General Supercharger Thread
  1. Oct 3, 2023 at 10:33 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    According to page 1 Sniv said 117 is the stock belt length I'd go down .5" or 1"
    snivilous[OP] and V10Ace like this.
  2. Oct 3, 2023 at 10:45 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Looks like the closest one Gates has 115".. might be too tight
  3. Oct 3, 2023 at 10:47 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    The Magnuson "smaller belt" is only 0.2" shorter. Stock Harrop belt is 117.7", so 117 - 117.5 would be what I would look for.
    Mdl and V10Ace[QUOTED] like this.
  4. Oct 3, 2023 at 11:05 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’d just get the green belt, size is noted in post 1. Everyone says they are tighter in addition to gripping the pulley better. I have one as a spare I keep in my truck for if mine shreds when I’m far from home.
    nags, Mdl and V10Ace[QUOTED] like this.
  5. Oct 3, 2023 at 11:07 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Good call as I can't seem to find a belt that's between 117"-117.7" anyway lol.
    Silver17[QUOTED] likes this.
  6. Oct 3, 2023 at 11:10 AM
    ssmokedz
    Shelton CT
    You will not be disappointed even with just stock pulley and fuel as long as you have a custom tune. Midrange torque is night and day.
  7. Oct 3, 2023 at 11:28 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Oh what I was thinking was XXX/XXR18
    But I’m tracking with the largest size on a stock rim.
  8. Oct 3, 2023 at 11:34 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Anyone get a P1603 code (engine stall) after modifying fuel basket and with tank at 1/4 full? The truck ran and drove to first shop. But not to second. I was just at shop troubleshooting. Thought it was because I didn't have the air filter in and it was tripping maf but no maf code. Added new air filter and truck sounded better but still stalled few seconds after starting.
    Truck was on a slight slope, downward towards front of truck. Plan is to go back tomorrow with some gas to add in. Currently just below the 1/4 line. Gonna add like 10 gallons.
    Mdl likes this.
  9. Oct 3, 2023 at 11:55 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @M3Tundra-JK. When I first modded my basket back in 2012 I had major issues. Anything below a 1/4 tank and it would almost stall with hesitation on take off. I replaced the canister and issue resolved.
    Currently have ffv canister with W450 model 267 that fits with no mods. Running 60psi at wot.
    *Also hopefully pump pickup tube isn't loose.
    HulkSmurf14 and M3Tundra-JK like this.
  10. Oct 3, 2023 at 12:08 PM
    M3Tundra-JK
    Scott
    2005 GX470
    I swear to the car gods if I have to drop the tank for a a 5th time so help me lol
    That is reassuring though. I know people say no WOT pulls below 1/2 tank with the modified basket, and the engine is acting more fuel starved than anything. Will report back tomorrow with finding
  11. Oct 3, 2023 at 12:20 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Pedal Commander the product is risky based on a few complaints I've read here. There are a couple of threads here reporting it throwing trucks into limp mode or trigger other issues. PC primarily sells a bluetooth version of their throttle controller that I think is the problem, I think when the BT radio is active it overdraws the circuit triggering limp mode.
    When I used PC the truck felt like the transmission was slamming into 1st gear in all settings besides Normal and ECO modes. Even City -4 felt this way. The Banks Pedal Monster engineer claims its the way the throttle curve is set up on the other devices, most advertise a dog leg curve.
    Banks also uses the OBD port to provide 12V power, the other devices use 5v from the pedal. If it draws too much from the pedal circuit that is when limp mode is engaged. The only way to remedy this is to pull over, unhook your battery and the Pedal Commander and wait 15minutes to clear the error code.
    If you are dead set on a throttle controller look at Banks PM or one of the other brands like Hikeit or Sprint Booster. The BT feature on the PC is unnecessary unless you are trying to hide the device and frequently make setting changes; I found I "set it and forget it" so the option to make remote setting changes was not useful to me. Other brands have features that may be more useful like valet mode, kill switch, speed sensitive settings, etc.
