Banks Pedal Monster review...it's a win!
Discussion in 'Performance and Tuning' started by Tundra234, May 24, 2023.
  1. Sep 12, 2023 at 3:05 AM
    #91
    Taikowaza
    Taikowaza New Member
    Thanks for the pics @Ginsterkev! Looking fantastic! Do you prefer a mix of idash and analog gauges? This is great.
    I’m not sure if these will fit in the 3rd Gen (22+) Tundras. The vent Geometries are totally different in our trucks. Also as Saltyhero mentioned I think that the Ortiz will mean the loss of the driver’s side handle for 3rd Gen.
    Im looking forward to the 3rd Gen stealth pod Jay posted that integrates onto the back attachment point of the handle. I do hope that Banks will make a dual pod using that attachment point.
    I think that I’ll prefer having all selected data visible on two idashes simultaneously rather than constantly switching screens on a single unit, that said I’ve not yet tried one (order placed, incoming).
    Ginsterkev[QUOTED] likes this.
  2. Sep 12, 2023 at 3:39 AM
    #92
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Oh man sorry I forgot you have a 3rd gen I guess I got my brain confused here, I didn't have my coffee yet this morning lol ... but yes I like having a dedicated boost and afr however the idash does have several afr avail wich is awesome I also use those as well you def can't go wrong with 2 of them !
    Taikowaza[QUOTED] likes this.
  3. Sep 12, 2023 at 5:13 AM
    #93
    Saltyhero13
    Saltyhero13 Throbbing Member
    This post has the steering wheel mounted version for gen 2.5:
    https://www.tundras.com/threads/gauges-with-magnuson-s-c.86348/#post-3154099
    Until folks start modding the gen 3s I doubt there will be much in support for boost gauges
    Not a fan of the suction mounted options, they tend to fall off at the most inconvenient times.
    OC offering are also Gen 2.5s
  4. Sep 12, 2023 at 5:18 AM
    #94
    Saltyhero13
    I was referring to Ortiz's Gen 2.5 offering. They only have a no handle option for the A Pillar (reference Gin's pics)
    Glowshift is another company that makes generic gauge pods.
  5. Sep 12, 2023 at 8:39 AM
    #95
    ToyFan
    ToyFan New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    We were not planning on an iDash dual Stealth Pod... However, if there's demand, it's certainly worth considering and I'm happy to pursue it with our engineers.
  6. Sep 12, 2023 at 8:58 AM
    #96
    Tundra234 [OP] New Member
    Yes I did and have had absolutely no issues at all. All you need is the OBD splitter and to disable the OBD function in the app. I kept the SG3 because it was a new purchase right before I switched from the PC to the Pedal Monster. I'm especially happy with the SG3 since I finally have a permanent mount for it.
  7. Sep 12, 2023 at 9:00 AM
    #97
    Taikowaza
    Thanks Jay, I am certainly very interested in an idash dual stealth pod for the 3rd Gen Tundra, pls add me to the list! Thanks!
  8. Sep 12, 2023 at 9:01 AM
    #98
    Good morning Jay. Not to derail too far off the tracks, but for reference, could you explain the "sleep mode" in regards to the OBD port? I saw in a different post that someone had concerns of battery drain with the OBD having power supplied at all times. Thanks.
    Saltyhero13 likes this.
  9. Sep 12, 2023 at 1:39 PM
    #99
    Saltyhero13
    It's your OP. Rare chance we get a vendor over here to address direct questions.
    Taikowaza likes this.
  10. Sep 12, 2023 at 4:56 PM
    #100
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I installed the Banks Pedal Monster Today. Got Bluetooth connected and did all the account registration and played with the settings. It detected my vehicle and enabled the reverse control protection.
    Then I unplugged everything to do the cable management and secure the controller under the dash. When I started the truck again, I relaunched the app. It connected for a moment and then disconnected even though Bluetooth was still connected. Power cycled the truck and relaunched the app and it connected to the truck but was showing reverse detection unavailable. I went through this a a few times before it allowed me to resync the reverse feature and it went back to green. This does not really leave me the warm and fuzzies.
    I'll check it through the app randomly over the next couple weeks and see what happens.
    But I'll say the drive home was much nicer in traffic and when I got up to the mountain twisties where I live.
    Taikowaza and bulldog93 like this.
  11. Sep 12, 2023 at 5:00 PM
    #101
    You shouldn't have any issue with it disconnecting now that you have it routed and installed.
  12. Sep 16, 2023 at 9:00 AM
    #102
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Is pedal monster doing anything to shift points? I highly doubt it, but since installing it, the shifting is really annoying. Seems to me that even at moderate throttle input, it holding shift points further out. Can make the truck feel pretty erratic.
