First Tundra DIY oil change, lessons learned
Discussion in '2.5 Gen Tundras (2014-2021)' started by CallsignKodiak, Sep 2, 2023.
  1. Sep 4, 2023 at 3:42 AM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    I like using tech, so I have a note in my iPhone with maintenence details for every vehicle in the family, including commonly-used part numbers, torque specs, and other handy info. I use a different app to record what was done, along with pictures of receipts.
    CallsignKodiak[OP] and bulldog93 like this.
  2. Sep 4, 2023 at 4:36 AM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    what app do you use to record maintenance performed and receipts?
  3. Sep 4, 2023 at 4:58 AM
    justcuz
    justcuz 2.5 Gen Member
    don't forget to update the maintenance app on your truck
    makes it easier to remember when the reminder pops up
    bulldog93 likes this.
  4. Sep 4, 2023 at 5:03 AM
    Scott P
    Scott P New Member
    Scott
    2019 SR5 Tundra
    My filter housing drain plug is so tight I just use that for removal of the whole thing. Minor spillage, which I catch with the drain pan. Am I the only one?
  5. Sep 4, 2023 at 5:23 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Mmmm. Yep.
    This is the hot setup:
  6. Sep 4, 2023 at 5:37 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    jayhawknavy02 likes this.
  7. Sep 4, 2023 at 8:00 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
  8. Sep 4, 2023 at 8:02 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    I simply reset the light. I really don't use the Toyota app.
  9. Sep 4, 2023 at 8:03 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    Too bad they're never in stock.
  10. Sep 4, 2023 at 8:10 AM
    BlueCrushSC16
    Charleston, SC
    Lol. I always tell the ladies if they want a foot long, they have to come back for 2nds.
  11. Sep 4, 2023 at 11:11 AM
    Scott P
    Scott P New Member
    Scott
    2019 SR5 Tundra
    What am I looking at here - link?
  12. Sep 4, 2023 at 11:24 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Aftermarket engine oil filter canister cap made by Jowett Performance. With the optional Fumoto valve in the bottom of it for easy oil draining prior to removal. These caps are hard to get now. I got mine about 4.5 years ago. Though I saw a few posts several months ago that Jowett was making another run of them.
    https://jowettperformance.com/products/coming-soon-billet-oil-cap-for-filter
  13. Sep 4, 2023 at 1:02 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Tempting.
  14. Sep 4, 2023 at 8:14 PM
    CallsignKodiak
    CallsignKodiak [OP] New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    This is what I use Evernote for.
  15. Sep 4, 2023 at 8:31 PM
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    When do these Toyota sales happen, and are they applicable to all Toyota dealers, or just yours? I already stocked up on oil filters, but I'm gonna need a backstock of engine air filters...plus more oil filters. I'm not as prepared as you appear to be, but I generally have no less than 2-3 oil changes worth of backstock (oil plus all filters) in my garage inventory for every vehicle my wife and I own plus my boys' vehicles.
    I'm far more likely to change the oil at 3-4k miles than I am to do these 10-25k miles OCIs that the boutique oil buyers like to do. If I end up wasting a little money on oil in the long run, I'm ok with that.
  16. Sep 5, 2023 at 3:24 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    I've been using VMT on my iPhone. I've mostly been happy with it.
  17. Sep 5, 2023 at 10:56 AM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    I remove the oil cap under the hood before draining the oil below; someone told me it helped drain quicker, not sure if true.
    The fumoto valve makes a big difference in cleanliness. I recently got the F133N, larger opening and nipple for a hose, after using the F103 in a few different vehicles for years. Can't say I notice it draining any faster, but being able to run the drain hose directly into a sealed oil pan is great.
    I was too cheap to buy the Motivex kit but found similar items on Az that are working well so far.
    https://shorturl.at/rDER2 (filter drain tool)
    https://shorturl.at/ckrD4 (screw-on funnel)
  18. Sep 5, 2023 at 11:30 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    So I guess my first question is should o install two fumoto valves…..one on the actual oil filter cartridge and one for the oil pan? Or does it all drain from the same place?
  19. Sep 7, 2023 at 5:10 AM
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    I don't know that you could install a Fumoto valve on the oil filter housing that comes from the factory. However, there is an aftermarket billet oil filter housing that has a Fumoto valve built in. I think it was posted as a reply earlier in this thread, yeah....see reply #35.
  20. Sep 7, 2023 at 5:22 AM
    #50
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Until my last oil change I thought I was a master at doing it myself.
    I didn't get the new rubber gasket into the correct groove of the filter housing and oil leaked everywhere.
  21. Sep 7, 2023 at 7:20 AM
    #51
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Thank you for the link.
