Undercoating ?
Discussion in '3rd Gen Tundras (2022+)' started by bullet3z, Sep 26, 2023.
  1. Sep 26, 2023 at 1:09 PM
    bullet3z
    bullet3z [OP] New Member
    24 Tundra
    Has anyone had their 3rd gen Tundra undercoated yet? If so, which type did you go with and did they do everything under the vehicle? They salt the crap out of the roads here and I do not want this thing to rust out.
  2. Sep 26, 2023 at 1:41 PM
    DFS
    DFS New Member
    2022 Capstone Tundra
    I'd use Woolwax, can be applied yourself and works very well. I've used it every year for 5-6 years before winter time.
  3. Sep 26, 2023 at 1:53 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    I’d recommend,either krown, or rustcheck. If your near Edmonton go,see sublime surfacing for his dry ice blasting and undercoat
  4. Sep 26, 2023 at 6:44 PM
    Tom976
    Tom976 New Member
    Tom
    Doing it yourself isnt that big of a deal. In the past I used Fluid Film on my Tacoma. Frame on that never had a rust issue living in the salt belt. (Toyota had recalls on it)
    Fluid Film is stupid easy to apply. (I used rattle cans) Spray everything metal. Used two or three cans. Only dislike was it smells for a few days.
    On Tundra I bought Corrosion Free Rust Cure Formula 3000 and a spray undercoating gun. Went on easy, may have sprayed a bit much here and there since it was dripping for days. Oops.
    Supposed to last up to 18 months. Supposedly this stuff is better than fluidfilm. Guess time will tell.
  5. Sep 26, 2023 at 6:54 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Corrosion Free user here.
    It's an easy DIY project with a compressor and gun.
    Mattedfred and Tom976 like this.
  6. Sep 26, 2023 at 7:01 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    I'll be picking up my tundra this weekend. Scheduled appointment at NHOC for the boss wax application. Said to be semi-permanent, heavy-duty rust protectant. Takes them 6+hrs to apply as they mask off to protect cable/exhaust etc. Have to leave it over night. Time will tell if worth it.
  7. Sep 26, 2023 at 7:30 PM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    I had the linex guys do their rubberized coating for my vehicle. I have a 5 year warranty on it. The owner (he is a vet as well) told me he would do free touch ups as well.
  8. Sep 26, 2023 at 9:05 PM
    TruckGuyJeff57
    TruckGuyJeff57 New Member
    20 Black Tundra TRD
    I keep hearing different things regarding pros / cons of lineX for under coating. I was about to pull the trigger a couple year back when I read many recommendations against it, suggesting that water can sometimes get trapped inside (ie through a crack that isn’t seen) or if there are small amounts of existing rust, it will “look” nice on the exterior but you risk the frame rotting on the inside. I asked the lineX shop and he said he’s been doing this for a very long time and that isn’t true. ‍♂️
    vtown76 and mmasse[QUOTED] like this.
  9. Sep 26, 2023 at 10:02 PM
    HLR_NM
    HLR_NM New Member
    Harry
    I live in New Mexico :anonymous:
    .. but if I lived where I thought it prudent to undercoat my choice would be Fluid Film - cheap, inert and easy to reapply. Skip the spray cans, get a 5 gallon bucket and a cheap spray gun and maintain the whole fleet.
    Pockets of trapped moisture could be a concern with plastic coatings - not like there have been any rusted and replaced Toyota frames out there :monocle:
    RichterScale likes this.
  10. Sep 27, 2023 at 1:23 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Mine got the Waxoil treatment when it arrived at the dealer from the factory,after a year they want it back for inspection and touch ups if needed, I'll tell you this though, if you have to do anything and I mean anything under your truck ya better wear a Tyvek suit cause that shit sucks to off get off it gets EVERY WHERE!
    I can appreciate for what it does but man swapping out my exhaust sucked I was covered in that shit.
  11. Sep 27, 2023 at 5:33 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Fluid Flim here. Lay a blanket of that stuff on everything steel and you’ll keep the rust away. Definitely get a spray gun if you have the compressor to support it.
  12. Sep 27, 2023 at 5:44 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    GO CANADA :canada:.
    We have Poutine AND Corrosion Free!
  13. Sep 27, 2023 at 8:10 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Rust is just the iron that has been burned by oxygen. If there's already rust and you completely seal/encapsulate it, the metal will stop burning. Rust doesn't spread when it's completely sealed off from O2. So, he was right about that not happening (granted, everything is perfectly sealed).
    I don't like things like rubberized or plastic coatings because they dry, shrink, crack and even have pits and spots missed. If water/O2 makes it's way into those little compromised spots, then yes, the metal will oxidize underneath the coating, it will spread and you won't see it happening.
