Power rear view mirror
Discussion in '1st Gen Tundras (2000-2006)' started by WestCoast Fl, Aug 30, 2023.
  1. Aug 30, 2023 at 1:46 PM
    WestCoast Fl
    WestCoast Fl [OP] New Member
    Mick
    2006 Tundra Double Cab
    Bilstien adjustable shocks XD series 17" wheels
    So my DC mirror is looking pretty crappy. I looked on ebay they are showing a auto dimming with digital compass available for about $80. Mine is a xsp type. I'm curious if my truck will have a female harness plug type thing behind the headliner for power. If anyone has any experience with doing this please share any information you might have. Thank you in advance.
  2. Aug 30, 2023 at 1:58 PM
    shifty` Animals and insects don't do drugs
    The direction to info you need is in this sticky thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Cab types and why it matters:​
      • There are 3 cab types for the 1GT: Access Cab ("AC"), Regular Cab ("RC"), Double Cab ("DC"). This is such a key piece of info when asking for advice or help, so be sure you update the truck info in your forum user profile to indicate which cab type you have (and engine, and drivetrain). It'll help others more-easily help you and give advice.
      • The overhead console that has time/outside temperature and/or compass. is another DC-exclusive. NO, that overhead console won't fit in an AC or RC truck without significantly modifying the headliner (at least) and rewiring your truck from the fusebox to roof. If you have a DC but no overhead console, the wiring for that special console may be tucked up in your headliner, check for it!
      • Some DC trucks (but not AC/RC) came pre-wired for an auto-dimming rearview, like the Sequoia. That being said, if you want to add an auto-dimming mirror, with compass, HomeLink garage door opener, outside temp, or whatever else, this post should direct you to necessary details/pictures you need. DC owners may have the wiring tucked into the headliner above the console opening. You may find the temp sensor wiring on the firewall as seen in that post above. AC/RC cab owners need to retrofit; there are OEM harnesses available, but the kits aren't plug 'n play...
  3. Sep 2, 2023 at 12:10 AM
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    My 2005 XSP double cab was prewired for the mirror. It's tucked up in the headliner. Are you in SWFL?
  4. Sep 2, 2023 at 6:21 AM
    WestCoast Fl
    Mick
    Hey actually in the Tampa area. I will definitely look for it. Seems like the features in the Sequoia could work too.
    912 likes this.
  5. Sep 2, 2023 at 6:30 AM
    Read up, pretty sure it's in the reply I linked above, but the Sequoia and Tundra use same connectors but have some of the wiring swapped. @BubbaW has posted in the past exactly which wires are different. One instance was recent, over here: https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1679#post-3293485
    I recommend reading that down, and reading the links in the reply I linked above before jumping on anything. The knowledge you need is here, but it may be a bit of a link-maze to get to it.
  6. Sep 2, 2023 at 7:01 AM
    WestCoast Fl
    Mick
    Okay definitely getting deep on the thread you created, suggested. Looking at 912's speaker install atm. GX460 Might be in my future. Tundra needs paint from the Florida sun. Had I kept it waxed it probably would still look great. So the thing ahead of the sunglasses holder is a trip odometer and what else? Not sure if that is worth the effort. But like the mirror options
  7. Sep 2, 2023 at 7:09 AM
    That "info display" thing in front of the mirror, IIRC, normally has time and temperature, maybe compass? I forget.
    And yeah, if you've got metallic paint, that's one of the topics in that thread I linked in the 2nd reply above. Clearcoat tends to fail in hot/sunny places, especially on the more-horizontal panels (roof, hood, topside of the fender flares, topside of the doors). The solid, non-metallic-paint trucks are almost always single-stage/no clear, like mine, so no pigment under the clearcoat to heat up and help degrade that bond (clear<=>basecoat). I prefer the metallic colors, especially metallic gold, metallic silver, metallic grey like @912 and @abcinv's trucks. But there's only one generation/manufacturer trucks I've owned that had worse clearcoat issues, and that's the 88-98 GM pickups, GMT400 was exceptionally bad.
  8. Sep 2, 2023 at 10:45 AM
    WestCoast Fl
    Mick
    Well I took down the console sunglass thing and didn't find a separate wire for the mirror on my DC. Short of taking headliner down not sure the wire is there. I'd think it would come off the plug controlling the lights. But looking under the hood I did find the temperature plug deal so it must be compatible but maybe through the harness plug with the Sequoia time, trip, thing
  9. Sep 2, 2023 at 11:17 AM
    The OEM wiring kit I bought for installing that mirror included wiring from the mirror area down to the fusebox. And it was a separate wire from the fusebox area to the front of the truck. Not sure it helps, but it's just another tidbit of info.
    I know there were some pics in one of those threads showing exactly where others found the wiring tucked away. Not sure if you found it or not, or how obvious the harness is.
  10. Sep 2, 2023 at 1:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Two years difference but my 04 DC Limited did not have mirror harness. I do have the overhead console that has temp, compass, homelink. When I found an auto dimming mirror at J/Y from a Sequoia, all it needed was positive and negative hookup. The auto dimming mirror with compass should only require neg/pos....the compass is in mirror. I used the below instructions and attached the whole install pdf.
  11. Sep 4, 2023 at 2:42 PM
    WestCoast Fl
    Mick
    Hey was the overhead counsel stock in your DC? I Finished up my mirror today. I'm wondering if the over head counsel would be plug in play on mine. I'd like to be able get the temp thing. Thanks for posting the diagram I'll have to look at mine again.
    BubbaW[QUOTED] likes this.
  12. Sep 4, 2023 at 3:05 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Indeed it was stock.
    According to how many conductors you have in the overhead console connector determines if plug/play. You possibly only have 3 considering the way your asking ?
    Past thread that might help if you don't have proper conductors
    Temp sensor for upper dash/map lights | Toyota Tundra Forum (tundras.com)
    My Stock 04
    Proper conductors/Improper conductors
  13. Sep 4, 2023 at 3:37 PM
    WestCoast Fl
    Mick
    Yeah mine has more than 3 wires. Reading the thred you posted another guy was saying there was a gentex mirror with temp included along with homelink and compass. I think I'll go that route because no moonroof in mine even though I really like the counsel
    BubbaW likes this.
  14. Sep 4, 2023 at 3:42 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If you consider the overhead console, post a good pic of your connector showing a good shot of the colors and pin location. We can tell ya if the 2 temp sendor conductors are there.
    Yeah, the gentex is a good route also since you have pwr and gnd already there.
    WestCoast Fl[OP] likes this.
  15. Sep 4, 2023 at 3:54 PM
    WestCoast Fl
    Mick
    Will try and get a picture of it soon. Any help would be appreciated
