Valve cover bolt torque
Discussion in '1st Gen Tundras (2000-2006)' started by 05 tundra ky, Feb 10, 2023.
  1. Feb 10, 2023 at 10:18 AM
    05 tundra ky
    05 tundra ky [OP] New Member
    05 Toyota Tundra SR5 double cab 4x4
    Trying to find out what the torque spec on the valve cover bolts for 2005 Toyota tundra SR5 4.7 L. I’ve looked online and I found anywhere from 106 inch pounds to 53 inch pounds. Does anybody know need some help?
  2. Feb 10, 2023 at 10:43 AM
    shifty` Animals and insects don't do drugs
    It's all linked from this thread, which is a recommended read: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Part numbers and process for valve cover gaskets here: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    Correct torque on bolts is in INCH LB, not FT LB and you're aiming for 53 inch lbs per the FSM which is in the ballpark of 4.5 ft lb if my math is on-point
    Note that 1st link has links out to manuals galore which cover this stuff.
    Tom's Tundra and DarkMint like this.
  3. Feb 10, 2023 at 10:52 AM
    05 tundra ky
    Thanks appreciate it
  4. Feb 10, 2023 at 10:57 AM
    No problem.
    You may want to download copies of the Service Manuals, in case they ever go away. For you, the 2005-2006 FSM / in case others may want it, 2000-2003 FSM (Please, people, hit me up if either of those links goes dead!)
    I've yet to see a copy of the '04, it was a crossover, engine-wise 2004 has more in common with 2000-2003.
    SpaceSpud, Tom's Tundra and Neo like this.
  5. Feb 10, 2023 at 10:59 AM
    That’s only 0.125 Ugga Duggas. Aluminum heads.
  6. Sep 1, 2023 at 5:26 AM
    boogy
    boogy New Member
    2003 Tundra AC 4x4
    Planning to change my front/rear diff and transfer case oils. I spent hours looking through the 2000-2003 FSM as well as this torque settings post and I'm not finding any torque specs for the transfer or rear diff fill/drain plugs. On page 256 of the FSM it shows the front diff drain as 48 ft-lb and the fill as 28 ft-lb but no luck on torque specs for the rear or transfer case. Do you know a reliable source I can find these specs from? It's for a 2003 AC 4WD and as far as I can tell it's a standard rear, not LSD. Thanks again for your time!
  7. Sep 1, 2023 at 6:00 AM
    Rear:
  8. Sep 1, 2023 at 6:03 AM
    For the TC, I will warn you not to over-tighten those, though. There is a risk of stripping.
    des2mtn likes this.
  9. Sep 1, 2023 at 6:40 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    German spec always werks: Guttentite :)
    boogy and des2mtn like this.
  10. Sep 1, 2023 at 1:42 PM
    boogy
    boogy New Member
    2003 Tundra AC 4x4
    Thank you for your invaluable help @shifty` Waiting on the oil and gonna give it a go after the weekend. Thanks again for all you do!
  11. Sep 2, 2023 at 1:43 PM
    RustyMcTee
    RustyMcTee New Member
    New England
    '03 SR5 4x4 AC V6 - new frame in '22!
    Careful not to over torque your valve cover. I did and it cracked super easily. Ordered a cheap one online to replace but it was so sketchy feeling that I went with a used OEM valve cover. Felt much better about it. But yeah, don't shoot yourself in the foot like I did lol
  12. Sep 2, 2023 at 1:54 PM
    RustyMcTee
    New England
    I've got the v6 5vz-fe
  13. Nov 14, 2023 at 6:43 AM
    The Black Mamba
    The Black Mamba Black Sneks Matter
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    For the life of me, I cannot get this to load. It times out. I've tried Chrome, Edge and even Safari on the phone :(
  14. Nov 14, 2023 at 7:00 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Hmmm...both load for me in Firefox, but not in Chrome
  15. Nov 14, 2023 at 7:00 AM
    It's pretty damn large, it may take a minute or three. Android or iOS? In either, can you hold your finger on the link and 'save' the file to your device?
  16. Nov 14, 2023 at 7:06 AM
    w666
    Maryland
    Correction: 05-06 Loads for me in Chrome. 00-03 does not. It threw a certificate warning (self signed) on my first attempt, so that may be part of the problem.
    The Black Mamba likes this.
  17. Nov 14, 2023 at 7:07 AM
    Google Drive vs. AITNet's website.
  18. Nov 14, 2023 at 7:21 AM
    The Black Mamba
    DFW
    Imma keep it stock
    That's the ticket. Got it! Thank you both.
