SUPERCHARGE OR NOT
Discussion in 'New Member Introductions' started by Coltgunman, Aug 26, 2023.
  1. Aug 27, 2023 at 11:52 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I figured that part numbers would be a good place to start, prices can change over time. Supply and demand.
    e30cabrio[QUOTED] likes this.
  2. Aug 27, 2023 at 12:21 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Super unleaded. Cost?
    I bet I use my supercharger, for its intended purpose, wayyyyy more than y’all use those big ass upsized tires
    and how much “mileage” do those tires cost you?
    how about the “warranty”?
    This is not a “need” issue. Its a “want” issue
    the s/c, as installed, rarely creates boost under normal Usage. The bypass gadget works quite well. So any concerns about wear and tear are questionable
    like I said earlier, a good tune makes the blown tundra bullet proof. Or thereabouts
    Just get it
    Tune it on a dyno
    live A little better
    life is good
    Wynnded likes this.
  3. Aug 27, 2023 at 12:24 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Here in east houston, a lot of the Hispanic brothers put loud ass exhausts on their chevys
    it’s all fun and games till they try to pass me.
    Seantron likes this.
  4. Aug 27, 2023 at 2:36 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I must go through more gas than you lol
  5. Aug 27, 2023 at 3:57 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    possible. I based it on my avg of 25 gallons a week
    I pulled a trailer a couple weeks ago. The s/c makes it effortless. However, instant gas hog when the bypass closes.
    flat roads, I got 11. Like most do with a trailer
    over hills, 3mpg. Using s5 tow/haul.
    I averaged 12 from houston to belton. Not bad and probably similar to n/a numbers. 62 mph
  6. Aug 27, 2023 at 4:40 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    What is the goal? Towing? Less gear hunting on the highway? Passing angry Ram drivers? :D
    At the risk of disappointing the forum’s boosted brethren, I think I would do gears first. I’m running skinny 35s, and I think 5.29s would make a world of difference, especially when doing work. Of course that would probably be enough to get me curious, and then I’d go ahead and boost it.
    This truck has power and reliability in spades. I think its major shortcomings are rear leafs and gearing. Even with the 4.30 rear end, the overall gearing isn’t fantastic.
    That said, the engine has loads of power. This old dinosaur 5.7 makes 90% of its max torque at 2600rpm. That’s awesome for a naturally aspirated engine. Just seems like boosting it with the kinda weak gearing isn’t getting the full advantage of the boost, especially if you’re on 35s or 37s. If you’re on stock tires, probably a different story.
  7. Aug 27, 2023 at 5:24 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No anger here. My gears are swapped w/o SCing first :thumbsup:
    Seantron and Terndrerrr[QUOTED] like this.
  8. Aug 27, 2023 at 5:35 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I pretty much always agree with what you have to say on this forum. You’re like my spirit animal. :rofl:That said, from personal experience on this particular point I think the gearing doesn’t even matter when there’s that much power on tap! I’m on 34s with stock gearing, and I have an extra 500ish pounds I’m lugging around with the bed cap, steel bumper, 65 lb tires, steel RCI skid, running boards, AALs, airbags, tools etc. and I was able to achieve a dragy verified 4.6 seconds to 60. I don’t see how much better it can get with this old 6 speed transmission on a 6k lb truck. There are others with similar mods and 5.29s and we are all in that same ballpark to 60. Might 4.88s or 5.29s shave a tenth off? Possibly, but is it worth the extra $2500 expense I guess is the question. Towing wise the power is also fantastic, borderline ridiculous even with the stock gears.
  9. Aug 27, 2023 at 5:49 PM
    Trdripper
    Trdripper New Member
    Bronze 2nd Gen
    King 3.0 front Coilovers with TC UCA King 3.0 rear Bypass shocks
    Hey guys. Trying to buy a TRD used supercharger for my 2011 tundra. Is there anyway to confirm if it’s for a naturally aspirated 5.7 or the flex fuel. Seller isn’t sure for some reason… not sure if Toyota made a supercharger for the Flex Fuel E85 tundra. Any help I’d-ing it or where to look for a model or type number would be great!
  10. Aug 27, 2023 at 6:51 PM
    Terndrerrr
    Music City
    6UR-FE
    Ha. Likewise! :cheers:
    Wow. Is there really a negligible difference in 4.30 vs 5.29 when you have a blower on 34s? I would think any difference would widen slightly with 35s, more with 37s. Just speculation, though. I admit I have no personal experience with either. I watch pretty much every SC and gears thread on the forum, and I'm just trying to put together as accurate a picture as possible. @reywcms swears by the blower on 4.30s/37s. I can be convinced that gears are negligible when you're running a blower. But many others on the forum with 5.29s/35s and no blower say that their truck woke right up, tows much better, holds 6th on the highway no problem. That alone might be enough for me–5.29s with a limited slip in the rear and a locker in the front.
    Depending on the OP's goal(s), gears might do the trick.
    Any of y'all SC'ers in middle Tennessee, I'd love to A/B our trucks. :burnrubber:
    Silver17[QUOTED] and texasrho83 like this.
  11. Aug 27, 2023 at 7:17 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Buddy of mine asked HP Tuners if he should do a gear swap and they flat out told him "nah, wouldn't make much difference" (he's SC'ed)
  12. Aug 27, 2023 at 7:20 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
  13. Aug 27, 2023 at 7:30 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah and guess which one's cooler?
    Terndrerrr likes this.
  14. Aug 27, 2023 at 7:35 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Whipple and 4.88s on the old man’s rig and he wouldn’t even of bothered. Does it help with towing the trailer sure but the other 99% not needed
    Silver17 and texasrho83 like this.
  15. Aug 29, 2023 at 4:57 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My Sequoia is Flex & the SC is not, I made it work. Except for bypassing the fuel switching valve they are the same. The issues are tune related not hardware.
    The Flex fuel pump looks exactly like a Walbro 450, if I had it to do over, I'd have left the fuel pump alone. (if I had fuel issues I could have swapped it later)
    texasrho83 likes this.