    HulkSmurf14 likes this.
  12. Oct 3, 2023 at 12:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Man I feel for ya. Over the years I've dropped the tank 6 times and pulled the longtubes 5. If I have to pull the LT's again I'm going to remove and blockoff the jba air tubes. Have them like the ARH with only cylinder 7 and 8 tubes for aip.
    Good luck!
    M3Tundra-JK[QUOTED] and reywcms like this.
  13. Oct 3, 2023 at 2:01 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Black@Blue19 and HulkSmurf14 like this.
  14. Oct 3, 2023 at 2:44 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    These damn rigs a very sensitive to battery voltage. Maybe this is it I wonder
  15. Oct 3, 2023 at 3:08 PM
    M3Tundra-JK
    Scott
    2005 GX470
    After more research I'm thinking ya. P1603 relates to tcm/ecm communications. Sounds like voltage too low to communicate between even with a charger on. Just spent $200 for a new battery to try tomorrow
    HulkSmurf14, Mdl and reywcms[QUOTED] like this.
  16. Oct 3, 2023 at 3:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Battery is a good one. Especially if its dead or a bad cell. Air leak, fuel pump, maf...
    HulkSmurf14, reywcms and M3Tundra-JK like this.
  17. Oct 3, 2023 at 6:11 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Magnuson TVS2650 arrived this afternoon
    VWTim, rockmup, M3Tundra-JK and 11 others like this.
  18. Oct 3, 2023 at 6:32 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    :smokertransformer: take me to da choppa!! Yeeeeeehaw!!
    Tripleconpanna, Mdl and Saltyhero13 like this.
  19. Oct 3, 2023 at 6:57 PM
    Saltyhero13
    Cool, seems like Magnuson was able to ship these out quick.
    Any first impressions?
  20. Oct 3, 2023 at 7:31 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Haven't gotten around to opening the boxes yet lol
  21. Oct 3, 2023 at 8:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Might I inquire as to the wait time?
    mZiggy[QUOTED] and Mdl like this.
  22. Oct 3, 2023 at 9:25 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I would've had those boxes open and all the parts laid out on my bed by now...
  23. Oct 4, 2023 at 2:40 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Well it's not really accurately representative of actual wait time moving forward because when I ordered, the kits weren't made and ready to go yet. They only finished housings early last week
    Wynnded[QUOTED] likes this.
  24. Oct 4, 2023 at 4:04 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    assuming the pulleys are the same size...and...85mm being "stock" pulley:
    selfishly, I'd like to see this 2650 perform damn near exactly as the Harrop....because, well, it is.
    maybe we will will also see the slight performance differences in design.
    mainly:
    one blows up, the other blows down - does it matter?
    does post blower IAT sensor affect tuning/performance?
    <hat tip to those that are getting the 2650 Mag>
    I'll be sitting over here waiting to see the dynos & dragys.
  25. Oct 4, 2023 at 4:35 AM
    mZiggy
    mZiggy Honey badger
    Marc
    iirc it's a 3.4" pulley, so ~86mm, comparable
    Saltyhero13 likes this.
  26. Oct 4, 2023 at 4:39 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    thanks.
    interesting.
    are you starting with that one...or moving down a few notches?
  27. Oct 4, 2023 at 5:19 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Starting there.
  28. Oct 4, 2023 at 5:35 AM
    Silver17
    Eastern PA
    Does it have a quick change hub?
    M3Tundra-JK and Saltyhero13 like this.
  29. Oct 4, 2023 at 5:44 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Let’s hope the IAT sensor is post blower so we can compare temps to the Harrop. Up vs down, etc.
  30. Oct 4, 2023 at 5:54 AM
    Silver17
    Eastern PA
    Nevermind I see it is a quick change in the pics. I wonder what the process is to change the coupler out on this style? Doesn’t look like a removable snout like the old one but can’t really tell in the pictures.
    Mdl, M3Tundra-JK, Saltyhero13 and 2 others like this.
