Do I have a problem with my Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, Nov 29, 2016.
  1. Oct 27, 2017 at 12:02 AM
    #151
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Smart move on the belts and plugs. What are they charging you for the fix?
  2. Oct 27, 2017 at 12:40 AM
    #152
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
  3. Oct 27, 2017 at 5:35 AM
    #153
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Plugs and belt came to $241.00. They reduced the labor on the plugs and aren't charging labor on the belt. The cam towers and timing cover leaks, second oil change and rental vehicle are all covered by warranty.
  4. Oct 27, 2017 at 6:25 AM
    #154
    duece292
    Greg
    Green Bay, WI
    I thought the belt and plugs were a good idea since it's already torn apart. I couldn't find a mileage recommendation for changing the belt. I know the plugs are 100,000 but I have never and will never run plugs that long. They're saving the belt for me (I'll carry it in the truck as a 'just in case' spare) and a couple of the plugs just because I want to see how they look at 56,000.
    TheBeast likes this.
  5. Oct 29, 2017 at 10:59 AM
    #155
    TheBeast
    TheBeast The Beach
    when will the truck be ready ?
    duece292[QUOTED] likes this.
  6. Oct 29, 2017 at 5:26 PM
    #156
    duece292
    Greg
    Green Bay, WI
    It was supposed to be ready on Friday. Got a call Friday afternoon that it was back together and the tech and service manager were test driving it and the CEL came on. The service advisor said it was off and running fine but wanted to keep it thru the weekend for the tech to go back over it. I asked what code it pulled but he didnt know and said the tech was on it as we were talking. He was very apologetic and said they wanted it perfect before i got it back. I said no problem, I'll suffer driving the rental turd Suburban until tomorrow.
  7. Oct 29, 2017 at 5:51 PM
    #157
    TheBeast
    TheBeast The Beach
    at least they gave you a suburban..I had a nissan sentra...
  8. Oct 29, 2017 at 7:06 PM
    #158
    duece292
    Greg
    Green Bay, WI
    Honestly I was expecting some little car. The Sub is a rental thru Enterprise and I was surprised that that's what they gave me. I did thank the guy for not bringing me a mini van ;)
    TheBeast[QUOTED] likes this.
  9. Oct 30, 2017 at 7:29 PM
    #159
    duece292
    Greg
    Green Bay, WI
    So, got the truck back today, everything seems to be right with the world again. They did a good, clean job with the sealant, cleaned up under the hood pretty well and gave it a bath. The delay in delivery was because of a timing issue which caused the CEL. Apparently some sealant got on a sensor and threw a timing code. She's also got new plugs and a new serp belt. Plugs looked pretty good at 56,00020171030_171128.jpg
  10. Dec 20, 2017 at 11:20 AM
    #160
    Tundra Bob
    Tundra Bob New Member
    Bob
    Western PA
    2018 Tundra SR5 Doublecab MGM 4x4
    Havoc HS3 Polished Hoop Steps , bed liner , bed rails, mud flaps , all weather mats
    I just purchased a 2018 tundra 5.7L & am wondering if this problem has been resolved in the newer trucks ?? :( Hopefully it is . :cheers:
    Bob
  11. Dec 20, 2017 at 11:28 AM
    #161
    TheBeast
    TheBeast The Beach
    too early to tell. Some 2017s have it though but less reports obviously. It seems to happen around the 30,000 miles mark.
  12. Dec 20, 2017 at 11:45 AM
    #162
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    I wouldn’t worry about it. It’s only a small percentage of people that actually have it happen. Honestly, you probably have a much higher chance of getting in a wreck and destroying the whole truck than having that leak #GlassHalfFull.
    Wrongside and TheBeast like this.
  13. Dec 23, 2017 at 9:49 PM
    #163
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    That happened to me and it turned out to be a chipmunk that tried to take a nap on my manifold.
    Slayer and TheBeast like this.
  14. Feb 2, 2019 at 8:26 AM
    #164
    FreeriderATC
    FreeriderATC New Member
  15. Feb 2, 2019 at 8:47 AM
    #165
    socal147
    socal147 None Specified
    Patrick
    Oak Hills Commiefornia
    2019 Tundra Tonka
    Stock is so temporary
    2019
    417 miles
    Mine has a new car burn off. Smell it every time I get done driving. Getting to be less noticeable ....
  16. Sep 19, 2023 at 11:00 AM
    #166
    Adventundra
    Adventundra New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Just put a deposit on a 2016 long bed w 46k miles …I was just informed to inspect for this issue. Guna try n get a look in there after lunch. Guy was trying to sell me 84 month/75k mile warranty but not sure if this would be covered….any ideas if it would be? Warranty does not cover wear and tear stuff.
