n0rth's Platinum build
Discussion in '2.5 Gen Builds (2014-2021)' started by n0rth, Aug 13, 2022.
  1. Sep 5, 2023 at 6:29 PM
    #61
    n0rth
    n0rth [OP] New Member
    J.W.
    2019 Tundra Crewmax
    Received a letter today about recall on the Ironman 4x4 Pro Forge UCA's for potential ball joint failure, they're sending a new set and reimbursing the install and alignment costs. I have not had any issues with these UCA's, I'll give Ironman 4x4 a :thumbsup: for taking care of the issue though.
    https://ironman4x4america.com/recall-faq/
  2. Sep 5, 2023 at 7:26 PM
    #62
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Can’t argue with that.
    n0rth[OP] likes this.
  3. Sep 6, 2023 at 9:37 AM
    #63
    NaturalState4x4
    NaturalState4x4 New Member
    Josh
    2021 Black Crewmax
    3" lift, TRD PRO wheels, 35x11.50 Falken RTs
    I just read through your build, and it is definitely one of my favorites! Solid job!
  4. Sep 6, 2023 at 10:14 AM
    #64
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    That's awesome to hear! I had heard/read about people having very opposite experiences with their customer service, so that's good that they're making it right.
    n0rth[QUOTED][OP] likes this.
  5. Sep 19, 2023 at 10:09 AM
    #65
    n0rth
    J.W.
    2019 Tundra Crewmax
    Guess I might need 39’s now…
    5
    .29’s are in my future for sure after driving Travis’s truck today.
  6. Oct 3, 2023 at 2:23 PM
    #66
    n0rth
    J.W.
    2019 Tundra Crewmax
    Brown truck delivery….5.29 Revolution with REM polish.
    Locker or lockers?
  7. Oct 4, 2023 at 2:40 PM
    #67
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Lockers for sure. If you're already cracking open the diffs don't give yourself any reason to do it again
  8. Oct 22, 2023 at 2:46 PM
    #68
    n0rth
    J.W.
    2019 Tundra Crewmax
    Rear locker showed up, Larry approves.
    Went for a drive today to check out the fall colors.
  9. Oct 22, 2023 at 8:47 PM
    #69
    n0rth
    J.W.
    2019 Tundra Crewmax
    Picked up a set of Solid Offroad motor mounts from another member, these should stiffen up the front end of the truck. I'm amazed at the amount of flex in the front frame rails.
    Hopefully the front locker will arrive before the end of the month, the plan is to pull the diffs and haul them to Zuk in Prescott AZ in early November.
  10. Oct 25, 2023 at 4:49 PM
    #70
    n0rth
    J.W.
    2019 Tundra Crewmax
    Have both lockers now, just waiting till next month to pull everything and head to AZ for the install. I also received shipping confirmation for the replacement Ironman 4x4 UCA's they should be here Friday. I have some serious garage time coming up in the near future, really looking forward to it.
  11. Oct 30, 2023 at 4:31 PM
    #71
    n0rth
    J.W.
    2019 Tundra Crewmax
    Turned cold the last few days, picked up a load of wood for my mom I'm amazed at how small the load looked in truck versus stacked at the house.
  12. Nov 10, 2023 at 11:27 AM
    #72
    n0rth
    J.W.
    2019 Tundra Crewmax
    Started snowing early this morning, the Kanati Trail Hogs perform really well so far hopefully we get more snow.
  13. Nov 10, 2023 at 2:36 PM
    #73
    CaptRussia253
    Ruslan
    Nice! I wish we had snow now.
    We’re twins haha.
    BreyTundy and n0rth[OP] like this.
  14. Nov 18, 2023 at 6:00 PM
    #74
    n0rth
    J.W.
    2019 Tundra Crewmax
    Pulled the diffs today, started at 8 this morning and finished up around 3:30 this afternoon.
    Notching the brake line tabs makes it all work and having a jack stand collection helps.
    Some axle cheese, it's only on the drivers side closest to the diff vent.
    This is the heaviest toy third I've ever had to deal with it will be even heavier going back in once the elocker and 5.29's are added, I'll be phoning a friend for some help installing this thing.
    I didn't take many pics pulling the front diff out until I got to this point...no wheel drive.
    Ready to make the trip to AZ with a pile of parts.
    Calling it a day, time for a shower then pizza and beer.
  15. Nov 18, 2023 at 7:38 PM
    #75
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Hovercraft mode means good things are about to happen.
  16. Nov 21, 2023 at 6:03 PM
    #76
    n0rth
    J.W.
