rubber bed mat for double cab 1st gen tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by dirtnsmores, Sep 26, 2023.
  1. Sep 26, 2023 at 8:03 PM
    dirtnsmores
    dirtnsmores [OP] New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    I've searched and can only find them for access cab 1st gens. I need one for my double cab 1st gen tundra. anybody know which brand makes them? I've searched this site and google, maybe it's right under my nose. thanks guys!
  2. Sep 26, 2023 at 8:06 PM
    dirtnsmores
    Southern CA
  3. Sep 27, 2023 at 12:39 PM
  4. Sep 27, 2023 at 12:57 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    In the rockauto listing for that mat (I used 2004), it shows that it is for 74.3" bed (Double Cab).
    Double Cab bed length = 74.3"
    Access Cab bed length = 74.7"
    Not sure that 4 tenths of an inch is going to matter much here.
  5. Sep 27, 2023 at 1:13 PM
    Double cab is absolutely ~74" (6'2), some say 75".
    Access cab is 2" larger, their number is totally wrong, maybe that's the measure of the mat itself?
  6. Sep 27, 2023 at 1:17 PM
    dirtnsmores
    Southern CA
    Ok thanks. Shot you a few dms (again ). Gonna take the truck to get the timing belt work started today.
  7. Sep 27, 2023 at 1:19 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I pulled the numbers from an old Tundra brochure, which matched the Westin info.
    dirtnsmores[OP] likes this.
  8. Sep 27, 2023 at 1:21 PM
    It's possible it's the inner dimension between tailgate and cab wall that's different from the outside edge length, then, and that's the discrepancy.
  9. Sep 27, 2023 at 1:25 PM
    dirtnsmores
    Southern CA
    I've ordered it, will post some pictures when it comes in on Monday!
    HBTundra likes this.
  10. Sep 27, 2023 at 1:27 PM
    912 likes this.
  11. Sep 27, 2023 at 1:56 PM
    dirtnsmores
    Southern CA
    Appreciate the help guys. Stoked to keep everything from sliding around back there.
  12. Sep 27, 2023 at 2:21 PM
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
  13. Sep 27, 2023 at 7:08 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    if the universal has the velcro to attach I'll probably go this route. I had one on my 2015 and it's really nice to have. Keeps stuff from sliding around and its super durable. If you carry a lot of equipment it doesn't rattle nearly as much either lol.
    shifty` likes this.
  14. Sep 28, 2023 at 3:01 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Meh, I have a plastic liner in mine. In my Ferd, I swung by the local Tractor Supply and grabbed a horse stall mat. It weights a shit ton, grippy af and its about 3/4 inch thick. I obviously don't cover the entire bed floor but it covers the majority. The bed is spray lined anyway. I just wanted it to keep shit from sliding around. $45 bucks. 'Nuff said.
  15. Sep 28, 2023 at 6:20 AM
    dirtnsmores
    Southern CA
    I may go this route eventually. Let me know if this works out for you guys
  16. Sep 28, 2023 at 6:33 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Was a little confused on that website. These were the options offered. 2006 DC SR5 and mine should be around 72-74”/6’2”-6’4”
  17. Sep 28, 2023 at 6:43 AM
    Yeah, dunno what they're smoking. Not sure I'd be buying from them if they can't get their sizes right.
    Weagle[QUOTED] likes this.
  18. Sep 28, 2023 at 7:01 AM
    janbrochill
    janbrochill Confovere miraculous infinitus mundi
    Cleveland, TN
    2001 Limited Tundra
    Camper top addition, horse stall mat bed padding, bed extender
    Took your advice and went with the same. Great cheap and lasting advice. Mine will also be used by dogs and it makes the bed that much more usable.
  19. Sep 28, 2023 at 7:28 AM
    Even my OG Toyota mat doesn't fit perfectly. Maybe it did when new. Never bothered me and I'm glad it came with the truck. I wish I had kept my bed extender sometimes.
  20. Sep 28, 2023 at 7:32 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    On my 1st gen, the rubber mat I used was from my previous Silverado. It was quite a bit longer and a little wider. So it went up the front of the bed like that, except 6 more inches, and the the extra width by a 4 inches or so. Basically had built in "pockets" in the two front corners because of that. Looked kind of ghetto, but it was actually handy.
  21. Sep 28, 2023 at 10:33 AM
    Lundy
    Lundy New Member
    San Diego
    Bedrug has zero options pre made/ custom( what ever you want to call ) it for 1st Gen Tundra
    Only option is the trim to fit. Need to get an actual quote from them via text or email. Then they email you a quote and purchase from that email. $109 no tax and free shipping .
    TonneauCovered.com
  22. Sep 28, 2023 at 7:49 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    The 5’7” is for the newer crewmax trucks.
    I’m really wanting to do what I did on my 2.5G. I cut the bed rug and added the US Cargo L track. Keeps stuff like floor jacks, spare tires, and cases from sliding since it allows them to sink in just enough to stay put when strapped down. Super sturdy since I was able to jump the truck and my 37” spare didn’t even move.
    Also, I like the bed rug since it's foam and allows water to dry up vs sitting under a mat or drop in liner eliminating the worry of rusting out the bed. Not to mention that it's significantly lighter than a rubber mat
  23. Oct 5, 2023 at 10:25 PM
    dirtnsmores
    Southern CA
    Do you have any pictures? Do you have the plastic drop in liner from the factory or bare metal underneath? Wondering if you can feel the grooves on the bottom of the bed.
  24. Oct 6, 2023 at 3:43 AM
    -Woodsman-
    -Woodsman- New Member
    NC
    05 SR5 DC Tundra 4WD
    The Black Mamba and shifty` like this.
  25. Oct 15, 2023 at 11:10 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Never got around to a mat, but got the L track mounted. Camping seasons here for us and I need more tie down points.
