ALL Gen 3 Tundras recalled - fuel leak risk
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Aug 11, 2023.
  1. Aug 22, 2023 at 11:56 AM
    #211
    Rex
    Rex New Member
    2023 SR5 CrewMax 4x4 TSS
    Called the dealer and was told if you don't have a leak or smell fuel, keep on truckin, parts will be available in October or November.
    troutback and 22whatwedo like this.
  2. Aug 22, 2023 at 12:33 PM
    #212
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    pretty well explained in PDF in post 216:
    The NHTSA Toyota notice of defect (https://static.nhtsa.gov/odi/rcl/2023/RMISC-23V566-8490.pdf) had a lot of good history on the problem. So, 14 TSRs and 27 warranty claims that may be related to the fuel line/brake line interference issue.
    No need for further internet engineering -
  3. Aug 22, 2023 at 12:48 PM
    #213
    10 Bears
    10 Bears New Member
    11 CREW 5.7
    None at the moment
    Doesn't have to be true.
    Just believable by those involved. i.e the virus....
    Tundrastruck91 likes this.
  4. Aug 22, 2023 at 1:01 PM
    #214
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    The posts with the pics on the previous page tell you where it is. Looking at the rear passenger wheel well from the side, going straight towards the center of the truck. Just on top of the frame. One of Tony's later posts shows exactly where to approach this. You can't get in there with a cell phone unless you pull the wheel. Maybe not even then. My photos were with a borescope camera with the wheel still on.
  5. Aug 22, 2023 at 1:15 PM
    #215
    raylo
    Frederick, MD
    Matt,
    Here are some more views for the vicinity of the location:
    Spickett78 and Mattedfred like this.
  6. Aug 22, 2023 at 1:59 PM
    #216
    tony22longBed
    tony22longBed New Member
    tony
    2022 lunar rock long Bed
    glad you found it...i had to use my phone and stuck in there to see...hopefully this vid will help others:
    https://clipchamp.com/watch/zLNJKgEo7R7
  7. Aug 22, 2023 at 2:12 PM
    #217
    raylo
    Frederick, MD
    Good video. But damn, how do you get back in there?? My big mitts won't fit.
  8. Aug 22, 2023 at 2:14 PM
    #218
    tony22longBed
    tony
    i had to lay on my back on the ground, head towards the hood, then stuck the phone thru it. :)...credits to you raylo!
    raylo[QUOTED] likes this.
  9. Aug 22, 2023 at 2:18 PM
    #219
    raylo
    Frederick, MD
    I believe that would be the temp fix. Permanent fix seems to be a new plastic line that avoids that interference.
    tony22longBed likes this.
  10. Aug 22, 2023 at 2:20 PM
    #220
    raylo
    Frederick, MD
    I actually made a nice little 3D printed clip that would snap onto the metal line and then separate the two lines. But I don't think I can get in there to snap it on. :-(. Maybe I'll try one of these days but I am not as spry as I used to be.
  11. Aug 22, 2023 at 3:05 PM
    #221
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I suspect they need to replace the plastic tube on all trucks unless they can definitively determine that it never rubbed against the brake line. But in most cases it will have touched at some point, and in the interest of safety they can't have the repair tech reliably access how damaged, or not, the plastic tube is. So replacing it is the only sure way to remediate a potential problem. Besides, replacing it on every truck is probably cheaper than even one lawsuit from a death.
    Yea I know others have stated that they would just open the door and run away if the truck is burning up. And that might work in many or most cases of a fire. But....that's not a truly safe way of looking at it as one can't be sure when the truck will go nuclear IF even a small fire were to start. The leak is just above that thing they call a gas tank :(
    NewImprovedRon likes this.
  12. Aug 22, 2023 at 3:08 PM
    #222
    raylo
    Frederick, MD
    But this area is far from hot sports and ignition sources. So unlikely to light off before you smell it. IMO. Well, not just IMO. That is in the text of the NHTSA filing.
  13. Aug 22, 2023 at 4:19 PM
    #223
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I don't know if you know this or not but almost all Japanese vehicles have the fuel door on the right hand side due to right hand drive but the Tundra was specifically made for America so they have a left hand side fuel door but I could see if the japan design studio designed the 3rd gen tundra then they would have placed it on the right side
  14. Aug 22, 2023 at 4:41 PM
    #224
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
  15. Aug 22, 2023 at 5:42 PM
    #225
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    At the dealer today for oil change, they had 5 Tundras for sale and told me there wasn’t a fix yet and it was nothing to worry about. Business as usual
    troutback likes this.