    2019 Tundra Crewmax
    Zuk started on the rear diff this afternoon, I'm fascinated with all the information and photos he shares and spend a lot of time studying them. The statements in quotation marks is what he sent with the photos.
    "Checking the factory pattern, which was fine. I can tell by the bias that it is a two cut pattern which is very common in the auto industry"
    "145 ft lb with generous amounts of red loctite on clean threads on all 12 bolts"
    "The pinion flange is in excellent condition....barely a little groove and finish sanded with 2000 grit wet and dry as insurance"
    "The 10.5 comes from the factory with a short solid collar which is nice that they do that.... The pinion bearings look perfectly fine"
    He was surprised when I told him there is 102K on the truck with the condition of everything he thought it would be less miles. I'll keep updating as the photos and info roll in and I have time to post.
  17. Nov 21, 2023 at 6:46 PM
    #77
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    Solid build man! Truck is awesome and with those gears and lockers will be a beast! I've got to get to working on that for my truck.
    CaptRussia253 and n0rth[OP] like this.
  18. Nov 22, 2023 at 5:35 PM
    #78
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Are you going to reuse the existing axle seals?
  19. Nov 22, 2023 at 7:39 PM
    #79
    n0rth
    J.W.
    2019 Tundra Crewmax
    Yes, I've never had any issues doing it this way on several trucks and Land Cruisers. I see you're running a Harrop how do you like it?
    CaptRussia253 likes this.
  20. Nov 23, 2023 at 7:25 AM
    #80
    CaptRussia253
    Ruslan
    Whats the overall price for the gears and install?
  21. Nov 23, 2023 at 7:47 AM
    #81
    ZPhilip
    Philip
    West Chester, PA
    Ok cool. I’m thinking about regearing and going the East Coast Gear mail out route, with self install.
    To be honest, I want to be faster for $12k spent on a Supercharger with smaller pulley, etc. But my truck at 6400 pounds, it would need around 700hp to really scoot.
  22. Nov 23, 2023 at 8:03 AM
    #82
    ZPhilip
    Philip
    West Chester, PA
    Im also interested in how this price compares to other sources, etc.
    CaptRussia253[QUOTED] likes this.
  23. Nov 23, 2023 at 8:25 AM
    #83
    n0rth
    J.W.
    2019 Tundra Crewmax
    Ordered gears directly from Revolution and added the REM polish (you have to call to add it) It looks like they have a Black Friday sale currently. https://www.revolutiongear.com/products/fitment/2019-Toyota-Tundra-any
    For the install, you would most likely need to work with an installer directly. Prices seem to be all over the place, I have used ECGS in the past and purchased entire built thirds 4.88's and ARB's for the Tacoma when I lived in Alaska. I'm using Gearinstalls.com "Zuk" who is retired and no longer does mail in service. He built my thirds when I lived in Idaho for the FJ80 Land Cruiser that had factory elockers and got 5.29's. He's close enough to me now and still does drop offs, so I had a buddy drop off my thirds and I'll drive over and pick them up after Thanksgiving. Roughly I'm at 2500$ with gears and install not including the lockers and my time, a place in ABQ quoted me 7500$ to do everything (Nitro gears and rear Nitro LSD) which sealed the deal for going the route I did.
  24. Nov 23, 2023 at 8:29 AM
    #84
    n0rth
    J.W.
    2019 Tundra Crewmax
  25. Nov 23, 2023 at 8:33 AM
    #85
    CaptRussia253
    Ruslan
    That’s a sick Tacoma. Almost went that route until I test drove the tundra haha. Thanks for the info :thumbsup:
  26. Nov 23, 2023 at 8:43 AM
    #86
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    A local Toyota master who owns his own shop did my F&R install for around $1300. I provided everything. That was the cheapest around my area. The others quoted in the $2k range.
  27. Nov 23, 2023 at 8:49 AM
    #87
    n0rth
    J.W.
    2019 Tundra Crewmax
    The 1993 FJ80 on 37's with 5.29's, elockers and Slinky suspension, I probably should have kept this one too but I didn't.
  28. Nov 23, 2023 at 9:13 AM
    #88
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Would've held onto this one.
  29. Nov 23, 2023 at 9:48 AM
    #89
    CaptRussia253
    Ruslan
    That’s a fantastic price. I was quoted close to $6k with parts included and no lockers :crazy:
  30. Nov 23, 2023 at 9:49 AM
    #90
    CaptRussia253
    Ruslan
    Ya I would have kept this one for sure.
