Finally got the ok for a Supercharger
Discussion in 'Performance and Tuning' started by 19PlatinumCrew, Aug 10, 2023.
  1. Aug 23, 2023 at 9:31 AM
    #211
    Saltyhero13
    Saltyhero13 Throbbing Member
    @VWTim sorry it was @4firemandan that ran water wetter on the Maggie. It may be up on his build page but he mentioned it in PMs. Not sure how long he ran it so can't say it is safe on the Maggie. Can always email/call the blower company to verify.
    There was a post about the bricks having a coolant leaks on the Harrops. Seems like it was traced back to the wrong coolant being corrosive or an issue with dissimilar metals. I'm sure someone will chime in to correct me.
  2. Aug 23, 2023 at 1:42 PM
    #212
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    For the intake you ordered, any stock lower airbox from a 14-21 would work. The 07-13 lower airbox is only needed for 07-13 trucks (obviously) or the larger supercharger specific intakes.
    nobodyintexas[QUOTED] likes this.
  3. Aug 23, 2023 at 2:25 PM
    #213
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    you answered the question I was about to ask
    muchos gracias
    Silver17[QUOTED] likes this.
  4. Aug 25, 2023 at 2:52 PM
    #214
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    So it begins...just got a call from National Speed questioning the Maggy sc box not working this does not give me a warm fuzzy if an air box stumps them what are they going to do about welding a bung and hooking up my psb1. They keep pushing the pro speed box. Not confident right now...Anybody with a Maggie sc box hooked to a Harrop send me pictures 540 420 9131 so I can forward them to National Speed thanks
  5. Aug 25, 2023 at 3:03 PM
    #215
    Silver17
    Eastern PA
    You can save this picture of mine to your phone and send it. They’re probably just struggling to get the Harrop rubber boot over the airbox lid but it can be done if you don’t have sissy hands. https://www.tundras.com/threads/finally-got-the-ok-for-a-supercharger.128824/page-5#post-3290138
    reywcms and Saltyhero13 like this.
  6. Aug 25, 2023 at 3:06 PM
    #216
    19PlatinumCrew
    Dave
    Thanks Silver just sent it to them...I assured them that it has been done but the tube would be a B###h to get on. What was your solution for this
  7. Aug 25, 2023 at 4:01 PM
    #217
    Saltyhero13
    Lots of lube
    Tripleconpanna and Silver17 like this.
  8. Aug 25, 2023 at 4:06 PM
    #218
    nobodyintexas
    nobodyintexas What?
    South of Houston
    which is always the solution
  9. Aug 25, 2023 at 4:22 PM
    #219
    Silver17
    Eastern PA
    Brute force and frustration with a big flathead screwdriver did it for me. Someone else had a good idea of putting the end of the tube in boiling water to make it more pliable, I forget who it was but I like that idea. Someone else shared a video of shoving a softball in the end and warming the rubber up with a heat gun to soften it up a bit.
    reywcms, Saltyhero13 and Black@Blue19 like this.
  10. Aug 25, 2023 at 4:30 PM
    #220
    19PlatinumCrew
    Dave
    I am sure that is the solution for most things today
  11. Aug 25, 2023 at 4:32 PM
    #221
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    This really isn't bad advice at all; just make sure you use water-based lube otherwise the silicone w/cause the rubber to deteriorate :thumbsup:
  12. Aug 25, 2023 at 4:41 PM
    #222
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Any further comment from myself will self incriminate me.
    Saltyhero13 likes this.
  13. Aug 25, 2023 at 4:42 PM
    #223
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’ll be doing this exact exercise soon
    getting the boot on the harrop, that is.
    VWTim and Saltyhero13 like this.
  14. Aug 25, 2023 at 4:44 PM
    #224
    19PlatinumCrew
    Dave
    Let everyone know...Lube...no Lube...asking for a Friend
    Saltyhero13 and nobodyintexas like this.
  15. Aug 25, 2023 at 4:45 PM
    #225
    19PlatinumCrew
    Dave
    Nobodyintexas..you running the stock 85mm pulley
  16. Aug 25, 2023 at 5:02 PM
    #226
    Saltyhero13
    Shoe horn or bust.
  17. Aug 25, 2023 at 5:11 PM
    #227
    Saltyhero13
    Are there connections on the boot? If not they can probably order a coupler for it. Can't imagine it will be that difficult for them to figure out.
  18. Aug 25, 2023 at 5:12 PM
    #228
    nobodyintexas
    nobodyintexas What?
    South of Houston
    80mm
    650’s
  19. Aug 25, 2023 at 5:21 PM
    #229
    nobodyintexas
    nobodyintexas What?
    South of Houston
    However, stock intake
    stockity stock
  20. Aug 25, 2023 at 5:45 PM
    #230
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    That is an android based system. Maybe you can get Torque on it.
  21. Aug 25, 2023 at 5:46 PM
    #231
    Silver17
    Eastern PA
    Yes, Just one connection.
    Saltyhero13[QUOTED] and reywcms like this.
  22. Aug 25, 2023 at 6:00 PM
    #232
    Saltyhero13
    Good pic. What is the stock TB 76mm?
  23. Aug 25, 2023 at 6:20 PM
    #233
    Silver17
    Eastern PA
    Yes I’m pretty sure. Not sure the Harrop boot would fit over the RCF TB, it would make changing the filter hard. At this point I’d remove the boot from the TB to remove the lid and change the filter since there is no way I’m removing the boot from the Maggie airbox. If it’s a tight fit at both ends then I’d be screwed. I’d probably piece something together like you did for the intake tube if I got an RCF TB.
    Saltyhero13[QUOTED] likes this.
  24. Aug 25, 2023 at 6:35 PM
    #234
    Saltyhero13
    I was looking at reducers on the intake hoses site to see what was available. Hopefully the shop figures out how to fit the hose.
  25. Aug 25, 2023 at 7:19 PM
    #235
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    To concur with Silver, they need non-sissy hands to get the coupler on the Maggie. I was inventing some cuss words wrestling that thing on. Finally got it with no heat or lube though.
    Next filter change, I might try to take it off the truck and heat and stretch it around something larger.
  26. Aug 25, 2023 at 7:35 PM
    #236
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Maybe being 118 helped when I did the SCOL boot on the RC-F TB but it was not that hard.
  27. Aug 25, 2023 at 8:00 PM
    #237
    19PlatinumCrew
    Dave
    Like I said before this does not give any new customer confidence when you can't or won't figure something as simple as a air box. Funny I haven't gotten a response after I sent the picture that Silver17 shows., he keeps telling me about the pro speed box for 650.00 and I still don't have a shipping update on the box from SCOL...time will tell....on a positive note I did get the oil changed, tires rotated,trans drained and refilled ,cat plates removed.
  28. Aug 25, 2023 at 9:01 PM
    #238
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Fwiw, I ordered a SCOL/Magnuson lid last Friday, Brian was hoping to have a shipping date next week. My Harrop did ship and it's due next week.
  29. Aug 26, 2023 at 5:05 AM
    #239
    19PlatinumCrew
    Dave
    Congratulations on the Supercharger, I was also told they had to order the top for the larger intake, good luck with your installation.
  30. Aug 26, 2023 at 5:45 AM
    #240
    Silver17
    Eastern PA
    I wonder if it’s possible for you guys to get this Harrop discount applied to your previous purchase. When I bought mine I got it $500 off as well.
    reywcms likes this.
