A build for speed and handling, I know it sounds crazy.
Discussion in '2.5 Gen Builds (2014-2021)' started by Fastlane47, Feb 5, 2021.
  1. May 28, 2023 at 4:26 PM
    #271
    Fastlane47
    Fastlane47 [OP] New Member
    Maryland
    2018 Platinum
    I'm still waiting for my long tube AR header's to come in from PS, but the 2.2 pulley is here, new belt and I'm also going to change out the idler pulley as well. Hopefully this pulley will keep the boost at 11psi with the header's. PXL_20230528_232302113.jpg
    reywcms and M3Tundra-JK like this.
  2. May 28, 2023 at 5:06 PM
    #272
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes! You should stuff that bigger airfilter in the prospeed intake. It could use it
  3. May 28, 2023 at 5:12 PM
    #273
    Fastlane47
    Maryland
    2018 Platinum
    What filter? The one that's in it is pretty big.
  4. May 28, 2023 at 5:14 PM
    #274
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    chugs and Fastlane47[OP] like this.
  5. May 28, 2023 at 5:18 PM
    #275
    Fastlane47
    Maryland
    2018 Platinum
    I think mine came with that filter, looks the same. Maybe??PXL_20230529_001715063.jpg PXL_20230529_001701902.jpg
  6. May 28, 2023 at 5:43 PM
    #276
    Fastlane47
    Maryland
    2018 Platinum
    On the way, thank you for the info, I think just being able to get air in at the front filter will help too.
    reywcms likes this.
  7. May 28, 2023 at 6:18 PM
    #277
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Definitely! So the one that came with it is about 6” moving to a 9” and open top should for sure help. Let me know how it goes!
  8. Jun 8, 2023 at 6:13 AM
    #278
    Fastlane47
    Maryland
    2018 Platinum
    Big difference, thank you. PXL_20230607_211718790.jpg PXL_20230607_213307869.jpg
  9. Jun 8, 2023 at 6:29 AM
    #279
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Did you notice any difference after a drive?
  10. Jun 8, 2023 at 6:31 AM
    #280
    Fastlane47
    Maryland
    2018 Platinum
    This morning it was cool about 50, it wanted to run!
    reywcms likes this.
  11. Jun 8, 2023 at 6:31 AM
    #281
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Boom!
  12. Aug 14, 2023 at 5:17 PM
    #282
    Fastlane47
    Maryland
    2018 Platinum
    Quick update - I have a 2.2 ready to go with a new belt from @snivilous, I had to cancel my ARH header order from Prospeed, I ordered them in March, was told 10-12 weeks, at week 13 I had to call them for an update, they said they're not even manufactured yet. I went with a different header company and they should be here by the end of the month. While I was waiting, I also ordered a Powertrax rear differential. It looks like this fall and winter I will be starting the engine build. I plan on doing cams, valves, springs,ported heads and a built bottom end. I need to figure out if I'm staying with the stock bore, or going to a 6.0.
    reywcms, Saltyhero13 and snivilous like this.
  13. Aug 14, 2023 at 5:45 PM
    #283
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Wicked! Brian crower stroker is my plan and leave the heads alone with upgraded hardware etc. can’t wait to see what you end up doing.
  14. Sep 5, 2023 at 2:10 PM
    #284
    Fastlane47
    Maryland
    2018 Platinum
    The header's came in today. I also order my short block from XAT Racing, Andrew knows his stuff when it comes to the 5.7PXL_20230905_204145685.jpg
    nags, WSDMetal, TOYOTARIG and 7 others like this.
  15. Sep 5, 2023 at 2:11 PM
    #285
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Oh snap! What specs did you go with for the short block?? I'm planning to do the same with the BC stroker.
    Mdl likes this.
  16. Sep 5, 2023 at 2:14 PM
    #286
    Fastlane47
    Maryland
    2018 Platinum
    I went with stock size, Manley position and BC rods, ARP main and head studs, I also added the upgraded oil pump and the ATI dampener pulley system, and upgraded the Radiator. They said its about 30 days out.
  17. Sep 5, 2023 at 2:19 PM
    #287
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    30 days not bad at all! Did you drop the compression at all? Can't wait to see this come together.
  18. Sep 5, 2023 at 2:23 PM
    #288
    Fastlane47
    Maryland
    2018 Platinum
    A little, 10.01
    Mdl, Saltyhero13 and reywcms like this.
  19. Sep 5, 2023 at 2:28 PM
    #289
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    That’s awesome, did he find you a donor block then? And is your plan to just run the stock one until it blows or swap it out before it blows and up the boost big time?
  20. Sep 5, 2023 at 2:30 PM
    #290
    Fastlane47
    Maryland
    2018 Platinum
    No, they are building it for me, I will send them my core, less down time for my shop. I wanted to build it in house, but the machine shop said it would take 3-6 weeks to balance everything. This way once I have all the parts, we won't need to wait on anything else.
    Mdl and reywcms like this.
  21. Sep 5, 2023 at 2:34 PM
    #291
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Is that the only air intake into the box?
  22. Sep 5, 2023 at 2:35 PM
    #292
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No that's an additional hole. There's another one from the factory
  23. Sep 5, 2023 at 3:31 PM
    #293
    Fastlane47
    Maryland
    2018 Platinum
    I plan next year to get a bigger blower and a built transmission. For now, install the 2.2 and lean it out a bit with the built bottom end.
    Mdl, Silver17[QUOTED] and reywcms like this.
  24. Sep 5, 2023 at 4:37 PM
    #294
    Saltyhero13
    Saltyhero13 Throbbing Member
    Factory hole is to the left/forward in the stock position. That is rey's SABM. Someone posted the recommended cut for that box which basically removes all the material between the SABM and stock holes.
  25. Sep 5, 2023 at 4:48 PM
    #295
    Silver17
    Eastern PA
    Like a taint removal?
    Mdl, reywcms and Saltyhero13[QUOTED] like this.
  26. Sep 5, 2023 at 4:55 PM
    #296
    Saltyhero13
    I see I am in the company of a fellow taint connoisseur. :101010:You won me my word bingo for the day.
    I think the technical term is airbox taint.
    I'm lucky I didn't have fluid in my mouth when I read your comment but that is a topic for another day on a different forum.
  27. Sep 5, 2023 at 5:44 PM
    #297
    Silver17
    Eastern PA
    My apologies @Fastlane47, it appears we have tainted the waters of this thread.
  28. Sep 5, 2023 at 6:27 PM
    #298
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    lol taint removal
  29. Sep 6, 2023 at 2:40 AM
    #299
    Fastlane47
    Maryland
    2018 Platinum
    Nice work sir
  30. Sep 6, 2023 at 2:40 AM
    #300
    Fastlane47
    Maryland
    2018 Platinum
    No sir, all good.
    Saltyhero13 likes this.
