  1. Sep 16, 2023 at 9:12 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Looking really good Joel
  2. Sep 16, 2023 at 9:20 AM
    TaquitoBandito
    Joel (AKA Bif)
    :hattip:
    Tripleconpanna likes this.
  3. Sep 16, 2023 at 6:57 PM
    TaquitoBandito
    Joel (AKA Bif)
    Finished the wainscot this morning, switched out the old outlets with Decora styled ones, took a nap, caulked and filled the nail holes for half of the room. Hoping to finish caulking, filling, and then sanding the filling tomorrow. Maybe even get some primer on all of the trim. With some luck, I'll be done with the "remodel" by the end of the week.
  4. Sep 23, 2023 at 2:42 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Popcorn ceiling removal.
  5. Sep 23, 2023 at 3:07 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Nicely done, Sir! :bowdown::bowdown::bowdown:
  6. Sep 23, 2023 at 5:13 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I forgot to put in here, but not long after I installed a motion sensor. It seems common that the light gets left on in here (typically cuz the wife's hands are full and/or she's got 4 little ones at her feet distracting her). I put it in and had some issues with wiring at first, but got it resolved. Also thought the sensor was crap because it wouldn't turn on once I walked in, but it would when stay on detecting motion because I turned it on. It was simply a setting and just the push of a button took care of it. Simple, yet everything I do seems to be more complicated haha.
    I used the one someone suggested in here....so thanks to whomever suggested it.
  7. Sep 23, 2023 at 5:58 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    This was last weekend, but finally installed the hybrid hot water heater (uses heat pump process to heat the water, only uses elements if it needs to). Old water heater energy usage chart was like $740/yr, new one is $108. Did the plumbing in pex-a...like it infinitely more than CPVC...12 fittings with no leaks, that's a new record for me!
  8. Sep 23, 2023 at 6:15 PM
    that was my suggestion. You’ll like it. I put them in:
    Main floor 1/2 bathroom
    Kitchen pantry
    Master walk in closet
    Daughters walk in closet
    Garage
    I may add it to the laundry room too.
    I put a dimmer in the master toilet (1/2?) area too so when I get up to pee, it doesn’t wake her. Of course I have dimmers in living room and loft too, but thought the master bath would be a good fit for it
  9. Sep 23, 2023 at 6:18 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :fistbump:
    I've got dimmers and 3 way switches in quite a bit of the house. Sensors may get added go a few other rooms soon. Lots are limited for different reasons, but I have a feeling we're gonna add some soon to others
  10. Sep 23, 2023 at 7:13 PM
    SwitchThrottle
    My brother in law picks on me because I put dimmer switches on almost every room.
    I have a motion detector switch that I need to install in my mom's garage.
  11. Sep 23, 2023 at 7:36 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    You know there's been moments he's wished he had a dimmer switch in a room that he's mocked you for too lol
  12. Sep 23, 2023 at 9:05 PM
    TaquitoBandito
    Joel (AKA Bif)
    Thanks Ron - I'm almost done! Need to paint the doors and put a 2nd coat on half the trim.
  13. Sep 23, 2023 at 10:19 PM
    It's a little shocking the outlet by the shower passed code inspection.
    Your wife did an amazing job on that remodel. Tell her for us. Something I hope she is proud of.
  14. Sep 24, 2023 at 5:22 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    Did a shop improvement.
    I got a Craftsman 60 gal compressor a couple years ago, got it wired up and working out behind my shed. Finally got around to plumbing the inside.
    I put way too much thought into doing this over the years and ended up using this product for the piping.
    ADCreHfwh-GAGBwm-HUql0JEkgy7GHLyuSVvrwGx_f71e344981066df19880f7f399587f879cec11d2.jpg
    To transition into the shed I used black pipe with a quick connect for easy maintenance.
