Toyo Bumper 1/2” Spacers
  13. Oct 8, 2023 at 5:10 PM
    #3073
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What’s a sway bar?
    Deaner, tundznoff, BiggHertz and 5 others like this.
  14. Oct 10, 2023 at 11:01 AM
    #3074
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Mine rubs the sway bar too on full lock turning. Not interested in removing the sway bar. I just dont taking the turning to the max and live with it.
  15. Oct 10, 2023 at 11:16 AM
    #3075
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Remind me your wheel offset?
  16. Oct 10, 2023 at 11:23 AM
    #3076
    coTony
    Tony
    Montrose, CO
    Looks good and no rubbing at all, that is an awesome job! I have a very slight rub on my Icon Billet UCA's other than that I am rub free. I have the same tires and offset on my wheels which is why I was interested to see if yours rubs when flexed out
  17. Oct 10, 2023 at 12:20 PM
    #3077
    Boisefly
    Boisefly New Member
    Boise, ID
    +18
    Shanet421[QUOTED] likes this.
  18. Oct 10, 2023 at 12:38 PM
    #3078
    2TunGet1
    A little rubbing on the sway bar at full lock. This is not my daily driver so I’m not really worried about it. Haven’t decided if I want to try without the sway bar yet.
  19. Oct 10, 2023 at 12:58 PM
    #3079
    coTony
    Tony
    Montrose, CO
    I removed my sway because I did not think it would fit and with the 3.0 coil over and secondary shocks up front it rides pretty well. Obviously dips in corners because no sway bar but not as bad as I thought it might be
    SAGE63 and CaptRussia253 like this.
  20. Oct 10, 2023 at 7:47 PM
    #3080
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You’ll get used to it. After going through @joonbug build thread, that’s when I decided to take my sway bar off. Haven’t looked back since. To each their own though.
    Man, glad to see so many of us hopped onto the 37s! I haven’t done much with mine except tire rotations and oil changes.
    J&ATundra, Deaner, BillyB and 11 others like this.
  21. Oct 10, 2023 at 8:08 PM
    #3081
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    There he is!
    pvn.beluga[QUOTED] likes this.
  22. Oct 10, 2023 at 8:34 PM
    #3082
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Wishing that one day I’ll take your SC and throw it into mine LOL
    reywcms[QUOTED] likes this.
  23. Oct 11, 2023 at 3:24 PM
    #3083
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Question though, what do you guys think about running Total Chaos shackles with 5100s on option 1 or 2? Or would this cause premature failure of the shocks?
    I’m really only hauling brush and dirt (limitless projects from the wifey) lol so I think the OEM leafs are shot.
    reywcms likes this.
  24. Oct 11, 2023 at 4:15 PM
    #3084
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Make it the way you want it, fix/repair as needed.:anonymous: If you're running OEM leafs you'll probably upgrade at some point, I'm guessing??
  25. Oct 11, 2023 at 5:36 PM
    #3085
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Woops!! I forgot to mention that option 1 or option 2 would be for the Icon RXT packs.
    831Tun[QUOTED] likes this.
  26. Oct 12, 2023 at 6:47 AM
    #3086
    king.cong.1119
    king.cong.1119 New Member
    I think you'd be fine, have you decided on the rxt yet? if not, maybe dobinson rear leaf could also be considered.
  27. Oct 12, 2023 at 7:27 AM
    #3087
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I just got some Boise Springworks and they offer a medium and heavy version...all new hardware, u-bolts and good directions, though it doesn't take a smart person to do it...just another option...I paid roughly $550 shipped to my door...I went with mediums but got medium-heavy haha "custom" is good, right? You would need to give them a call or leave an email off their website and they'll call ya back...
    Http://www.BoiseSpringworks.com
  28. Oct 12, 2023 at 10:54 AM
    #3088
    Boisefly
    Boisefly New Member
    Boise, ID
    These guys are about 10 minutes from my house and do killer work. Did leaf springs on my jeeps and have great customer service.
    HulkSmurf14[QUOTED] likes this.
  29. Oct 12, 2023 at 10:55 AM
    #3089
    HulkSmurf14
    2014 Tundra Limited
    Agreed! They have been VERY good with communicating in an "eyes wide open" approach so all questions were answered. They have been around for a long time too!
  30. Oct 12, 2023 at 12:01 PM
    #3090
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I have the RXT sitting in the garage, lol
