General Supercharger Thread
  1. Sep 13, 2023 at 11:52 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Do you need to remove the blower to fix the coupler?
  2. Sep 13, 2023 at 11:53 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    The magnuson is a bit of a bitch for two reasons: the first being the bolts holding it down are a pain to reach, I took a wrench and cut and welded it up to make it easier to get to them, the second is the fuel lines in the back can be annoying to pull. Both are pretty minor, just require a bit of patience. You only need to do the bolts so you can lift the snout and unbolt the snout, I don't think you need to pull the fuel lines for that. The snout comes off with 6 or 8 bolts from the front, then the coupler is just a plastic block you pull and slap back in.
    As far as rebuilding, probably wouldn't hurt if it has a lot of mileage which if it's factory blown I'd expect it does. A rebuild from SCOL is about $1200 and is new fluids and bearings and the whole 9 yards.
    Mdl and Saltyhero13 like this.
  3. Sep 13, 2023 at 11:56 AM
    snivilous
    SW UT
    If you live where you say you do in New Mexico, that would also be a good time to swap the pulley out since it's a lot easier with the nose removed. A smaller pulley will make up for the elevation losses and in my opinion are all but mandatory if you live above 2500ft or so since there starts to be a lot of power left on the table since a supercharged engine loses power from elevation twice as fast as a normal engine.
    Mdl, Saltyhero13 and reywcms like this.
  4. Sep 13, 2023 at 11:57 AM
    STravis
    Travis
    Ruidoso, NM
    It's got 137,000 miles, so not crazy but probably worth the money to rebuild I guess.
    Is there a writeup anywhere for the snout rebuild or pulling the blower?
  5. Sep 13, 2023 at 11:58 AM
    STravis
    Travis
    Ruidoso, NM
    A pulley and new tune would definitely be on the list of things to do for sure. I live at about 7300 feet.
  6. Sep 13, 2023 at 11:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  7. Sep 13, 2023 at 11:59 AM
    snivilous
    SW UT
    https://superchargersonline.com/202...uson-supercharger-for-the-5-7l-toyota-tundra/
    I would get the smallest possible pulley then
    Saltyhero13 and STravis[QUOTED] like this.
  8. Sep 13, 2023 at 12:08 PM
    STravis
    Travis
    Ruidoso, NM
    Awesome, thanks for the great info. I'm almost tempted to pull the supercharger and put it on my other truck but that one will get a bigger blower on the future.
    One more question, the guy said it started rattling recently, any issues driving it home from AZ with the rattle? It's about 6 hours or so.
    HulkSmurf14 likes this.
  9. Sep 13, 2023 at 12:12 PM
    snivilous
    SW UT
    I wouldn't be concerned at all. The rattling is from slop in the coupler, essentially it has extra backlash so the rattling is just the input shaft tapping back and forth against the coupler/rotors. It won't hurt anything, and usually it's only noticeable at idle.
    Mdl and STravis[QUOTED] like this.
  10. Sep 13, 2023 at 12:16 PM
    STravis
    Travis
    Ruidoso, NM
    Awesome. All what I needed to hear haha. I'm gonna check it out this weekend and see what I think.
    Thanks for the info.
  11. Sep 13, 2023 at 12:20 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I would get @snivilous pulley. Sorry for sending that prospeed one. That's a new release from prospeed.
  12. Sep 13, 2023 at 4:53 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I don’t think anyone posted this but there is a used TRD blower for sale in NJ for $3500 obo
  13. Sep 13, 2023 at 4:58 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Guranteed scam seen a lot of those floating around. My buddy almost lost money on one of those deals.
  14. Sep 13, 2023 at 5:01 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    That was my instinct as well.
    reywcms[QUOTED] and Mdl like this.
  15. Sep 13, 2023 at 5:03 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    PXL_20230913_235819760.jpg Wideband installed, would have been pretty seamless until my 2nd weld pass on the sensor bung was a little hot. Had to drill out the plug and retap the threads.
    Did a gross fuel adjustment on the PE table for ~10:1 afr yesterday. Just did a quick drive to meet friends and it's 9.2-9.6:1 at WOT, very close, and cleaned up the little bit of pre-ignition I was getting. I'll try to log tomorrow am before heading to the airport. Then start playing with timing tables based on those logs.
    reywcms, e30cabrio, Mdl and 1 other person like this.
  16. Sep 13, 2023 at 5:05 PM
    Saltyhero13
    That's neat!
    "Why is you clock always changing time?"
    Mdl, Silver17 and Tripleconpanna like this.
  17. Sep 13, 2023 at 5:07 PM
    VWTim
    Corvallis, OR
    My wife is going to absolutely hate it. Already planning a piece of velcro webbing to cover the screen.
    reywcms and Saltyhero13[QUOTED] like this.
  18. Sep 13, 2023 at 5:07 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I think it's his 0-60 time :laugh:
    Mdl likes this.
  19. Sep 13, 2023 at 5:14 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve seen that one pop up on FB for my area as well. All my instincts say it is legit and I like to think I’m good at calling them. A FB profile active since 2013, 260 friends, pics of vehicles on his page that match some parts he is selling, and no mention of shipping. Worth a look to anyone interested IMO.
    nags, Mdl and Saltyhero13 like this.
  20. Sep 13, 2023 at 5:22 PM
    ZPhilip
    Philip
    West Chester, PA
    I thought the same. I wouldn’t share a scammy looking ad.
    Mdl likes this.
  21. Sep 13, 2023 at 5:25 PM
    Saltyhero13
    1/4 mile run.....in Mexico of course!
  22. Sep 13, 2023 at 6:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are you also annoyed when people say OH when they mean ZERO? :rofl:That's the one that gets me. :anonymous:
  23. Sep 13, 2023 at 6:17 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I think for most of us it is annoying because the military told us it was and we agreed.
    Tripleconpanna likes this.
  24. Sep 13, 2023 at 6:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When reciting the time?
  25. Sep 13, 2023 at 6:29 PM
    1UP
    1UP Truck Gang
    Anytime speaking the number 0.
  26. Sep 13, 2023 at 6:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oh....:rofl:
    1UP[QUOTED] and Tripleconpanna like this.
  27. Sep 13, 2023 at 6:39 PM
    snivilous
    SW UT
    That one doesn't stand out to me, but I do say zero :D
    Wynnded[QUOTED] likes this.
  28. Sep 14, 2023 at 6:59 AM
    nags
    nags New Member
    Jeez, haven't been here in a while. That was a lot to catch up with.
    e30cabrio, snivilous[OP] and reywcms like this.
  29. Sep 14, 2023 at 7:02 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    77.5mm ordered via Harrop.
    it will ship once they get them in stock.
    which is perfect because my truck is delayed another week due to having to paint more of the truck & replace the scratched passenger rear window (tornado shit).
    Still rockin' the highlander!
  30. Sep 14, 2023 at 7:03 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
