Alternator wiring
Discussion in '1st Gen Tundras (2000-2006)' started by Kingjp, Aug 30, 2023.
  1. Aug 30, 2023 at 10:03 AM
    Kingjp
    Kingjp [OP] New Member
    03 Lexus 470
    The plug on the alternator has 3 wires, a black, a blue and white and a black and white. I am trying to figure out what each wire goes to. I assume black is ground? Black and white the charging indicator light and blue and white the ignition? Can someone clarify which one does what?
  2. Aug 30, 2023 at 10:11 AM
  3. Aug 30, 2023 at 11:03 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Since those colors do not show for a Tundra, would this happen to be about your 03 Lexus 470 showing in your profile ?
    If so, unless someone here with a Lexus can offer info, the below is a 2003 Lexus GX470 if it helps.
    Link to a Lexus Forum if it's about your 03 Lexus 470....
    Lexus Model Forums - ClubLexus - Lexus Forum Discussion
