Blue disk, spacer, or retainer?
Discussion in '1st Gen Tundras (2000-2006)' started by Trundtrk, Sep 15, 2023.
  1. Sep 15, 2023 at 10:24 AM
    Trundtrk
    Trundtrk [OP] New Member
    Found on floor, driver side after friend drove truck. Can't find where it may have came from. Does anyone recognize it?20230913_183751.jpg
  2. Sep 15, 2023 at 12:02 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Hard to even guess without just a little more info.
    What year tundra, is that the color of your inside trim, is that on a paper towel and about the size of a quarter....?
    More info please.
    If paper towel, it's looks similar to what wife buys and appears with a qtr as reference, it's about size of your plastic piece.
    shifty` likes this.
  3. Sep 15, 2023 at 12:37 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Look to see if your brake light switch rubber bumper/stop is still there.
    If manual trans could also be clutch cancel or start switch bumper.
    BubbaW likes this.
  4. Sep 15, 2023 at 12:38 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    You sure it isn't something that stuck to the bottom of his shoe and ended up on the truck floor? It looks similar to a knock out plug on blue plastic electrical box.
    The Black Mamba likes this.
  5. Sep 15, 2023 at 12:44 PM
    I was thinking that, or even the ring around a roofing nail, or the stop for the brake light switch. But the center bit is weird looking.
  6. Sep 15, 2023 at 12:59 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Ah Hah Kemosabe....something like this
    assassin10000[QUOTED] likes this.
  7. Sep 15, 2023 at 1:35 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I was thinking blue ratchet spinner disk from the super cheap ratchet sets at harbor freight. :D
  8. Sep 15, 2023 at 2:23 PM
    Trundtrk
    My brake lights work, black bumper stop is in place. Will look to see if parking brake has a bumper stop. Thanks for suggestions. Thought it might be from outside of truck, but I think with the many tiny pieces, most likely from inside truck.
  9. Sep 15, 2023 at 2:42 PM
    Trundtrk
    It is from the brake pedal assembly, but not the light switch. It's on the other side of lever, appears it's suppose to push what looks like a plunger or piston. Thanks for the inputs.
  10. Sep 15, 2023 at 3:42 PM
    Trundtrk
    Not sure what switch this is, the silver plunger pops out when key is turned on.
  11. Sep 15, 2023 at 4:58 PM
    The one on the right is the one that popped, is it not for the brake lights? I thought it was shift lock for a sec, but I feel like that may be in the column?
    One on the left is on e-Brake pedal, right?
  12. Sep 15, 2023 at 5:32 PM
    Trundtrk
    The left is e-brake. And you were right about it being the shift lock. I tested it and it not shift if I hold plunger in. The brake light switch is not shown in this pic., but it's working and has the stop pad. So I need to get the bumper pad for the shift lock. Thank you for your help.
    shifty` likes this.
  13. Sep 15, 2023 at 5:35 PM
    Well damn, I guess I shouldn't have deleted my initial reply that just said "SHIFT LOCK". I wasn't 100% sure.
    You know how to look up that part, right?
    (Hint: Use the top few bullet points here)
  14. Sep 15, 2023 at 7:02 PM
    Trundtrk
    Think I stumbled across it on dealer site as 47131. Looked at a few brake pedal diagrams and think I got it. But will check out your hint to verify. Thanks.
