Front Passenger caliper hard line pre bent
Discussion in '1st Gen Tundras (2000-2006)' started by Hawaii4x4, Aug 30, 2023.
  1. Aug 30, 2023 at 10:45 AM
    Hawaii4x4
    Hawaii4x4 [OP] New Member
    2004 Toyota tundra double cab
    Hey everyone I was wondering if anyone has a link to a passenger hard brake line pre bent that goes from brake caliper to brake hose. I was changing out a stud and when I took my brake off I snapped the old rusty line sadly. Anyone know where I can get one? I’m been looking and haven’t found an exact fit. Let me know thanks
  2. Aug 30, 2023 at 10:53 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Toyota sells these lines pre-bent. Here's the part numbers:
    Driver: 47318-0C020
    Passenger: 47315-0C020
    Riverdale21, Aerindel, amm203 and 3 others like this.
  3. Aug 30, 2023 at 10:57 AM
    Hawaii4x4
    Thank you I appreciate it
    des2mtn[QUOTED] and FrenchToasty like this.
  4. Sep 2, 2023 at 1:09 PM
    amm203
    amm203 New Member
    2004 Sequoia 4WD
    Just had this happen to me today. Snapped the rusty hard line like a twig trying to change front calipers on my Sequoia. Extremely frustrating. Toyota dealer can’t get new lines in until Wednesday - exact same part numbers as your Tundra. I was able to use an old bleeder screw with the same thread pitch to seal off the line at the rubber hose - no more leaking. Thankfully have a spare car to use until then. Highly suggest picking these up ahead of time if you’re going to do any work involving touching these lines on these old trucks.
  5. Sep 2, 2023 at 3:07 PM
    Hawaii4x4
    Yeah I had the same issue I was not able to get a new OEM from Toyota until 2 weeks later after I already started working on it. I actually ordered a OEM hard line off of eBay that got here quick. Fit great and canceled my Toyota order
    amm203[QUOTED] likes this.
  6. Sep 2, 2023 at 3:51 PM
    amm203
    amm203 New Member
    2004 Sequoia 4WD
    eBay to the rescue! Would have rather used them. Kind of scary to think 5ft/lbs of hand torque popped that line off like it was nothing. Peace of mind to have it be brand new
    Hawaii4x4[OP] likes this.
  7. Sep 2, 2023 at 5:20 PM
    Be careful if you ordered "Genuine OEM" off fleaBay. You're liable to get something else. It's really hit or miss.
  8. Sep 2, 2023 at 6:06 PM
    Hawaii4x4
    Yeah I was worried but I was in a pinch…and it surprising was just like the old one of the truck. Fit perfect and came with a receipt from Toyota
    shifty`[QUOTED] likes this.
  9. Sep 2, 2023 at 7:41 PM
    amm203
    amm203 New Member
    2004 Sequoia 4WD
    Agree 100% Toyota (and Subaru) parts are scam-sold out the wazoo on eBay. However I’d be confident these specific parts are so rare (and so basic in their build) that eBay is a safe option. There are only a handful of eBay buyers I would trust for more complex parts. It is sad how untrustworthy Toyo parts are on eBay
  10. Sep 2, 2023 at 10:54 PM
    Aerindel
    Aerindel New Member
    Montana
    It's not hard to bend brake line. I had to replace the same exact line a couple years ago after a tire chain came loose and tore it off. It just got a short piece of straight line from napa, bent it by hand.....its been fine ever since.
    Hawaii4x4[OP] and fyrfytr26 like this.
  11. Sep 26, 2024 at 3:54 PM
    Eazy_E20
    Eazy_E20 New Member
    Eric
    Fort Knox, Kentucky
    2020 Silver Tundra SR5 Crew
    My second replacement arrives tomorrow from Toyota dealer. Anyone figure out why they bend? It seems to be common, but not common enough for a dealer to stock supply? Crazy.
    Is it the vaccuum? Is something hitting it, which wouldnt make sense to me. Curious. Thanks.
  12. Sep 26, 2024 at 4:20 PM
    des2mtn
    Shady Grove
    Tonto cover
    The metal brake lines are supposed to be bent, it's not a straight line from the caliper to where the metal brake line meets the rubber brake line. Over-bending the lines or improperly supporting the calipers when doing brake work can cause the metal lines to pinch and leak though.
