  1. Oct 4, 2023 at 6:12 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Wife's getting you a high clearance bumper for Christmas? She's a keeper!
    Voss, oscardog86, Mr.bee and 5 others like this.
  2. Oct 4, 2023 at 6:17 PM
    jwilly0404
    jwilly0404 New Member
    Jesse
    2001 TRD Limited AC 4x4
    Bone Stock
    I picked up the new radiator and all the fluids. Lol. Friday I get to make a mess. How much trans fluid should I expect to lose, any rough ideas?
  3. Oct 4, 2023 at 6:20 PM
    A few ounces at most when swapping the radiator. All you have to do is point the trans hoses upward and gravity will keep them from leaking. You'll only lose some when you disconnect them from the radiator.
    jwilly0404[QUOTED] likes this.
  4. Oct 4, 2023 at 6:22 PM
    depends on how messy you are. There is less than half a quart in the lines I would imagine.
  5. Oct 4, 2023 at 6:30 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Where you live? I’ve got all kinds of body damage. :rofl::cheers:
  6. Oct 4, 2023 at 6:39 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
  7. Oct 4, 2023 at 6:40 PM
    DJenerated
    Dija
    The Lone Star State
    I don't even have those bottom corners of my bed any more on my 06 :D :sawzall:
  8. Oct 4, 2023 at 7:50 PM
    DJenerated
    Dija
    The Lone Star State
    KNABORES likes this.
  9. Oct 4, 2023 at 8:31 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I don't recall your impact setup but those bolts on my truck were super tight and there is a nut on the top side to hold if I remember right. Had to turn a breaker bar and hold a wrench. Kinda inconvenient really.
  10. Oct 4, 2023 at 9:43 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Since I was putting it back together and boxing it up, here's a pic:
    des2mtn, artsr2002 and NUDRAT like this.
  11. Oct 5, 2023 at 5:34 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I got to the shop early this morning and managed to get a first coat of paint on before we opened.
    Voss, -Woodsman-, RUSTYNUTS and 8 others like this.
  12. Oct 5, 2023 at 5:43 AM
    Do you work at a dealership or body shop? That hood is going to look so much better once you finish.
  13. Oct 5, 2023 at 6:26 AM
    The Black Mamba
    DFW
    Imma keep it stock
    I'm at a dealership. We don't have a body shop.
  14. Oct 5, 2023 at 7:51 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I wanna say that the head of the bolt is a 19mm and the nut on top of the cross-member is a 22mm? Driver's side has more stuff in the way, but it's not too bad. That reminds me, I was looking to buy some replacement bushings for those arms. Doesn't seem like they cinch up enough, once they're unseated.
    shifty` likes this.
  15. Oct 5, 2023 at 8:17 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Don't take this the wrong way, but why does it look so 'bad'? Are those tiny bubbles in the paint, or are the chip marks showing thru? Askin as I have the same black hood, littered with rock chips. (not quite as bad as yours was)
  16. Oct 5, 2023 at 8:18 AM
    Thanks, after seeing your last pic, I went out and popped the caps off on the donor wheel I have. Had I known they just pop off, I would've replaced my shiny ass volume/track up/down buttons years ago. I assumed they were spring-loaded, but found the the springiness was coming from two white post assemblies inside the control body. I'll hafta snap some pics and post those too, in a new thread about steering control button face swaps or something, so we have the info archived in its own thread.
    My Bosch profactor cordless has never been unable to get a bolt off (yet) on this truck. I'm hoping it could do the job.
    I just had a setback in recovery though. Overextended myself eating mac n chz last night. Then sneezed two hours later. Got my first bleed. Throat is sore as hell now. Looks like I'm laying low for the next couple days.
  17. Oct 5, 2023 at 8:18 AM
    I'm pretty sure he used the Rustoleum roller method. It can actually look good. Friend of mine did it on his mid-90s Impala. What you're seeing are the bubbles that show early in the process, it's normal.
  18. Oct 5, 2023 at 8:19 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Just realized it wasn't sprayed on
  19. Oct 5, 2023 at 8:23 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    gawd dammit. sorry to hear.
    shifty`[QUOTED] likes this.
  20. Oct 5, 2023 at 8:28 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Yesterday I sanded the hood down to the metal where the paint had flaked off and tried to even out the rest of it. Today I just rolled it with rustoleum. No primer or block sanding applied. This was not meant to be or look like a professional job. The bubbles you see in the pic have flattened out. The next coat will look much better and then once it cures, I will use a finishing compound to polish it. It will look better. I didn't set out to make it look new, just to make it look better that the paint chips and clear coat failure that were there.
  21. Oct 5, 2023 at 8:32 AM
    DJenerated
    Dija
    The Lone Star State
    I miss Mac n cheese so much. I made my own cheese sauce with keto plant noodle garbage that was like eating rubber. I had to throw it out. The sauce was awesome. I blended heavy cream, butter, Velveeta, gouda, and colby jack
  22. Oct 5, 2023 at 8:46 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Ahh, you don't have the single-stage paint. I don't have clear coat, but still got all the same chips. I was hoping those were just bubbles. That's good. 'Bad' was a bad choice of words. So.. my bad. It doesn't look bad at all. I was just curious about the texture. Can't wait to see it finished.:thumbsup:
  23. Oct 5, 2023 at 8:55 AM
    -Woodsman-
    -Woodsman- New Member
    NC
    05 SR5 DC Tundra 4WD
    Western NC, I say we make Shifty’s place a meeting hub and we can all just crash there for the weekend. :yes:
  24. Oct 5, 2023 at 8:58 AM
    Yeah, I don't have enough land or garage space to guarantee y'alls cats stay intact if you choose to stay here. Work moved me where I am 20 years ago, and it's going to pay off handsomely soon enough (already has in droves), but there are plenty of downsides to living where I do.
  25. Oct 5, 2023 at 9:03 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Shit, I just remembered I've got cold beers in the fridge...... way over here on the west coast. Maybe next time:hattip:
  26. Oct 5, 2023 at 9:16 AM
    -Woodsman-
    NC
    Dang dude, I’m sorry to hear this. I hope you can get some rest/heal and feeling better soon.
  27. Oct 5, 2023 at 9:32 AM
    Time. It's all just ... time! Recovery takes time, will get there. I still feel good.
  28. Oct 5, 2023 at 9:37 AM
    Welp, finally got notification: My order is on-hold, and they identified the national shortage. I just don't have time or the voice to deal with this one today.
    bmf4069[QUOTED] likes this.
  29. Oct 5, 2023 at 9:39 AM
    The Black Mamba
    DFW
    Imma keep it stock
    sounds like @-Woodsman- and @RUSTYNUTS need to make Texas the meeting hub. There are plenty of us on here for places to crash. @-Woodsman- can pick up @shifty` on the way.
  30. Oct 5, 2023 at 9:44 AM
    The Black Mamba
    DFW
    Imma keep it stock
    2nd coat is applied. Now to let it dry.
