General Supercharger Thread
  1. Sep 23, 2023 at 8:18 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I hope she's OK. The GX looks great!
    Tripleconpanna and snivilous[OP] like this.
  2. Sep 23, 2023 at 8:18 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    "Aural enhancement."
  3. Sep 23, 2023 at 8:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is the Prospeed intake 4.5 inch intake ID or OD?
  4. Sep 23, 2023 at 10:31 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    OD. The ID is slightly larger than 4.25" but not by much.
    Mdl[QUOTED] likes this.
  5. Sep 24, 2023 at 5:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Has anyone had the RC F throttle body bored out. Looks like it can be bored out 3mm. Think @ViktorG did his. Not sure if it would make a major difference withe the maggy 1.9. Will be modding the TRD intake with 4.5in or 4.75in pipe, looks like i can cram a 5 inch too, as maf is maxxed. Will anything over 4.5 affect normal unboosted drivability? I do have to wait until I get the new 750 injectors.
    HulkSmurf14 and ViktorG like this.
  6. Sep 24, 2023 at 6:58 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I had mine done, but they could only increase it by 2 mm iirc
  7. Sep 24, 2023 at 7:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    George at Maxbore said he can do it 3mm without compromising the wall thickness. I found a rcf with 30k on it and a good deal. Is it worth it for any gain? $155 for the cleaning, new plate and boring.
  8. Sep 24, 2023 at 7:28 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’m holding out for the LS103 tb to work out.
    Fastlane47, Mdl and HulkSmurf14 like this.
  9. Sep 24, 2023 at 7:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ^^^Pimpin' ain't easy but it sho' is fun!!!
    Saltyhero13, Mdl and reywcms like this.
  10. Sep 24, 2023 at 10:53 PM
    ViktorG
    Viktor
    Calgary, Canada
    That will be about a 7% area increase, surely it can only be a good thing.
  11. Sep 25, 2023 at 10:50 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    So I decided to yank the supercharger out this morning for the coupler. The rebuild kit came with the truck and I didn't realize it was the kit with new bearings. Can anybody point me to instructions for the bearing portion? I'm to the point of putting the new coupler in and putting it back together now. Should I even worry about the bearings?
    16956641455457483379407486153676.jpg PXL_20230925_171733766.jpg 16956641954581244870792041666506.jpg
  12. Sep 25, 2023 at 11:25 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Yes, do them while it's all apart.
  13. Sep 25, 2023 at 11:33 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I second replace the bearings. The pulley is a bear to get off sometimes. But everything else should go well.
    HulkSmurf14 and Wynnded like this.
  14. Sep 25, 2023 at 2:17 PM
    STravis
    Travis
    Ruidoso, NM
    Got it all done. All quiet now. The new pulley from @snivilous is pretty sweet. I went with a 2.2 and it made a noticeable difference.
  15. Sep 25, 2023 at 2:30 PM
    HulkSmurf14
    2014 Tundra Limited
    Nice work on the rebuild/update! Are you still on the Maggy 535s? Or did you upgrade with everything apart?
  16. Sep 25, 2023 at 2:32 PM
    STravis
    Travis
    Ruidoso, NM
    Still on the 535's. That will make me keep things in check for a while. I will eventually run a bigger pump/injectors and shoot for more boost and a tune. I really just want to make sure the truck doesn't need anything else before I get too wild.
  17. Sep 25, 2023 at 2:34 PM
    HulkSmurf14
    2014 Tundra Limited
    Awesome! I'm stoked on your newly released ponies!
    Mdl and Tripleconpanna like this.
  18. Sep 25, 2023 at 2:47 PM
    STravis
    Travis
    Ruidoso, NM
    Me too!
  19. Sep 25, 2023 at 4:00 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Looks absolutely awesome! If you have any complaints or issues or suggestions for the pulley let me know. Between you and @Wynnded and a third random guy today, that like doubles the amount of SSS pulleys in the wild :rofl:
    PolishedTRD, Wynnded, reywcms and 6 others like this.
  20. Sep 25, 2023 at 5:30 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's it!?! WTH is wrong with you people? :facepalm::rofl:
  21. Sep 25, 2023 at 5:35 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    In fairness I was ordering a sniv pulley before the blower swap lol but I do have a sniv product and soon something else
  22. Sep 25, 2023 at 5:51 PM
    e30cabrio
    I have a 2.2 waiting to go in. It's still over 100 hear. :(
  23. Sep 25, 2023 at 6:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice!
    I'm game once my 750's show up. Hmm 6.7 inch overdrive crank and 2.2...
    So I found intake pipe 4.5 inch,that I can cut to get a 22deg angle to meet up with throttle body.
    What epoxy bonds aluminum to TRD ABS plastic. I'll create a rim on intake for inside of cover to help bonding. Loctite hysol epoxy or 3m product?
  24. Sep 25, 2023 at 6:11 PM
    HulkSmurf14
    2014 Tundra Limited
    I just need to get off my arse and throw it on...and refresh the coupler, etc...
  25. Sep 25, 2023 at 6:17 PM
    snivilous
    SW UT
    There's at least four people in this thread with pulleys sitting in the box still, so I'm not counting those ones since there's no evidence they function yet :rofl:
  26. Sep 25, 2023 at 6:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It was so chilly here when I did mine on Saturday about noon, I had to close the garage door!
    HulkSmurf14, snivilous[OP] and Mdl like this.
  27. Sep 25, 2023 at 6:42 PM
    HulkSmurf14
    2014 Tundra Limited
    We had snow on Sunday in the hills...it's just around the corner!! Woot woot!!
    Mdl and Wynnded like this.
  28. Sep 25, 2023 at 8:05 PM
    e30cabrio
    Boooooo
    HulkSmurf14, Mdl and Wynnded[QUOTED] like this.
  29. Sep 26, 2023 at 9:32 AM
    e30cabrio
    Would tuning a 16+ LX570 be any different than any other 5.7?
    Mdl likes this.
  30. Sep 26, 2023 at 10:31 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would speculate that as long as the ECU version is supported by HPT (assuming that's what's being used) it would be the same.
    Mdl likes this.
