Retractable tonneau and cargo bed dividers
Discussion in 'Tonneau Covers, Caps and Shells' started by trustdrummer, Aug 22, 2017.
  1. Aug 22, 2017 at 8:18 PM
    trustdrummer
    trustdrummer [OP] New Member
    2016 Tundra
    Hello all. I'm new here.
    Just bought a 2016 crew cab SR5. I think I'm going to get the retrax Powertrax MX tonneau cover for it so I can store my tools securely under it. However I'd like to use my bed rail system and the toyota cargo gate/bed divider to keep stuff from sliding. The place I'm buying the cover from says the divider can't be used with the cover closed. Since I have neither the cover or the divider at the moment I don't know if there's a way to flip over the mounts with the knobs so it might allow more clearance. Any help/suggestions is appreciated. I really want to use some type of gate with existing rail system that will work with the retrax. Thank you all.
  2. Aug 23, 2017 at 7:30 PM
    Lo1dakota
    Lo1dakota Ermagherd
    Brandon
    Washington
    2017 Inferno CM TRD Off-Road
    18" TRD Wheels - BFG 35" Tires - OME Lift - N Fab Steps - TRD Sway Bar
    Check out the BAK Revolver X2. It's a hybrid hard/soft tonneau. It comes with brackets to drop the tie down system so that it can still be used. Pretty sweet setup. I just installed one on my truck.
  3. Aug 24, 2017 at 3:39 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I've got the Retrax PRO MX and the cover mounts directly to the bed rail system which is one of the reason I wanted it, it keeps the integrity of the whole thing. But I don't have the divider but I'm thinking if you call your local Toyota dealer and ask them if it drops below the bed rail system you'd get your answer.
  4. Aug 24, 2017 at 9:37 AM
    trustdrummer
    2016 Tundra
    @RowdyRon thsnks for the pics. So you could turn that L bracket upside down so the knob faces down correct? That migh allow clearance for a retrax tonneau cover.
    @MT Madman Have you had any problems with your retrax pro leaking through the aluminum slats? Not at the seals at the edge where where it meets the truck. I've seen some videos that people posted leaking through the slats. It's got me leary to pay so much for something leaks through the aluminum slats.
  5. Aug 24, 2017 at 11:10 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @RowdyRon is the height adjustable on the divider. I have BAK Revolver X2 with the rail system and I had to attach my factory rails to a supplied bracket.
  6. Aug 24, 2017 at 11:18 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    @RowdyRon Thanks,....I didn't read that part...
    Duh on my part:facepalm:
  7. Aug 24, 2017 at 12:36 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Hey Ron is the divider an actual Toyota part number?
  8. Aug 24, 2017 at 1:33 PM
    Tacogrande
    Jeremy
    Thanks Ron! You the man!
    Just called my local dealer and they want $453.55. Ill call Roman and see what he says.
    Looks like a nice piece of hardware.
    NewImprovedRon likes this.
  9. Aug 24, 2017 at 3:08 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Welcome from WI! The powertrac will work just fine with the factory rails as the clamps for the cover simply slide into the rails. The divider however, may pose a problem. If the mounts can be flipped so that the knob is underneath I believe you'll have enough clearance for the cover to travel above it as the Powertrax doesn't have the latch like the other Retrax covers. BUT...because of the width of the Retrax rails it will be impossible to remove the divider from the bed because you won't be able to remove the knobs and lift it out of the sliding mounts. I don't know if it's possible to slide the divider out at the rear, @RowdyRon may be able to provide that answer. If it can be, you'll still have to remove the rear clamps that secure the Retrax rails to do that. Also, because of the clamp placement in the rails you'd end up only having about 3 feet of travel fore and aft with the divider. Retrax is an excellent cover. Ive been installing them for several years now and havent had any leaking issues in regards to the slats or canister. I do always tell my customers though, with a smile, the only thing water tight in this world is a frogs ass. Truck beds were never built to keep water out so a little trickle in the front corners or at the tailgate is not out of the ordinary, especially on trucks like ours with plastic bedcaps. One other thing to consider and this is just food for thought, but the Powertrax canister is about 12" x 12" the full width of the bed, so on a crewmax where the bed is only 5 1/2' you stand to lose a pretty good chunk of space at the front of the bed.
  10. Aug 24, 2017 at 4:46 PM
    duece292
    Greg
    Green Bay, WI
    Cool, thanks Ron!! I wasn't sure if the sliding mounts would clear the bed posts or not. I learn something new on here every day :)
  11. Aug 24, 2017 at 7:56 PM
    trustdrummer
    2016 Tundra
    @RowdyRon @duece292 thanks so much for the info. I have the factory toyota rails and I know the retrax can be attached to that. I want a retractable cover but I realize if I want water tight I'll need to get the fiberglass kind. However it appears whatever I get I will pretty much lose the ability to use the cargo divider. If I do use it I will have to take the rear clamps off, which I don't want to do. So I will probably end up going with the powertrax pro. That being said, I will have to use a cargo bar to keep stuff from sliding in the bed. And suggestion on what would work best with the plastic bed liner that came on the truck? I'm thinking of getting line x or rhino liner type lining later. But for now I've got to deal with plastic liner
  12. Aug 24, 2017 at 8:11 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Thread Jack alert!!! I spot two cannon gun safes! I got the "Armory"
    NewImprovedRon and duece292 like this.
  13. Aug 24, 2017 at 8:33 PM
    duece292
    Greg
    Green Bay, WI
    @trustdrummer, Erickson makes a good cargo bar, #8908 is the ratcheting style and is easier to use than the twist style and will work fine with any type of liner. You can also use a 2x6, 8, 10 in the board slots in the bedliner. The powertrax is a great cover and as far as water tight goes it seals up very well. I just always try to make my customers aware of potential leaks but I think it's safe to say that it'll be 98%. To take care of the other 2%, when I install one I use butyl rubber under the corners of the bedcaps and to fill any gap between the bedcaps and bedliner. It just helps to keep any water from finding it's way in at the front of the bed. At the tailgate I use a bulb gasket called trailseal. It's adhesive backed and helps to close the gap around the tailgate. It works great for keeping water from blowing thru in carwashes as well as keeping dust and fine snow from getting in. Hope that helps.
    Tundra_Dawg likes this.
  14. Aug 25, 2017 at 3:49 AM
    MT Madman
    Hawk Point MO
    No problems with leaking on the cover at all
    just back spray around the tailgate but nothing their seal didn't fix https://www.retrax.com/series-22103...et.html#!year=2016||make=TOYOTA||model=TUNDRA
  15. Aug 25, 2017 at 5:16 AM
    MT Madman
    Hawk Point MO
  16. Aug 25, 2017 at 5:25 AM
    MT Madman
    Hawk Point MO
    This divider has me intrigued, I'll have to watch and see if it works with the cover.
  17. Aug 25, 2017 at 6:30 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    We can get one, however we don't ship those out. I've shipped too many out and had them come back damaged, so they are sold in store only.
  18. Aug 25, 2017 at 8:52 AM
    duece292
    Greg
    Green Bay, WI
    Loading Zone is another cargo divider that might be worth a look.
  19. Aug 25, 2017 at 11:30 AM
    NoDak
    NoDak New Member
    2017 Tundra TRD Pro CM - Super White
    I have the Bakflip X2 and had to drop the bedrails using Bak's supplied "s" bracket. I went by my local dealership today and tried to install the cargo divider. Although there is enough clearance from the bottom of the bed (it also fit with my bed rug installed), the divider is about 1/2" too long to fit due to the "S" bracket coming in a bit on each side. If you cut the bar a 1/4" on each side you could make this fit, and still have the clearance to close your hard tonneau cover.
    I would have bought the cover today, but I just moved and don't have the tools to cut the bar down. I'm trying to find a local fab shop that will help me out. I'll post pics when I get it done.
