Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Aug 11, 2023 at 2:54 PM
    #1381
    daveeasa
    OK, so upgrade to the toy rig and the big net gain here is, what specifically? Shorter wheelbase?
  2. Aug 11, 2023 at 2:58 PM
    #1382
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Shorter wheelbase, Atlas transfer case, tucked up gas tank, boxed frame, etc. Basically, it’s my second chance to build everything the right way.
  3. Aug 11, 2023 at 3:34 PM
    #1383
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I thought I had reached peak jealousy when you ordered bead locks, but I was super wrong, I have NOW reached peak jealousy! If my DCab wasn’t my daily I would be following right along with you. DCSB is really the perfect truck.
    Edit: I’ll follow along in spirit
  4. Aug 11, 2023 at 3:56 PM
    #1384
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I have a 2020 but I’m excited to see how an atlas does in a 2014 plus truck. Wonder if I can make one work in a 2020
    SAGE63 likes this.
  5. Aug 11, 2023 at 4:20 PM
    #1385
    Cruzer
    Cruz
    Sunnyvale, CA
    Should be feasible. I've got my Atlas 4 speed TC sitting in storage right now. It has a 3.8:1 gear ratio with a 2.72:1 doubler, which means I'll be crawling in 1st gear at 182:1 :D
    :benchpress:
  6. Aug 11, 2023 at 4:21 PM
    #1386
    SAGE63
    San Diego County
    it will be so badass
  7. Aug 12, 2023 at 1:57 PM
    #1387
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Same for me. 10 different sets at least and I've never had an issue.
    snivilous[QUOTED] and ATV25 like this.
  8. Aug 13, 2023 at 11:42 AM
    #1388
    breynolds
    breynolds New Member
    Future Tundra owner
    There used to be a lot of confusion regarding legality of bead locks. Companies have to say "off road use only" so they cover their own asses and not DOT approved doesn't necessarily mean they are illegal to use on road. Lots of car parts are not DOT approved but you'll never see someone getting a ticket for using them on surface streets.
  9. Aug 13, 2023 at 11:44 AM
    #1389
    breynolds
    Future Tundra owner
    I'm also amazed at how much more expensive TR beadlocks are now. When I bought a set for my old truck they were $400 each :eek:
    snivilous likes this.
  10. Aug 17, 2023 at 2:20 PM
    #1390
    Cruzer
    Cruz
    Sunnyvale, CA
    So this kinda worked except I didn’t have a big enough lawn and driveway to go all the way. When I aired it back up I heard the bead pop back out. I need to find a big grassy field.
    2mchfun, Tripleconpanna and 831Tun like this.
  11. Aug 17, 2023 at 6:00 PM
    #1391
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What?? You didn't buy the Bead Buster tool you posted?:D
    Cruzer[QUOTED][OP] likes this.
  12. Aug 17, 2023 at 10:11 PM
    #1392
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Don't know if it will work with your bead grip wheels but this was my method to pop the beads off my wheels
    FYI you can put a 3/8 square drive in the hook and spin the bottle jack with a drill :cool:
    2mchfun likes this.
  13. Aug 18, 2023 at 5:58 AM
    #1393
    breynolds
    Future Tundra owner
    Hi lift jack under a bumper works well too
    2mchfun and ATV25 like this.
  14. Aug 18, 2023 at 6:54 AM
    #1394
    Cruzer
    Cruz
    Sunnyvale, CA
    I tried similar tactics and it just ended up lifting the truck :rofl:
    CaptRussia253, 831Tun and NoMoreGreen like this.
  15. Aug 18, 2023 at 9:30 AM
    #1395
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Same here. I only have so much patience and the Hi lift/ bumper method quickly drained the patience reservoir.
  16. Aug 19, 2023 at 3:00 AM
    #1396
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I like your truck! :thumbsup:
  17. Aug 19, 2023 at 3:02 AM
    #1397
    2014 Black tundra
    2014 tundra sr5
    I see you’re a Raiders fan. :thumbsup: Me too. They started out good in pre season. :yes:
  18. Aug 19, 2023 at 8:02 AM
    #1398
    Cruzer
    Cruz
    Sunnyvale, CA
    I hate flying. At SFO waiting to go to Portland to get my new Toy. This helps :D
  19. Aug 19, 2023 at 1:28 PM
    #1399
    Cruzer
    Cruz
    Sunnyvale, CA
    How much are Rock Warrior wheels worth? These are nearly flawless.
  20. Aug 19, 2023 at 2:42 PM
    #1400
    APalmTree
    Brandon
    SW Washington
    Depends on how long you want to wait... I've seen absolutely beat sets go for sub 300 and basically flawless sets all the way up to 1500 with no rubber. They don't make them anymore so if the right buyer is looking for them you can pretty much name your price. I bought mine for 1000 with 3/4 good tires because the guy just wanted them gone and they are pretty close to flawless aside from the center caps
  21. Aug 19, 2023 at 3:50 PM
    #1401
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If you are still in the area, I'll give you $200 for them... Although you can definitely do much better as others have mentioned :thumbsup:
  22. Aug 19, 2023 at 4:44 PM
    #1402
    Cruzer
    Cruz
    Sunnyvale, CA
    Bro!
  23. Aug 19, 2023 at 5:44 PM
    #1403
    Tripleconpanna
    :laugh:
  24. Aug 19, 2023 at 5:52 PM
    #1404
    2mchfun
    Congrats on the DC! Can't wait to see the transformation! Take your time and work safely!
    Cruzer[OP] and Tripleconpanna like this.
  25. Aug 19, 2023 at 7:26 PM
    #1405
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Just another thought. When you go to sell them might want to consider selling them over on expedition portal or ih8mud. I see a lot of 200 series owners putting them on and those guys tend to have deep pockets and will pay $$$ for a quality set.
  26. Aug 19, 2023 at 9:55 PM
    #1406
    Cruzer
    Cruz
    Sunnyvale, CA
    Mmmmmmmm sounds yummy
    FrenchToasty and SAGE63 like this.
  27. Aug 20, 2023 at 3:52 PM
    #1407
    Cruzer
    Cruz
    Sunnyvale, CA
    They meet for the first time
  28. Aug 20, 2023 at 4:01 PM
    #1408
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Did driving the DC feel like you were in a lowered Miata compared to the CM?
    2mchfun and Cruzer[QUOTED][OP] like this.
  29. Aug 20, 2023 at 4:26 PM
    #1409
    Cruzer
    Cruz
    Sunnyvale, CA
    Everything is a Miata :rofl:
  30. Aug 20, 2023 at 5:07 PM
    #1410
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Lol fair point. But I’m amped to see the build kick off! What’s first?
    SAGE63 likes this.