    Im thinking the shifting is being affected, not directly by PM, but rather the fact that it thinks I'm holding the pedal deeper and that it should hold lower gears longer.
    A bit annoying around town
    Skew12 likes this.
  13. Sep 16, 2023 at 9:22 AM
    #103
    Taikowaza
    I’m really liking mine. Is your truck stock @nasher75? I’m thinking the PM may be of most benefit to those of us with larger tires and suspension mods. FYI I’m not endorsed or sponsored by Banks in any way. I previously ran the BMS pedal tuner and hated it. I have 285/65R20 tires and the 3” TRD lift kit. Since going larger on tires and suspension I haven’t been nearly as happy with my shift points or acceleration. The PM on Sport 1 (where I am running it now) is pleasing me greatly on normal drive mode. If I switch to sport (Toyota drive) mode or Tow/Tow+ it’s just insane. I have not yet moved up on sport mode (2-10) or even touched track mode. My turbos kick on much more intuitively when I need them on the (PM) Sport 1 mode. I will be receiving my idash (logging) datamonster tomorrow and will set it up to display the PM data as well as my shift gear and turbo pressure. I will be happy to post data with PM on and off to compare, and will appreciate anyone’s help analyzing what I’m seeing. Cheers!
    bulldog93 likes this.
  14. Sep 16, 2023 at 9:45 AM
    #104
    What size tires and is the speedometer calibrated? I ran 285/70's with my PM and had no issues. Once I went to 295's, I had gear hunting as I was off 4 to 5 mph. Once I did the speedometer calibration I was good to go.
  15. Sep 16, 2023 at 1:41 PM
    #105
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Im on 285/70's, no calibration.
  16. Sep 18, 2023 at 5:15 PM
    #106
    Taikowaza
    IMG_8360.jpg IMG_8342.jpg IMG_8348.jpg IMG_8350.jpg Received my idash today, excited about it. It took a while to rewire my pedal monster but got everything set up successfully. I’m impressed with it so far. I spent some time setting up various screens. Selected Toyota as the vehicle and rebooted. The engine selection and displacement wasn’t intuitive, it would have been much better if this were all detected via the OBDII port. I selected 3.4L Twin Turbo/Intercooler/Throttle, the only other option is “no throttle”, not sure how these differ. I am trying to see what transmission gear I am shifted into as one of my settings, however the only option is “D” (drive) or P (park) which isn’t helpful. Boost PSIG is also not registering. I feel as if the 3rd Gen engine is not registering somehow. I may need a firmware update (checked: I’m on the latest update) and/or more experience with settings. Overall I’m quite happy with the quality of the unit. I was able to adjust the tire size and see a revised speed which is great. Looking forward to learning more about this and especially to the pillar mount in production. I can already tell that I am going to really enjoy setting up the various screens. The PM screens are great and provide the same readout as the app. Will continue to update.
    edit: spent more time with the idash and customized the screens. I’m not presented with engine choices after selecting « Toyota », I’m asked to enter the size of the engine in litres and the displacement in cubic inches. I entered 3.4L and the displacement defaults to 207.5 instead of the 210 I’ve been entering. Despite selecting this I still can’t see my transmission gear settings (1-10) as the screen only lists drive, reverse etc; this is disappointing. Other vehicles support this. I suspect that the dash doesn’t recognize all the data from our trucks (yet): hopefully with a firmware update very soon. I like the color options, customizability, compact size, and endless permutations of data that can be displayed. Now if only I can get my gears to display. Not sure if the twin turbo intercooler (with throttle) choice is correct yet…
  17. Oct 12, 2023 at 7:37 PM
    #107
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    I recently got the stand alone unit. After upgrading to 33 hybrid tires that were larger and heavier than the stock size. I am pleased with performance so far. I’ve tried the city 5-7 and sport 5-7. Sport at 7 is a little jumpy like tow haul. All and all I like it and a shout out to hotshot off-road!!
  18. Nov 30, 2023 at 4:10 AM
    #108
    ronrich
    ronrich New Member
    Curious if anyone is running one of these units on a supercharged Tundra. How does it response to putting all that power to the ground? I find just taking the "nannies" completely off changes my truck's throttle response. Can't hardly convert all that power to forward motion. Truck easily spins larger tires on dry pavement, even with partial throttle! Any thoughts appreciated, especially your experience if you are running a SC.
    Ginsterkev likes this.