    The reason metal brake line is bent, is because by design it needs to meet with the rubber line at a certain place on the spindle, and that's often not a straight line. The metal line doesn't move at all with your suspension. But the rubber line that it connects to does; it moves with your suspension
  13. Sep 26, 2024 at 7:47 PM
    Eazy_E20
    Eazy_E20 New Member
    Eric
    Fort Knox, Kentucky
    Des2mtn,
    I guess I wasnt clear with my wording - my apologies. Im aware they are naturally bent, but mine has bent inward to a crack causing a leak.
    As you stated, the metal line shouldn’t move; however, mine has bent inward twice. Which I think is odd, even though it seems common.
  14. Sep 27, 2024 at 5:31 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    Since both ends of the line are *supposed* to be mounted to fixed points, the hard line shouldn't bend under normal circumstances. However, I did find on mine that the retaining clip that holds the fitting to the soft line was missing, meaning that the hard line was at least flexing some amount every time the suspension cycled. You may want to check to ensure those retaining clips are in place. Otherwise, the only other reason I can think of that they would bend (again because both ends are fixed in place) would be road debris or some other issue during maintenance (hitting the line with the wheel when mounting/dismounting, caliper removal during brake maintenance, improper jack/stand placement, etc.).
    Eazy_E20[QUOTED] and des2mtn like this.
  15. Sep 27, 2024 at 10:14 AM
    Eazy_E20
    Eazy_E20 New Member
    Eric
    Fort Knox, Kentucky
    Turtonics,
    Excellent. I have never thought of that, Ill check and replace, and Ill follow up. Thank you so much. You all kickass!!
  16. Sep 27, 2024 at 11:50 AM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    If you're in a pinch and need to fix it that day, auto parts stores sell various sizes in steel and NiCopp lines with the Japanese fittings. I found a perfect match at Advance Auto. NiCopp can be bent by hand. You want to use a tool to bend the steel line. I planned on just using it as a temporary fix, but it turned out so nice that I just left it installed haha.
  17. Sep 27, 2024 at 6:10 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Why not just get some stainless steel braided lines?
  18. May 28, 2025 at 7:59 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Resurrecting an ancient thread...apologies in advance.
    When I first saw this thread I ordered the hard lines above knowing that one day they would come in handy. Now that I'm getting ready to install them, I notice that the ends are different (one has threads all the way to the flare, the other does not). Do you know which end fits the caliper and which end fits the soft line? (I assume it matters else why would they be different?
    des2mtn[QUOTED] likes this.
  19. May 28, 2025 at 8:11 AM
    des2mtn
    Shady Grove
    Tonto cover
    I've ran into this as well and it does matter, I'm pretty sure the partially threaded one fits into the soft line and the fully threaded one goes into the caliper.
    I came across these part numbers for the fittings themselves, I imagine they're the same as what's installed on your pre-bent line. Use them with bulk 3/16" tube and double flare tool.
    w666[QUOTED] likes this.
  20. May 28, 2025 at 12:19 PM
    Jedgar
    Jedgar New Member
    2006 SR5 Double Cab 4WD, V8, forest green w/ topper
    None (no lift, don't want one), Bilstein 4600 shocks soon. Bigger Michelin tires soon.
    Well…When I was working on my front brakes, had one of the short steel lines, which was rusty, leak after I installed the new caliper. I wanted to fix it while I had the wheel off and tools out. I had 3/16” nickel copper brake line and fittings left over from a replacement job on my 1997 Ford E350 box truck. So, I flared (double flare) and bent a line up. Guess what, fittings screwed in no problem and no leaks.
  21. May 28, 2025 at 2:37 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    You should be able to match the orientation of the old line. I want to say that it fits well in the correct orientation and the line makes contact or won't easily work in the wrong orientation.
    des2mtn and w666[QUOTED] like this.
  22. May 29, 2025 at 6:07 AM
    w666
    Maryland
    At this point both the hard and soft lines, as well as the caliper (all new) are in my hands. I'm just trying to sort it before I have brake fluid running down my sleeve. I'll attempt to dry fit everything before I open the lines, and report back.
    Update: According to some guy on the Internet (must be true...right?) the partially threaded fitting goes to the soft line
    https://www.youtube.com/watch?v=Eb3mSoDsu7k&ab_channel=Ozzstar'sCars
    shifty` likes this.
  23. May 29, 2025 at 6:33 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    That matches my truck. Doesn't seem like it fits the other way. I think the colored band indicates 'up'
    w666 likes this.
  24. Jun 7, 2025 at 7:53 AM
    w666
    Maryland
    I can confirm that this end goes into the soft line
    pirates712 and des2mtn like this.