    My daughter’s fiancé owns a shop. I watched him do the oil change. Sorry for the probably silly question. Is the fitting and rubber hose (see pic) take the place of the plastic piece that comes with the Toyota filter to drain the housing it’s in? It has threads and the plastic piece just appeared to snap in.
  22. Sep 7, 2023 at 7:30 AM
    #52
    fyrfytr26
    Eastern PA
    2021 DC SR
    Yes, the tool you show threads in using the threads for the plug that's normally there. Then you screw the knurled part in to push the ball up and drain the oil. I only screw the knurled part in just far enough to get the oil to drain so as not to overcompress the spring.
    CallsignKodiak[OP] and OHwendTrd like this.
  23. Sep 7, 2023 at 8:17 AM
    #53
    Retired...finally
    I noticed a warning about that on the filter box.
    NewImprovedRon likes this.
  24. Sep 7, 2023 at 9:49 AM
    #54
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Ya gotta watch for the sales. The last one was two months or so ago. There's often a "heads up" here at Tundras.com. And don't confuse yourself on my stash. It's not purely Tundra. But also Highlander (2017) and Venza (2009). Most of my T-100 filters are in a closet in another other room (ran out of shelf space!).
  25. Sep 7, 2023 at 10:58 AM
    #55
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I just ordered one of those. Along with a Fumoto for the pan. And a screw-in funnel. I also bought ramps, a six pack of filters, and I subscribed for Amazon to send me the oil I need every four months. Gonna buy a creeper too.
    I'm done letting total strangers touch my truck, after the last apes either lost or stole my skid pan.
    OHwendTrd, Mike59 and bulldog93 like this.
  26. Sep 7, 2023 at 12:28 PM
    #56
    T-Guy69
    T-Guy69 New Member
    Long Island
  27. Sep 7, 2023 at 12:56 PM
    #57
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    For oil, if Costco is close and you are a member, roughly twice a year they run discount on their own brand oil, which I think is Mobil 1 private labeled.
    Right now for a box of two 5qt is roughly $30.xx after $8 discount, I usually stock 3 cases, and it should last me for Tundra + Pilot until the next sale, and I might skip one if I overstock, or my fiend would buy it from me.
  28. Sep 7, 2023 at 1:04 PM
    #58
    Cougareb
    Cougareb New Member
    2014 Tundra Limited Magnetic Gray
    Appreciate this thread, as I'm planning to start changing my own oil. I grew up helping my dad change the oil (and other maintenance / repairs) on our family vehicles, but I've fallen into the habit of dropping off my vehicles at dealerships for routine maintenance. I'm trying to take back more of what I can do on my own, hoping to learn and teach my own sons to be more self-sufficient and to understand more of the mechanics of a vehicle.
    I've purchased a creeper, the screw-on funnel and drain valves mentioned in this thread, and I purchased a set of 5 OEM oil filters. -- My question is about oil and its shelf life. I'm told my 2014 Tundra will take around 7.5 quarts of oil, so buying the Costco Kirkland brand synthetic would mean getting 20 quarts for $63.99. (From iantung's post above, it sounds like it's $4 cheaper in the warehouse to get the same amount, so I may choose that route rather than ordering online.) -- What is the shelf life on this oil; is it fine to sit on a shelf for 6 to 9 months in between oil changes? What about storing it outside in the dry heat of Nevada / Arizona? -- Also, I have a 2010 Lexus RX 350, and I'm wondering if there's any reason not to use that same oil for that engine.
    CallsignKodiak[OP] likes this.
  29. Sep 7, 2023 at 1:11 PM
    #59
    Ghost Rider
    Ian
    Cypress, Texas
    I m in Houston, and I store those in the garage, either on shelf or in the black/yellow plastic tubs.
    Warehouse is cheaper than online, but for some if there's no warehouse in the reasonable area, online is an option as it gets to your door, just more bucks...
    As for shelf life, I don't think it would matter unless you stock 20 cans at a time and sit on it.
    I usually stock three boxes, 6 cans. Tundra takes ~8qt (7.5-8.5qt for whatever everyone else says) and Pilot takes 5qt
    So 3 boxes usually last me two changes each.
    Oh, wife just texted, looks like I have to up the parts department for more parts/oil/whatever the hell I need to do what she wants....great....:annoyed:
  30. Sep 8, 2023 at 4:25 AM
    #60
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    Kirkland oil is made by Warren, a private-label blender who makes oil for TONS of house brand oils. It's perfectly good oil and meets all the specs I need including API and ILSAC. Just check the back of the bottle. For the price, you cannot beat Kirkland. You can even buy without a Costco membership if that's the way you roll.