    ADCreHfIBGMnwxMoAcaZkCLhI9je3bM4UVlF7xXj_88ac594de79f6bb368c562a46dd52bf8adb84b14.jpg
    ADCreHegwrrEYaTv1mttRdPh4vMrsM4Qdvlp6keM_a90f474cf694f52bb465eb20905c786a9665b726.jpg
    The precut pipe is easy to work with but I wanted the flexibility of the pipe. One of my hobbies is scale models and I use airbrush for painting, that's why the other pressure regulator.
    ADCreHetJA3_2TNYNHdRLO9syDQXLT80_A92cPx7_32f9d966c848f8201d30134784afe49dfbb72a46.jpg
    It's a bit out of reach from my bench but I used a bigger gauge so i can read it, ok it's crooked but that's how it lined up. I'm ok with that. I used Loctite thread lock to seal the threads, testing this out before I got to far it sealed up nicely. Fella on youtube did it so how can I go wrong? I'm going to put pressure on it tomorrow, wish me luck.
  15. Sep 24, 2023 at 6:54 PM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    :bowdown:
    Looks beautiful!!! Great job...
    -T
  16. Sep 25, 2023 at 6:45 PM
    Moon Puppy
    Bob
    2020 Tundra Limited
    To quote my self, I did pressure and leak test today. Cranked up the pressure regulators and squirted windex on the joints. Not a leak anywhere!
  17. Sep 26, 2023 at 10:21 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Had the concrete guy bring in a load (1.5 cu yd) of river rock to fill the French drain. I did have a skin on the perforated pipe but also added a layer of weed blocking fabric over it before adding the rock to keep dirt out. A before and after photo (different days). An hour after we finished a thunderstorm came in with a LOT of rain, and the drain worked well, no pooling on the driveway nor grass. Success.
  18. Sep 27, 2023 at 2:24 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    how old is the pool?
    saltwater pool?
    TaquitoBandito likes this.
  19. Sep 27, 2023 at 2:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    Started out replacing seals in my pool pumps but ended up buy more parts due to extensive corrosion of several components. A pool owners life.
    Moon Puppy and TaquitoBandito like this.
  20. Sep 27, 2023 at 2:27 PM
    bfunke
    Mid-1980s pool. Chlorine.
    Fotnot and TaquitoBandito like this.
  21. Sep 27, 2023 at 3:55 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    So many home improvement projects on the list at the moment...but like an idiot I decided to help out my former employer by working a little extra after hours and on Saturdays. Good people and company, plus a little extra cash, so I don't regret it, but it does limit time I could spend working on the house and truck projects.
    I have a room left in my whole house reflooring project, then need to install quarter round moulding throughout the house. Some rooms to repaint. Light fixtures to update throughout the house. Siding in the back that has a bit of damage on the bottom couple of rows.
    Thankfully that extra work I'm doing is for home builders and I'm able to get some of the things I need that would otherwise have been thrown out despite being brand-new (light fixtures, a few of the Hardie plank pieces that I need). Now I just need time!
  22. Sep 27, 2023 at 4:21 PM
    NewImprovedRon
    Ron
    NW Arkansas
    Looks great!
  23. Sep 30, 2023 at 12:06 PM
    TaquitoBandito
    Joel (AKA Bif)
    Finished the dining room earlier this week. Curtains just came in today and pictures need to be hung. But it’s DONE.
  24. Sep 30, 2023 at 12:26 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks great. :thumbsup:
  25. Sep 30, 2023 at 2:05 PM
    NewImprovedRon
    Ron
    NW Arkansas
    You have skills, Sir! :bowdown::bowdown::bowdown: Nicely done!
  26. Sep 30, 2023 at 2:12 PM
    Azblue
    The Dirty T ( ^_^)_且
    You missed a spot.
  27. Sep 30, 2023 at 2:13 PM
    TaquitoBandito
    Joel (AKA Bif)
    You aren’t supposed to look that close, dammit.
    jewsNbrews and Azblue[QUOTED] like this.
  28. Sep 30, 2023 at 6:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    :101010:
    seriously awesome work
  29. Sep 30, 2023 at 6:50 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Nice job.
    I think we have the same corner cabinet.
  30. Sep 30, 2023 at 7:00 PM
    Great job Joel.:thumbsup:
