Shimmer/vibration after lift kit and carrier bearing drop.
Discussion in 'Suspension' started by Thcvet, Nov 8, 2018.
  1. Sep 30, 2023 at 9:33 PM
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    2” as advertised with a rough country add a leaf. FWIW I have 2.25” in the front
  2. Oct 1, 2023 at 7:48 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Looked under the truck today and watched some RAS installation videos.
    My carrier bearing does not looked cocked or misaligned. And everything is installed correctly.
    So next question. What is the normal amount of carrier bearing play when pushed up on driveshaft? I’m getting 1/4” of slop when I push up in driveshaft at location of carrier bearing.
    drew.c.114 likes this.
  3. Oct 1, 2023 at 8:17 AM
    drew.c.114
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Damn. Eliminating installation error of the CBD kit, I’m wondering if there will always be SOME shudder. I really only notice it when I slam on the gas pedal, which I don’t normally do when I’m driving normally, so I’m wondering if I should just live with it, or if over a long enough time has residual shudder remains could cause premature u-joint and CB failure.
  4. Oct 1, 2023 at 8:40 AM
    ZPhilip
    Philip
    West Chester, PA
    This is also the only time I notice the vibration. Hard acceleration from a stop, which is fairly often so it gets annoying.
    drew.c.114[QUOTED] likes this.
  5. Oct 1, 2023 at 9:27 AM
    drew.c.114
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Honestly the only thing that reduced the shudder dramatically was getting the angles as close to spec by measuring the angles of the drive lines and flange on the differentials
  6. Oct 1, 2023 at 5:54 PM
    drew.c.114
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Also, I checked this and I’m off by a bit (3mm). I’ll have to readjust it and see what’s up!
    ZPhilip[QUOTED] likes this.
  7. Oct 1, 2023 at 8:45 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Nice find let us know how it turns out.
  8. Oct 8, 2023 at 8:23 PM
    ZPhilip
    Philip
    West Chester, PA
    Do you know what are the ideal angles are?
  9. Oct 9, 2023 at 10:23 AM
    drew.c.114
    Andrew
    Gilbert, AZ
    2021 Trail Edition
  10. Oct 9, 2023 at 10:42 AM
    MadMaxCanon
    This is awesome, thanks.
