The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    26.7%
  2. Alpine ILX-F509
    4 vote(s)
    3.1%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.2%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.5%
  7. No - I was late to the party
    55 vote(s)
    42.0%
  8. No - I didn't need a new head unit
    19 vote(s)
    14.5%
Multiple votes are allowed.
  1. Aug 31, 2023 at 3:23 PM
    #241
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  2. Aug 31, 2023 at 3:30 PM
    #242
    Azblue
    The Dirty T ( ^_^)_且
    Ah, thank you kind sir. Also, looking at the wire diagram in the Alpine manual I think I have located the other wires. On the main harness below the HDMI ports, the ground is 1st wire on the left of the bottom row and the parking brake wire is 3rd from the right on the top row. I will probably use Posi-taps to connect them.
    Now I just need to know if I connect the speed sensor wires and WTF the blue wire on the antenna adapter is for.
    And I see @TRDFURGUSON answered my questions as I was typing this
  3. Aug 31, 2023 at 3:41 PM
    #243
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    DON'T connect the parking brake wire to anything but the bypass module.
  4. Aug 31, 2023 at 3:43 PM
    #244
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    TRDFerguson likes this.
  5. Aug 31, 2023 at 3:46 PM
    #245
    Azblue
    It's already connected to the HU via the Maestro harness, I was just going to posi-tap it near the connector that plugs into the HU
  6. Aug 31, 2023 at 3:51 PM
    #246
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah... Don't do that lol. Having it connected from the truck to Maestro is fine, but the lead into the Alpine needs to ONLY be connected to the bypass module.
  7. Aug 31, 2023 at 3:56 PM
    #247
    Azblue
    Well shit, now I'm confused (admittedly easy to do). The harness that plugs into the HU is from the Maestro via the AlP1. So where do I connect it?
  8. Aug 31, 2023 at 4:00 PM
    #248
    RainMan_PNW
    Casey
    Clark County, WA
    Cut the parking brake wire in that harness to the HU. Hook the end going into the HU to the bypass module. Seal off the other end. Have another Miller Lite.
  9. Aug 31, 2023 at 4:20 PM
    #249
    Azblue
    Like this?
  10. Aug 31, 2023 at 4:22 PM
    #250
    RainMan_PNW
    Casey
    Clark County, WA
  11. Aug 31, 2023 at 4:22 PM
    #251
    RainMan_PNW
    Casey
    Clark County, WA
    Ok
    About to blast off
    Be in AZ in a couple hours
  12. Aug 31, 2023 at 4:23 PM
    #252
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    This. I just finished this about 2 hours ago after looking at the manual to find the wires to connect to and then followed the directions here to splice in the bypass. Works perfectly!
  13. Aug 31, 2023 at 4:25 PM
    #253
    Azblue
    Cool. I assume that it's ok to posi-tap the ground in that same harness since it's right there anyways?
  14. Aug 31, 2023 at 4:26 PM
    #254
    Safe travels Casey.
  15. Aug 31, 2023 at 4:27 PM
    #255
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, that’s fine
  16. Aug 31, 2023 at 4:27 PM
    #256
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    The hardest part is stuffing all the shit back in the dash after you're done lol. I plan on never pulling it apart again. Thanks everyone again for all your help!!
  17. Aug 31, 2023 at 4:27 PM
    #257
    RainMan_PNW
    Casey
    Clark County, WA
    Yep
    Not Jason’s preferred method of connecting, but thousands of Best Buy installations have used them. :D
    much better that scotchlocks
  18. Aug 31, 2023 at 4:30 PM
    #258
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Which makes me want to use them even more…
  19. Aug 31, 2023 at 4:32 PM
    #259
    RainMan_PNW
    Casey
    Clark County, WA
  20. Aug 31, 2023 at 5:02 PM
    #260
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    FYI this is where/how I mounted my aftermarket mic. Just removed the factory guts and threw those in a drawer
    Leek128, Patch999, WFD473 and 4 others like this.
  21. Aug 31, 2023 at 5:02 PM
    #261
    Azblue
    Have a good trip and feel free to grab Jake and head down from the basin to the valley and help tear my truck apart this weekend. I have beer. :burp:
    TaquitoBandito and TRDFerguson like this.
  22. Aug 31, 2023 at 5:05 PM
    #262
    Azblue
    I'm already so sick of wires I took the easy way out. After I finally got that fucking stripped screw out, I just lowered the screen 1 notch so the pocket was still accessible. Drilled a hole in the back of the pocket to run the wire and mounted the mic at the front of the pocket on the left side pointed at the driver.
    WFD473 likes this.
  23. Aug 31, 2023 at 5:08 PM
    #263
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  24. Aug 31, 2023 at 5:15 PM
    #264
    RainMan_PNW
    Casey
    Clark County, WA
    There’s nothing in that spot in the 20/21 (maybe 19 too). But the little grill is still there…i was thinking of using it
  25. Aug 31, 2023 at 5:49 PM
    #265
    AZTundra
    Paul
    Phoenix, AZ
    Any issues with the sound quality in this location from the aftermarket mic? If not, I may just copy this approach.
  26. Aug 31, 2023 at 5:50 PM
    #266
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Couldn’t get my mic to work so had to open everything up. Was hoping it was unplugged but the cord was nicked. Had to order a new one, so looks like one more time to practice wire stuffing everything back there. Would it be smart to plug in rca cables for a future amp so I don’t have to get back there again?
    bulldog93 and AZTundra like this.
  27. Aug 31, 2023 at 5:52 PM
    #267
    AZTundra
    Paul
    Phoenix, AZ
    If you do that you'd probably want to run a wire for the remote turn on as well.
  28. Aug 31, 2023 at 5:56 PM
    #268
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I haven’t had any complaints, and the wife usually lets me know when I do anything wrong.
  29. Aug 31, 2023 at 5:59 PM
    #269
    RainMan_PNW
    Casey
    Clark County, WA
    :rofl::rofl:
    AZTundra and TRDFerguson[QUOTED] like this.
  30. Aug 31, 2023 at 6:04 PM
    #270
    RainMan_PNW
    Casey
    Clark County, WA
    If you ever think you’ll add one, I would.
    There’s already an amp remote turn on wire in the stock harness if your truck has the factory amp (or has the harness under the seat).