  16. Aug 22, 2023 at 5:46 PM
    #226
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    interesting there’s an empty hose clamp right there near the intersection. (Green arrow)
  17. Aug 22, 2023 at 6:12 PM
    #227
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Makes you think the issue is quality control and someone got lazy?
  18. Aug 22, 2023 at 6:15 PM
    #228
    303Gen3
    Golden Colorado
    they will say anything to get your signature then plead ignorance on the Mothership "stop sale" requirement.
    22whatwedo[QUOTED] likes this.
  19. Aug 22, 2023 at 6:45 PM
    #229
    jctmundra
    Northern VT
    From pdf in post 216:
    "Toyota visited the fuel tube supplier to understand the investigation results from other recovered fuel tubes, as well as to audit the current fuel tube manufacturing process. During this audit, new and recovered fuel tubes were inspected on a check fixture, and it was found that the shape of the fuel tubes was out of specification."
    troutback, 303Gen3[QUOTED] and SC4333 like this.
  20. Aug 23, 2023 at 2:58 PM
    #230
    e263rd
    e263rd New Member
    So I have a June build and the app shows no active recalls??? Am I just waiting for a letter????
  21. Aug 23, 2023 at 6:31 PM
    #231
    303Gen3
    Golden Colorado
    You maybe screwed. Or not. Might get one FOB or two. Might get re-enginered fuel line or not. Might not get possession until Stop Sale is ended for sure. When you get it just drive it! FYI - The fix for those of us in this mess is not stated to roll out until October.
  22. Aug 23, 2023 at 7:21 PM
    #232
    PNW Tundra Mike
    Back in So Cal
    Love to see and compare what your June trucks look like in the same spot.
  23. Aug 23, 2023 at 8:03 PM
    #233
    Tryanothername
    Tryanothername New Member
    23 Tundra Pro
    Hard to say for certain. The dealer packet on the NHTSA recall page (https://static.nhtsa.gov/odi/rcl/2023/RCMN-23V566-3880.pdf) has non-hybrid trucks affected all the way up through "late" july 2023. Hybrid builds through early June 2023. The notice also makes it pretty clear the dealer will easily be able to see if the VIN on the new truck is affected by the recall through their vehicle inventory summary, so I'd imagine they'd be the best place to get confirmation. I'm not an expert, though. Just a bored guy who's been waiting for an allocation for two years, only to have the truck pulled from final sale the day after it hit the lot. The extra 6 weeks until the published temp fix won't kill me, but it definitely stings enough that I'm trying to get any idea at all as to when the service manager will have enough information from Toyota to make the fix and resolve the stop sale.
    Mattedfred likes this.
  24. Aug 24, 2023 at 4:42 AM
    #234
    raylo
    Frederick, MD
    What would be interesting is for one of you guys with no recall get a photo of this area. I'd like to see what is different.
    Edit: I just saw that Mike asked this same question a few posts above. So, I'll say, ditto.
  25. Aug 24, 2023 at 5:48 AM
    #235
    raylo
    Frederick, MD
    Looks interesting, especially if they meant length when they said that the fuel tubes' "shape" was out of specification. A longer tube attaching at that clamp would solve the problem. Hard to tell if the clamp is the correct size for the thin tube, but maybe it would get a bushing or somesuch.
  26. Aug 24, 2023 at 5:51 AM
    #236
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    this is a great example of why not to buy new year models when they first come out ROFL!
  27. Aug 24, 2023 at 7:43 AM
    #237
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    How did we get a dozen pages deep before this question was asked?!?
    Mattedfred[QUOTED] and Paul Moll like this.
  28. Aug 24, 2023 at 11:19 AM
    #238
    PNW Tundra Mike
    Back in So Cal
    I’ll have it repaired when my 2nd fob comes next year. Fuel Sensor - They must have made a change. I’ve parked in my inclined driveway facing up and down for a month now and not getting any weird readings or late readings after filling up. Miles To Go reading seems to work too although the number at Full has been climbing as my mpg goes up (as expected) Last fill said a little over 500 to go.
    Black widow TRD likes this.
  29. Aug 24, 2023 at 11:31 AM
    #239
    raylo
    Frederick, MD
    "When" your fob comes... the eternal optimist! I am more in the IF it ever comes camp.
  30. Aug 24, 2023 at 9:25 PM
    #240
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    I'd be willing to bet that's a solid no. From what was shared by Ryan the fix is to add an additional sending unit. Adding a sending unit will almost certainly require a new tank design. The issue at play is a long tank, and only one sending unit, at one end of the tank.