    Of course, someone selling a product will always say that it works well and all the bad things are myths.
    Rubber coating, plastic coating, linex, etc will work to prevent rust, given that everything is perfectly covered and sealed, it never chips, shrinks, cracks, pulls away from the surface, etc. But that will never happen. Unless the metal is already galvanized and painted (but then you don't really need the protection).
    It's better to use a wax or oil based product, do a good job covering everything and reapplying it when needed.
    Just my opinion. But based on living in snow/road salt land for 50 yrs.
  14. Sep 27, 2023 at 8:54 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  15. Sep 27, 2023 at 9:17 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Exactly. It just doesn't work,.....and makes the problem worse.
  16. Sep 27, 2023 at 11:22 AM
    Blufin
    Bob
    23 Capstone
  17. Sep 27, 2023 at 12:29 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    The CRC marine corrosion inhibitor is $24 p/10oz can at the local marine shop here.
    I looked on Amazon and found it for $10 p/can. So I ordered a bunch.
    I'll update on how it is to apply and how it holds up over winter.
  18. Sep 27, 2023 at 12:58 PM
    mmasse
    Idaho
  19. Sep 27, 2023 at 1:13 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
  20. Sep 27, 2023 at 1:32 PM
    Oldandfat
    Cannuckastan
    Oil,spray type coatings have to be applied every year.
    I will be trying “Honeyseal” which is a cosmoline type coating. It has a yellow tint to it so you can see if and when it needs to be re applied.
    the nice thing about the place I’m going to is they dry ice blast before they coat. Kinda like a factory reset.
    at the end of the day doing some kind of rust mitigation is,better than none.
    more important is the application of the product rather than the product itself (oil or cosmoline type)
  21. Sep 27, 2023 at 1:44 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Unless you have a brand new spotless frame then rubberized undercoating is not the way to go since as others have said it will trap moisture. Oil based products like fluid film do a great job. I'm 4 years into ownership of mine and have had it undercoated with fluid film every year and not a spot of rust on it. The only thing that sucks is when you go to do anything to the underside of your truck it's a slippery mess. I usually plan my big projects like suspension swap just before my next undercoating to avoid a fresh mess of fluid film.
    BravoDeltaRomeo likes this.
  22. Sep 27, 2023 at 2:15 PM
    allenbrad11
    allenbrad11 New Member
    I live in the rustbelt, so that was the very first thing I had done . I used Zeibart for the undercoating.
  23. Sep 27, 2023 at 2:57 PM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Been taking mine to Krown since 2022...soooo..two visits now, no issues.
  24. Sep 27, 2023 at 3:32 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Wouldn't be a bad idea to give your battery terminals and any exposed ground terminals a spritz with CRC, too.
  25. Sep 28, 2023 at 5:18 AM
    Tom976
    Tom976 New Member
    Tom
    If you want to coat the battery terminals I would recommend petrolium jelly for that.
    Used it for years on the cars and boat. Prevents the white powder oxidation.
    BravoDeltaRomeo and Mattedfred like this.
  26. Sep 28, 2023 at 7:38 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    I'll be trying Krown for the first time, scheduled for the end of October in York, PA. They had open availability as early as next week, unfortunately my work schedule is a little hectic over the next few weeks so I pushed it out a month. $159 for my Tundra which I was extremely shocked at the price. I asked them if I should drop my spare tire, as they don't do so, and the lady on the phone said they should be able to reach under there still with the various hoses/attachments they have, along with being able to spray the spare tire as well. I'll follow back once I actually get it done.
  27. Sep 28, 2023 at 7:50 AM
    Oldandfat
    Cannuckastan
    id drop the spare anyways. Actually I do this every year. Otherwise if you don’t, and you get a flat you may find the mechanism seized.
    plus I also check the tire pressure as well.
    Mattedfred likes this.
  28. Sep 28, 2023 at 9:26 AM
    Dan_Gleesac14
    Yea after thinking about it a little more, I think I will just leave my spare in the bed for them to spray separately. But living in MD and now PA a majority of my life, this is normal practice yearly to drop and inspect the spare like you mentioned.
  29. Sep 28, 2023 at 9:27 AM
    Oldandfat
    Cannuckastan
    good plan.
    most people never,do this. Then when you need your spare, it’s low on air and useless.
    ask me how I know! Lol
  30. Sep 28, 2023 at 10:15 AM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    I am using PB Blaster's Surface Shield. Dust and debris do tend to stick to it but that can all be washed off as long as rust does not form. This winter will be its first test on the Tundra. I have been using it for 3 years now on my wife's Highlander but it rarely seen snow as we did have a winter beater before I bought the Tundra so it would not be a fair evaluation of this stuff.
    Brownsfanhere likes this.
