Alpine ILX-F511. Game Changer
Discussion in 'Audio & Video' started by running214, Mar 2, 2023.
  1. Aug 26, 2023 at 3:51 PM
    #1201
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    There’s still the 9 inch Alpine you could try
    ToyoMafia likes this.
  2. Aug 26, 2023 at 8:00 PM
    #1202
    polymerhead
    polymerhead New Member
    When I start up my truck the HU will switch to my TPMS screen maybe 30 seconds after, when they register. It’s like it registers a new reading and wants to tell me about it. Happen to anyone else? Any way to make this not happen other than removing the TPMS gages from the HU? It’s not a huge deal, but I’d rather not have to navigate back to my music on every trip.
  3. Aug 26, 2023 at 8:12 PM
    #1203
    Val4x42
    Val4x42 New Member
    Phoenix, AZ
    2018 Tundra
    To turn it off go to: Setup->Function->Factory Audio->Vehicle Information->Tire Alert and turn it off
  4. Aug 26, 2023 at 8:25 PM
    #1204
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    What he said^^^^
    TaquitoBandito and polymerhead like this.
  5. Aug 27, 2023 at 10:58 AM
    #1205
    polymerhead
    Thanks! I’ll try it. So far I’ve installed the head unit, a Kenwood amp, Kicker door speakers and a Rockford Fosgate 10” punch sub behind the rear seat. Pulled all the dash speakers this morning. For a modest build I’m happy with the result, especially since the savings on the head unit paid for everything else!
  6. Aug 27, 2023 at 2:28 PM
    #1206
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Been fucking swamped this week and will be this next week too. The one I have coming will be here Monday - it is the same one that @dittothat ordered. I'm expecting their sales to jump astronomically in the next week if I confirm fitment.
  7. Aug 27, 2023 at 2:31 PM
    #1207
    Once I get out of the swamp, I’ll be getting a parts list together as well.
    TaquitoBandito and ToyoMafia like this.
  8. Aug 27, 2023 at 2:47 PM
    #1208
    Richie Rich
    Richie Rich New Member
    California
    07 Crewmax Limited TRDOR.
    Coilovers, wheels, 35s, Amp steps, Carplay
    Finally got the cluster of an install done on the Tacoma.
    The 9" scales much, much better in the dash than the 11" would.
    I highly recommend not trying to move the video feed from your factory backup cam to the headunit. While I did make it work, what a PITA it is.
    SXM is staffed by utter morons who borked my entire account.
  9. Aug 27, 2023 at 3:28 PM
    #1209
    AZTundra
    Paul
    Phoenix, AZ
    Just ordered one myself. Hoping for an install of everything over the holiday weekend.
  10. Aug 28, 2023 at 9:20 PM
    #1210
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Picked up my Kenwood today. Just ordered everything else needed for the install.
  11. Aug 29, 2023 at 3:05 PM
    #1211
    HoodRiverTundra
    HoodRiverTundra New Member
    Riley
    Hood River, OR
    2011 TRD Crewmax
    ICON Stage 2, Roadmaster Active Suspension, 46 Gal TransferFlow Tank, 295/70/18 WildPeaks
    2011 Limited with JBL Head unit & Speakers. Upgrading to the Kenwood DMX1037S. Crutchfield has the notice below when looking at the installation packages
    "If you plan to bypass the factory amp, we recommend replacing your vehicle's low-impedance speakers with standard 4-ohm aftermarket speakers to avoid damaging your new radio. If you want to keep your factory speakers, you'll need to add an aftermarket amplifier."
    Anyone looking at having to make these changes? Suggestions on new speakers?
    Thanks
    TaquitoBandito and MedCityMoto like this.
  12. Aug 29, 2023 at 6:49 PM
    #1212
    RainMan_PNW
    Casey
    Clark County, WA
    Are you wanting to replace everything, or just the HU right now? You can just swap the HU and use the Maestro and it will run through the JBL amp and power the factory speakers fine. It won’t be amazing, but it will still be a noticeable improvement over stock.
    replacing the JBL amp and swapping out speakers is a potentially very slippery slope… sort of like looking at suspensions and tires
  13. Aug 29, 2023 at 7:50 PM
    #1213
    HoodRiverTundra
    Riley
    Hood River, OR
    2011 TRD Crewmax
    That’s what I’m finding out & I’m not a big audio guy anyway. I’d be good with just replacing the HU for CarPlay and adding a front cam for now
    In that case, you’re saying I can ignore crutchfield’s suggestion and it will work fine?
