  1. Sep 9, 2023 at 4:41 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Toyota made black knobs but not sold separately.
    https://www.ebay.com/itm/1247901051...3vLFqmVS6m&var=&widget_ver=artemis&media=COPY
    Also I went with one of these when I went blaaaaaaccccckkkkk
    Pic for clarity
  2. Sep 9, 2023 at 5:05 PM
    EmergencyMaximum
    Interesting. That 'feature' was standard on my work package:laugh:
    joseph_womack likes this.
  3. Sep 9, 2023 at 5:27 PM
    Shanet421
    San Diego,CA
    What’s that? 4x4?
  4. Sep 9, 2023 at 5:57 PM
    EmergencyMaximum
    No, black knobs.
    MTRock and Shanet421 like this.
  5. Sep 9, 2023 at 9:03 PM
    Retroboy1989
    Northern Utah
    Same size. 275/60r20
  6. Sep 9, 2023 at 9:38 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I never knew this. I've been scoping the ajt knobs but also debating painting them as well to be the cheap ass I am. Good to know I have options. Thanks for the info @Shanet421
    Also loving your blaaaack out look. Dark side is the way to go.
    Shanet421[QUOTED] likes this.
  7. Sep 10, 2023 at 6:16 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    PSA. Be sure to service that driveshaft. PO let this one go a little past scheduled service...
  8. Sep 10, 2023 at 10:03 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Oof! That’s rough! Will you have to replace a yoke as well?
  9. Sep 10, 2023 at 1:23 PM
    alee891
    Now/here
    Shitbox
    Somehow isn't wallowed out, so we're good there. New carrier bearing tho to compliment the ujoints.
    PolishedTRD[QUOTED] likes this.
  10. Sep 10, 2023 at 3:34 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
  11. Sep 10, 2023 at 3:46 PM
    Retroboy1989
    Northern Utah
    How many miles?
  12. Sep 10, 2023 at 4:13 PM
    alee891
    Now/here
    Shitbox
    232k
  13. Sep 10, 2023 at 6:08 PM
    AdamK
    AdamK New Member
    Finally finished my dual battery setup - an Optima Yellowtop D34/78 powering my ARB compressor w/1.5G tank and always-on USB charging ports and other (eventual) accessories through a Blue Sea ML-ACR charge controller and Blue Sea SafetyHub 100 Fuse Block for distribution. Been inching along on this for over six months - feels good to get it wrapped up!
  14. Sep 10, 2023 at 6:13 PM
    Shanet421
    San Diego,CA
    :worthless:
    Mountun Goat and joseph_womack like this.
  15. Sep 10, 2023 at 6:38 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Seriously? You did a dual battery set up in a Tundra and didn't show pictures of it? That is a two beer foul.
  16. Sep 10, 2023 at 7:21 PM
    Retroboy1989
    Northern Utah
    232k x 629 tire revs per mile x 4.3 rear end ratio =
    627 million revolutions.
    It lived a full life.
  17. Sep 10, 2023 at 7:35 PM
    AdamK
    AdamK New Member
    @Tipsovr
    Fair enough, here's the whole system ... it's probably not exactly what you're thinking it'd be for a dual-battery setup.
    The 2nd battery is in a rack in the void in front of the right rear tire. I sorted this bit out last weekend and yesterday, making a jig, sorting out brackets, and welding to the frame.
    The 1.5G Viair tank is in the opposite void in front of the left rear tire. There is a chuck off the tank accessible against the frame above the left-rear tire. This went in months ago.
    Inside we have the ML-ACR controller switch on the right of the column and the ARB Single switch on the left. I didn't get a picture of the USB ports, but they're nothing special ... mounted in a blank to the right of the OEM USB port.
    This is the Blue Sea ML-ACR charge controller and Blue Sea SafetyHub 100 distribution block, and a relay box on a lightly modified ********* mount. This was installed after the compressor and tank, but before the interior work.
    Finally, here is the ARB compressor on the bracket from the company whose name I can't remember (anyone know?) with my homemade manifold tucked behind and another chuck available in this location. This was the first thing to be installed - I'm estimating about six months ago.
    Trying to figure out what I want to tackle next - kind of fancy the idea of a Demello hidden winch mount, but am in no hurry.
  18. Sep 10, 2023 at 7:47 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Love the battery mount. I have a group 24 AGM in a compartment in my bed toolbox, but have been considering that location when it poops out and needs to be replaced.
