*VIDEO* Ticking Noise - Timing Chain Tensioner?
Discussion in '2.5 Gen Tundras (2014-2021)' started by NateG, Oct 1, 2019.
  1. Apr 11, 2022 at 10:16 AM
    DaveTundra1
    DaveTundra1 New Member
    2016 Toyota Tundra
    I just had the same issue noise was worse when cold it ended up being the timing chain tensioners, timing gears and chain thank god for the extended warranty I bought, it just paid for itself
  2. Apr 11, 2022 at 10:28 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did the dealer give you any flak about it saying that its not a big deal and you dont need to fix it or anything like that? I am considering an extended warranty for this issue and the cam tower leak issue.
  3. Apr 12, 2022 at 9:13 AM
    DaveTundra1
    2016 Toyota Tundra
    The first time I brought it in they couldn't figure out what it was, the noise got a lot worse and I have a friend that is a service writer for the dealership and he was a big help in making sure they fixed it, they are aware of the issue the engineers also like you to take a video so you can show them they confirmed the issue with the video but they covered everything with the platinum warranty except for the diagnostic which we should not have to pay especially when they know the issue is there. its always the drivers side bank 1 is what I was told
  4. Apr 15, 2022 at 7:17 AM
    csweet68
    csweet68 New Member
    Cybil
    2014 Tundra
    Thank you for this thread. I have the same issue on my 14 Tundra with 207k miles. Mine has a bit more a tin can rattle as well. No one has been able to figure it out till the most recent mechanic. Althought the tensioner was never mentioned. This mechanic says replacing my timing chain is redundant on a 200k mile engine because Its an expensive job and my engine may need replacing shortly after. My engine seems to run strong and should be able to get at least another 100k if not more out of her. Thoughts??
  5. Apr 15, 2022 at 7:34 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    These engine can go to 500k+ with regular maintenance
  6. Apr 15, 2022 at 8:09 AM
    DaveTundra1
    2016 Toyota Tundra
    I would say go for it these engine do go many miles
  7. Sep 22, 2023 at 8:34 AM
    Harveyparty
    Harveyparty New Member
    2015 Tundra
    None
    Watching this thread to see if anyone ever experiences catastrophic failure as a result of tensioner and if there are indicators prior. My 2015 Tundra has 211k miles and has been clicking for at least 75k. Seems to get a little better after oil change but never fully goes away. Can be pretty loud on cold start and wife says it sounds like shit but I just tell her to shut up and get in (kidding. Hahaha). I won’t spend the $4200….confident she’ll hold together until we hit the 10 year mark.
  8. Sep 22, 2023 at 8:58 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    just curious what difference you see between 5w-20 and 0w-20 at operating temperature?
    Ive tried 5w-30 AND 5w-20 and both are quieter than 0w-20