  19. Nov 30, 2023 at 4:40 AM
    #109
    Ginsterkev
    Kevin
    Pennsylvania
    I am running this with my maggy and I can say on sport 4 if your not careful it will jump pretty quick, and just for fun I turned it all the way up on track and turned tow/haul on let me just say that was insane just to try and get it to get off the line smoothly ...... needless to say I won't be doing that anymore lol .... tires are ridge graps 295-70-18 on factory pro wheels
  20. Nov 30, 2023 at 5:00 AM
    #110
    ronrich
    ronrich New Member
    Thanks for your quick reply. Sort of what I figured from your reply. I'm running 305/55/20 terra graps and my truck is insanely fast with all the "nannies" off. Honestly I don't drive around like that much unless I want to play with some obnoxious mustang revving their engine at a stoplight. Otherwise I'd be burning these rear tires off big time!
    bulldog93 and Ginsterkev[QUOTED] like this.
  21. Nov 30, 2023 at 5:13 AM
    #111
    Ginsterkev
    Kevin
    Pennsylvania
    Yes I completely agree I will say I
    Like the more responsiveness of the pedal monster because even with the blower on there I feel I do have to push the pedal further then I want to get it to go , but honestly that is prolly More placebo effect than anything ! If I want it to go, it will go with or with out the pedal monster .... just way cooler with it there !
  22. Nov 30, 2023 at 6:26 AM
    #112
    Saltyhero13
    If you are breaking traction stock, Banks PM wont help launching. They don't mute the pedal/TB opening (for safety as stated earlier), all their modes advance it. You can try another brand that has ECO or an OFFROAD mode but I can tell you first hand it doesn't help; however avoid Pedal Commander.
    Your best bet is traction bars or similar device and better tires for hooking up at a launch; off road style tires are terrible for road traction. Also having something in the bed helps.
    Ginsterkev and ronrich[QUOTED] like this.
  23. Dec 28, 2023 at 9:23 AM
    #113
    Passingthru
    Passingthru 2023 Capstone
    Put the order in yesterday and should arrive today. With all the torque and HP the Tundra window stick claims, I expect the feel of it more. Looking forward to this Banks device making that happen cause Toyota failed miserably dumping the v8 (even though it too had a lag in stock.)
  24. Jun 14, 2024 at 6:59 PM
    #114
    @BettyWhite20 has a brand new one for sale in the marketplace if any of you know someone that is wanting to get one.
  25. Jul 28, 2024 at 3:03 PM
    #115
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Man, when I have something wrong and come to this forum, 90% of the time, you have an answer!
    Mind if I ask what "No-obd" mode is, exactly, and what level you have your speed trim set to? I want to run an obd scanner to monitor AT and TC temps while towing and while using a splitter and the PM. When I checked and found your work-around, it seems like a good solution.
    TYIA
  26. Jul 29, 2024 at 10:18 AM
    #116
    The No OBD mode redirects the data from the OBD port to the ScanGuage or whatever you are using. It does disable the reverse trim feature though. Its not a big deal as reverse stays stock. I'll see if I can find the actual post from Banks that explains the No OBD mode.
    drew.c.114[QUOTED] likes this.
  27. Sep 23, 2024 at 9:27 PM
    #117
    Jamdown
    Jamdown New Member
    PW
    2007 Black Tundra
    Hi Guys, I just bought Pedal Monster for my 2007 5.7L 4x4 Tundra. Unfortunately I am having a problem with installation and am seeking assistance from anyone who has installed on a 2nd Gen. I installed the pedal monster standard, paired the device to an iPhone, registered and attempted to calibrate but it does not work and prompts for a firmware upgrade from v14 to v15. Unfortunately, I get an error when I attempt to upgrade. Any info or suggestions would be greatly appreciated.
  28. Sep 23, 2024 at 10:53 PM
    #118
    blenton
    blenton New Member
    I am also having issues with a Pedal Monster on my truck. I haven't tried syncing to phone or updating (I'm running it through an iDash). Every time I switch settings on the PM it asks to recalibrate the PM. I've contacted Banks about the issue but they keep going radio silent for weeks at a time, saying they will have an engineer look in to it. I'm also having issues with my iDash which is, IMO, a hot pile of garbage. If you just purchased it, I would suggest contacting Banks for a full refund on a faulty product. They have offered to refund mine but won't provide any details to me as to how I can make that happen.
    I'm 100000% disappointed in the Banks equipment offered for the Tundra.
  29. Sep 24, 2024 at 3:27 AM
    #119
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
  30. Aug 4, 2025 at 7:54 AM
    #120
    Allirun
    Allirun New Member
    Greenville, PA
    Anyone tried this with the newest gen and if so how is the lag? Asking since i have a 23 trd pro and i hate the lag. Ill eliminate the comments on "use your foot to eliminate the lag..hur hur" but im honestly sick of the lag in general.
