Rear Diff Gear Oil for LSD?
Discussion in '1st Gen Tundras (2000-2006)' started by Bobby Bo, Sep 30, 2023.
  1. Sep 30, 2023 at 4:01 PM
    Bobby Bo
    Bobby Bo [OP] New Member
    I bought some Valvoline 75w-140 for my rear diff thinking I can do the oil change myself. Once I got under there I saw a "LSD Oil Only" sticker and checked my manual which states above 0 degrees to use SAE 90 or below 0 degrees to use SAE 80W or 80W−90.
    The Valvoline 75w-140 I bought states it has limited slip additives but I want to follow the manufacturer recommendations. Any recommendations on which oils I should consider? I am in Colorado where it only occasionally gets below 0. Thanks.
  2. Sep 30, 2023 at 4:22 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    The factory service manual says the 75-140 is for non-LSD. I’d just return it and get the right viscosity
  3. Sep 30, 2023 at 4:47 PM
    Whatever you do, don't make the mistake I did and use that oil in your LSD diff.
    Use Lucas 80w90 in the rear diff if it's an LSD. Save your money.
    I ran what you're looking at in my LSD rear and no amount of additive would've made my rear end not chatter.
  4. Oct 1, 2023 at 4:18 AM
    angertheloner
    angertheloner New Member
    ATX
    2000 Tundra AC Limited
    All original survivor
    Just ran into this thread. How would I know if I have the lsd?
  5. Oct 1, 2023 at 5:26 AM
    Bobby Bo
    Mine had a yellow sticker on the rear diff stating such bit not sure how I would have known/identified it if it wasn't there
  6. Oct 1, 2023 at 5:47 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
  7. Oct 1, 2023 at 6:01 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Enter your VIN @ www.toyota.com/owners/ and retrieve your "as built" configuration.
  8. Oct 1, 2023 at 6:07 AM
    LSD rear shouldhave a sticker indicating it assuming you're not in the rust belt and/or someone hasn't taken it off.
  9. Oct 1, 2023 at 6:11 AM
    Bobby Bo
    mine doesn't show LSD anywhere when inputting my VIN, but has the sticker
  10. Oct 1, 2023 at 6:12 AM
    Trust the sticker. Especially for Canadian users, the truck info at Toyota Owner's website isn't always correct.
  11. Oct 1, 2023 at 7:27 AM
    w666
    Maryland
    Yeah, about that...the site stopped displaying my details correctly a while back, so I wrote them to complain. They sent me a PDF of my actual config, and that's what I refer to going forward
  12. Oct 1, 2023 at 8:57 AM
    angertheloner
    ATX
    Thanks. No sticker and nothing in the spec sheet either with vin. The truck was pretty clean and original when I bought it so, I’m thinking it’s a no on the lsd since I don’t think the sticker would have been removed from the previous (original)owner.
  13. Oct 1, 2023 at 9:04 AM
    I mean, even if it isn't LSD, conventional Lucas 80w90 works both ways. Thing with LSD is, there isn't much except Lucas 80w90 that works without chatter. :rofl:
    Not sure what you've got going on though.
    bfunke likes this.
  14. Oct 1, 2023 at 9:28 AM
    bfunke
    bfunke Tundra Curmudgeon
    You can pull the fill plug and look into the hole. If you can see into the carrier and see spider gears, it’s not limited slip. Also jack up the rear end while in park and spin one tire. If it doesn’t spin it’s LSD. If the other wheel spins the opposite direction it’s not LSD unless your clutch pack is toast.
  15. Oct 1, 2023 at 4:00 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    I vote for a peek inside the bung-hole.
  16. Oct 1, 2023 at 5:40 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Motul 90pa being the other fluid I know works.
    Mustanley and shifty`[QUOTED] like this.
  17. Jun 4, 2025 at 3:11 PM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    Sorry to bump an old thread; I'm planning to change fluids in the transmission and differentials on my 04 DC with an LSD. Regarding the rear differential, do I need to add an LSD additive if I go with the Lucas Oil 80w-90 gear oil?
  18. Jun 4, 2025 at 3:44 PM
    Nope. It works as-is with Lucas 80w90.
    And on the trans, if you don’t already know, drain and fill is king, there’s no viable reason to drop the pan, you’re probably asking for headaches if you do.
    phudz[QUOTED] likes this.
  19. Jun 5, 2025 at 10:13 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    What brand makes the squeeze bags for the front diff again? I don't remember how i.filled it last time but adding some the other day during my ECGS bushing fiasco was a pita..
  20. Jun 5, 2025 at 10:26 AM
    At least two make a full syn bag that will work with the LSD rear, without using additives.
    • Valvoline Max "Flex Fill" bag
    • Amsoil SevereGear "Easy Pack" bag
    You can readily buy hand pumps for the quart bottles of Lucas 80w90 though, it takes about 40-50 pumps to get everything out of the bag with the cheapy scAmazon pumps (Slippery Pete brand, or whatever). My old hand pump would get me there in 20-30, but have no idea where the hell I put it (or if a worker snagged it) while we were finishing out the basement.
  21. Jun 6, 2025 at 5:16 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Are you meaning this?
    And no additional additives?
  22. Jun 6, 2025 at 6:12 PM
    Yes. That specific gear oil works, as is, with zero additives. It’s what is currently in my LSD diff today, after spending almost $70 on my preferred Mobil1 full synthetic gear oil, and getting diff chatter.
    But with it being non-synthetic, you should change it in half as many miles as synthetic with normal use (15-17.5k) and if towing, 7.5k-10k miles. Those are *ideal* numbers, if we had a dollar for every person on here that’s gone 150k miles without ever changing diff fluids, we’d be rich.
  23. Jun 7, 2025 at 6:34 PM
    Redoak
    Redoak New Member
    Dave
    none
    As rank, and nasty as the old was I’ll probably change it about 3K miles just for my peace of mind then bump it up to recommended miles between changes.
    Wouldn’t the Lucas work for front diff, and transfer case too?
    shifty`[QUOTED] and FrenchToasty like this.
  24. Jun 7, 2025 at 7:59 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Iirc the front diff and tcase spec a 75w-85. Synthetic is good for these.
    Only need the lucas, motul or as one guy found supertech for the clutch type LSD. This prevents chatter.
  25. Jun 7, 2025 at 8:04 PM
    I used full syn in front diff and tc, and will likely keep it that way, doing shorter intervals out back.
    Redoak likes this.
  26. Jun 7, 2025 at 9:08 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    FWIW researched to find Supertech 80-90W gallon < $20 that seems to be the most economical and called the manufacturer to confirm application for BestGen LSD. They comfirmed it is "recommended for Limited Slip / Positive Traction rear axles" as noted on the bottle. No additional additive was needed for my 2003 with LSD and it runs without chatter.