  14. Aug 29, 2023 at 7:56 PM
    #1214
    RainMan_PNW
    Casey
    Clark County, WA
    Their suggestion is based on IF you decide to pull the factory amp out. The door speakers are low impedance (2 ohm) and that doesn’t play nice with the head unit if wired direct to the speakers (it is designed to power 4 ohm speakers).
    Instead, the head unit will send the audio signals (with the help of the Maestro) to the factory Amp by default and the amp will distribute to the speakers.
  15. Aug 29, 2023 at 8:22 PM
    #1215
    HoodRiverTundra
    Riley
    Hood River, OR
    2011 TRD Crewmax
    Got it, that makes more sense now. Thanks!
  16. Aug 29, 2023 at 8:34 PM
    #1216
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I had the non-JBL amp which I long since deleted previously, any issues with the OEM speakers directly run from the Kenwood DMX1037S with the bypass harness?
  17. Aug 29, 2023 at 8:36 PM
    #1217
    ufmechanic
    ufmechanic New Member
    New Mexico
    2nd Gen Blk CM Pt 5.7L 4x4
    I love my ILX-F511 but I am looking for advice or to see if I am the only one shaking the thing to death. The screen went from the wiggle people talk about to displaying like trying to watch blocked cable HBO when off road. Anyone else?
    I am thinking to remove, pick another height, reinstall, and then rtv shims behind each side or something.
  18. Aug 29, 2023 at 8:38 PM
    #1218
    AZTundra
    Paul
    Phoenix, AZ
    Where do you currently have the height and depth adjustment set to? Also, which dash kit are you using? These items may help others with similar setups be able to answer better.
    ToyoMafia and TaquitoBandito like this.
  19. Aug 29, 2023 at 8:53 PM
    #1219
    ufmechanic
    New Mexico
  20. Aug 30, 2023 at 10:38 AM
    #1220
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Interesting... I'll be ordering my install bits soon. I wonder where the weak point is, and if it's something I can build a reinforcement bracket for either out of metal or some strong 3D printed material.
    TaquitoBandito likes this.
  21. Aug 30, 2023 at 10:54 AM
    #1221
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Mine has been solid since install. Just checking, you installed the 4 screws that hold the face to the main chassis after you connected it and before you installed the power bar thing?
  22. Aug 30, 2023 at 10:59 AM
    #1222
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Mine is solid as a rock……make sure all the connections are seated properly and all screws are installed
  23. Aug 30, 2023 at 2:03 PM
    #1223
    MedCityMoto
    Do you know if the non-JBL amp is also running 2 ohm speakers in the door? I pulled my SR5 non-JBL amp months ago when I went with a Dasaita headunit, and the audio quality was way way better. But if I'm potentially causing issues for myself I will swap the door speakers, I can get some quality 4ohm speakers.
    bulldog93 likes this.
  24. Aug 30, 2023 at 2:14 PM
    #1224
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you're running ALL the stock speakers, you're fine. Each corner, which includes the door, corner speaker and one channel of the center speaker, works out to being a 4ohm circuit.
  25. Aug 30, 2023 at 2:26 PM
    #1225
    MedCityMoto
    I am indeed! Excellent, I can save up for doing an entire speaker-amp-sub system in the future instead of throwing a makeshift budget thing at it quick!
  26. Aug 30, 2023 at 2:58 PM
    #1226
    polymerhead
    I can tell you I bypassed the non-JBL amp when I installed this HU and the sounds trough the factory door speakers was worse than routing it through the factory amp in my opinion. Especially with the HU driving the dash speakers so much harder, my audio sounded pretty bad for a week until I got better door speakers installed with a 5 channel amp. I ended up pulling the dash speakers completely once that was done.
  27. Aug 30, 2023 at 3:20 PM
    #1227
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    @TRDFerguson will make the trip to you and help with the install if you throw him a bone or two from the HotShot shop. :rofl:
  28. Aug 30, 2023 at 3:36 PM
    #1228
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I remember that now, and yeah the factory amp has a built in low pass filter for the door woofers. I still don’t think it should hurt anything, necessarily, but it could make the sound worse like you experienced.
    bulldog93 and TaquitoBandito like this.
  29. Aug 30, 2023 at 4:19 PM
    #1229
    MedCityMoto
    Ah, well. I'd put the factory non-JBL amp back in, for a trial run, but I gave mine to another forum member here, and I'm not dropping the kind of money they're asking for one on eBay!
  30. Aug 30, 2023 at 4:24 PM
    #1230
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That money would be better spent on a set of decent component speakers haha
    RainMan_PNW and TaquitoBandito like this.
