Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Aug 29, 2023 at 2:56 AM
    #1081
    18" TRD Off Road Wheels
    :yes:
  2. Aug 29, 2023 at 9:20 AM
    #1082
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    Can't wait to see the videos!
    BlueRibbon4x4[OP] likes this.
  3. Aug 29, 2023 at 12:15 PM
    #1083
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    I think I’m gonna start a new YouTube channel and upload the videos there. I have videos already of the build.
  4. Aug 29, 2023 at 12:17 PM
    #1084
    AthenaOffroad
    Niko
    Let me know when you do! I'll sub I have several up of mine already. But just the stuff I've done already + my ATV stuff
  5. Aug 29, 2023 at 1:11 PM
    #1085
    BlueRibbon4x4
    Geno
    I’ll sub too, what’s your channel?
  6. Aug 29, 2023 at 1:54 PM
    #1086
    AthenaOffroad
    Niko
    Athena Offroad
  7. Aug 29, 2023 at 5:38 PM
    #1087
    BlueRibbon4x4
    Geno
    Clear coat applied, almost there…
  8. Aug 30, 2023 at 5:01 PM
    #1088
    BlueRibbon4x4
    Geno
    Installed! We’ll wait till later for some night shots and video. Chase lights are up and running. Good to go!
  9. Aug 30, 2023 at 5:14 PM
    #1089
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Nice work! Looks good !
  10. Aug 30, 2023 at 5:24 PM
    #1090
    BlueRibbon4x4
    Geno
    Thanks!!
  11. Aug 30, 2023 at 6:40 PM
    #1091
    biebs96
    PA
    Bumper looks good. Not sure why you took such poor photos of it.
  12. Aug 30, 2023 at 8:22 PM
    #1092
    BlueRibbon4x4
    Geno
    :rofl: Thanks !
    GODZILLA and biebs96[QUOTED] like this.
  13. Sep 2, 2023 at 12:48 PM
    #1093
    BlueRibbon4x4
    Geno
    I posted earlier about my compressor going out. After driving through a heavy rain storm the compressor wouldn’t turn off. I yanked the fuse and saved the problem for later.
    So my mistake this morning was not reinstalling the fuse and making sure it works. I uninstalled it, opened her up, and rewired everything that is inside the switch compartment. The compressor comes wired with a switch, and a circuit breaker. But inside the compartment, everything is connected with wire nuts. I just soldered and shrink tubed everything, tested it, and it works great. I didn’t take any damn pictures, but I redid the air lines under the hood to remedy the slow air leak I have. The compressor turns off at 75psi via an installed air pressure switch, it kicks on approximately every two minutes for a few seconds, letting me know there’s a small leak. Right now it’s holding tight, and I’m happy to have my air back in the truck.
  14. Sep 4, 2023 at 7:37 AM
    #1094
    BlueRibbon4x4
    Geno
  15. Sep 5, 2023 at 5:41 PM
    #1095
    BlueRibbon4x4
    Geno
    Next project - match the tails. I grabbed a cheapo third taillight on Amazon, and with a little heat gun action, got it apart. You can really see why these leak. It came right apart. The one I wanted had an ugly red stripe down the middle, so it got sanded off and once the clear goes on it should be perfectly clear.
    Just a sneak peek of what they’re getting and we’re on our way.
  16. Sep 5, 2023 at 5:44 PM
    #1096
    AthenaOffroad
    Niko
    Are those the same lights you used as your chase lights?
    RobertD and BlueRibbon4x4[OP] like this.
  17. Sep 5, 2023 at 8:17 PM
    #1097
    BlueRibbon4x4
    Geno
    Yes, I had a pack of four.
  18. Sep 7, 2023 at 9:20 PM
    #1098
    BlueRibbon4x4
    Geno
    Moving along on the third brake light. Drilled through the board to pass the chase light wires through, and shaped the chase light.
    Then I epoxied the lights to the bezel and filled the top area with fiberglass bondo.
    IMG_8891.jpg IMG_8892.jpg IMG_8893.jpg IMG_8894.jpg IMG_8895.jpg IMG_8900.jpg IMG_8905.jpg
  19. Sep 8, 2023 at 8:27 PM
    #1099
    BlueRibbon4x4
    Geno
    Little more bondo to smooth out the chase lights. Needs another smooth coat, primer, them one more.
  20. Sep 8, 2023 at 9:36 PM
    #1100
    BlueRibbon4x4
    Geno
    Primer down. Actually doesn’t look like an afterthought. Still needs one more coat of body filler.
  21. Sep 8, 2023 at 9:40 PM
    #1101
    RobertD
    Robert
    DFW, Texas
    Looks so good!
  22. Sep 9, 2023 at 5:08 AM
    #1102
    BlueRibbon4x4
    Geno
    Thanks! Honestly I was disappointed how it looked before. That gap on the inside was really bugging me. Glad it came together.
    RobertD[QUOTED] and GODZILLA like this.
  23. Sep 9, 2023 at 5:51 AM
    #1103
    RobertD
    Robert
    DFW, Texas
    And how many folks get their face a few inches from your 3rd brake light to have noticed? Oh thats right, NONE!
    But I do understand. Glad it came together.
    bulldog93, RainMan_PNW and GODZILLA like this.
  24. Sep 9, 2023 at 6:27 AM
    #1104
    BlueRibbon4x4
    Geno
    :rofl::rofl:
    yeah, yeah you’re right. But what about the close up photos?
    GODZILLA and RobertD[QUOTED] like this.
  25. Sep 9, 2023 at 6:29 AM
    #1105
    BlueRibbon4x4
    Geno
    Got the last coat of filler, primer, and a coat of bluuuuuue.
  26. Sep 9, 2023 at 9:38 PM
    #1106
    BlueRibbon4x4
    Geno
    Blue Ribbon and 2K clear. The lens is next, and will get attached in a few days when the clear is gassed off.
  27. Sep 12, 2023 at 6:53 PM
    #1107
    BlueRibbon4x4
    Geno
    Paint paint paint.
    Applied a smooth bead of silicone around the painted area into the channel.
    Taped off the inside area of the lens and clamped the lens onto the bezel.
    Sprayed the plastic adhesion promoter after scuffing with a 7447 red scotch brite.
    Sprayed with 8T5 Blue Ribbon
    2k clear is hopefully tonight.
    RobertD and TRDFerguson like this.
  28. Sep 12, 2023 at 6:56 PM
    #1108
    biebs96
    PA
    Can’t tell, is the black housing color matched as well?
  29. Sep 12, 2023 at 7:00 PM
    #1109
    BlueRibbon4x4
    Geno
    Yep. All of it.
    biebs96[QUOTED] likes this.
  30. Sep 12, 2023 at 7:19 PM
    #1110
    BlueRibbon4x4
    Geno
    Masking peeled. Ready for clear.