    Fwiw, the Demello winch bracket is slick, been using mine for about 2 years.
    AdamK[QUOTED] likes this.
  19. Sep 10, 2023 at 10:24 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    And battery cables are run from the main battery to secondary? All tucked near the frame? How thick of cables?
    Everything looks great, never even thought about tucking the battery there, I did consider an air tank though; haven’t gotten around to it yet
    Tipsovr likes this.
  20. Sep 11, 2023 at 6:28 AM
    AdamK
    AdamK New Member
    @joseph_womack
    Thanks, and yes, there is a lot of usable space in those voids, and they’re well hidden from any casual glance, and reasonably protected.
    The secondary battery cables are size 1/0 and routed down into the frame from the engine bay back to the battery. They’ll handle all the amps the battery is cable of delivering given the distance - about 20’ for my RCSB. The batteries are tied together through the Blue Sea ML-ACR which latches and unlatches depending on charge level and other conditions to ensure load on one battery doesn’t draw down both.
    joseph_womack[QUOTED] likes this.
  21. Sep 11, 2023 at 6:51 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Semi-Completed a brake job yesterday. Replaced both front Calipers, I thought they were seized or frozen as they started making noise. Turned out it was my rear brake that was freezing. Got a damaged rotor I'll have to get turned today...
    joseph_womack and AdamK like this.
  22. Sep 11, 2023 at 9:07 AM
    aelarson
    aelarson New Member
    AZ
    2021 1794 Tundra (Silver Sky Metallic)
    Well, the trip to CO started with a bang in Ames, IA (which is funny because I went to school at Iowa State for 5 years and drove this road a million times). A lady in her Kia minivan pulled out from the right lane in front of me in the left lane and decided to come to a complete stop while I was doing highway speed with 3,500 lbs. of cargo/trailer. I went full ABS and managed to trim 20-25mph off, but still made contact at around 50-55mph, minivan was probably doing 15-25mph. The eBay bumper took the hit like a champ and saved the trip. Two of the SS5's lights still work, two broke. All the SS3's are functional. No damage to the radiator, trans cooler, fans, belts, etc. Everything functioned as it should, so we kept the nose in the wind. Her minivan took a big hit, I'd imagine it's close to be totaled out. Overall, no one was hurt and the Tundra kept us safe.
    We still made it to CO to elk hunt and had a blast. No meat in the cooler, but that's hunting. Our neighbor at base camp also had a Tundra, we were in good company. I put 40 miles on the boots and had some close opportunities, but couldn't get an arrow off.
  23. Sep 11, 2023 at 10:22 AM
    alee891
    Now/here
    Shitbox
    Glad you made it out alright. What unit(s) were you in?
    aelarson[QUOTED] likes this.
  24. Sep 11, 2023 at 10:24 AM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    IMG_4873.jpg Decided the air bags were a bit overkill for what I tow….only around 3500lbs. Pulled the air bags and put in Timbrens. Drives like butter empty. Hooking up the trailer and SxS soon for the real test.
  25. Sep 11, 2023 at 11:24 AM
    aelarson
    aelarson New Member
    AZ
    31. Steep, Steep, Steep. Looked like billy goat country, not elk country!
  26. Sep 11, 2023 at 11:41 AM
    Cmende
    Cmende New Member
    California
    2013 Rock Warrior
    Dirt King boxed upper and lower control arms. Fox 2.5 shocks front and rear. R1 concepts drilled and slotted rotors. Baja Designs XL80 on the A-pillar and Baja Designs Squadron Pros in the fogs.
    Mountun Goat and D4x4TRD like this.
  27. Sep 11, 2023 at 6:57 PM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Sorry to see but glad to hear you and others are safe! Gives me some reassurance on this bumper's quality, I've always been curious how it would hold up in an accident. I take it you don't have a winch in yours? I'm wondering if that would have made the difference with mine-I could see it being pushed into the radiator and leave me unable to continue the trip.
  28. Sep 11, 2023 at 7:44 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    @Cmende I have the east detailing wrap on mine. Did it about a year ago. Holding up great.
  29. Sep 11, 2023 at 9:16 PM
    joseph_womack
    Joe
    Louisiana
  30. Sep 11, 2023 at 11:58 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Added Form lighting headlights.
