Adding tailgate assist
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Jul 23, 2020.
  1. Aug 19, 2023 at 9:46 AM
    daveeasa
    My ‘05 Tacoma had fresh paint and was in very nice cosmetic condition. Probably as good as your FGT, possibly better. AZ it’s whole life and fully stock w no mods, only found one small dimple inside the driver door jamb. I was a little sad to cut but f it, I got over myself. Thin non-structural sheet metal is not gold. I dremeled the edges smooth and painted them.
    Using OEM parts is the key. Toyota reliability and replacement option. I only wish my 2nd Gen tailgate were heavier so it would actually open without having to pull. I probably just need a softer dampener somehow, but I think there is only one part for that.
    Not sure what you are asking about with the license plate bracket.
    shifty` likes this.
  2. Aug 19, 2023 at 9:49 AM
    daveeasa
    Mine looks like this. Didn’t cut and replace the trim plastic nor paint the dampener black. I’d prefer to cover w steel bumper.
    And, if I pull while opening the handle it drops, just if I open directly up and don’t pull back it stalls. Though even that seems to drop now, after a few seconds. Perhaps because it’s on a slope.
  3. Aug 19, 2023 at 9:59 AM
    2nd video you posted. Go to 1m20s mark. Note the license plate frame is folded up.
  4. Aug 19, 2023 at 12:15 PM
    daveeasa
    Thanks for explaining. It looks like he did a custom hitch and custom 7 pin behind a flip up plate holder. I can take some photos of my stock bumper if you want but I don't think any of that is standard. More like a budget friendly semi-high-clearance rear bumper.
    The steel ones with integrated hitch would have a 7 pin cutout on the side. I'm guessing the OEM setup has the 7 pin below, next to the receiver.
    shifty`[QUOTED] likes this.
  5. Oct 2, 2023 at 4:52 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
  6. Oct 2, 2023 at 8:03 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    This works for helping you lift the tailgate. Doesn't really do much to slow it down while dropping. I have it on my DC. It does make the tailgate feel lightweight when lifting it though.
    dirtnsmores[QUOTED] likes this.
  7. Oct 3, 2023 at 9:52 AM
    dirtnsmores
    Southern CA
    Does it slow down the tailgate at all coming down? Or not really? Gonna look for a video
  8. Oct 6, 2023 at 11:23 AM
    dirtnsmores
    Southern CA
    Got the EasyLift installed on my Tundra. Boy what a difference! Tailgate is now lighter than my 2nd gen Tacoma. Install went smooth... one hole on the bed and one on the tailgate. 5/16 lower on the bedside as recommended by you guys. Thanks for the recommendation fellas!
    Weagle likes this.
  9. Oct 6, 2023 at 11:24 AM
    dirtnsmores
    Southern CA
    you're right... doesn't do anything to slow it down... but it's much easier to guide it down and "catch" it now before it slams. This is all I needed.
    artsr2002[QUOTED] likes this.
  10. Oct 6, 2023 at 12:25 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Received mine today and about to install.
  11. Oct 6, 2023 at 4:24 PM
    Weagle
    Prattville, AL
    Just finished. Works as advertised.
    It is so close to not needing the tailgate assist that I doubt I will add it.
    At least if the tailgate slips with this product it does not crash with the full weight of the tailgate as it would have before.
    dirtnsmores likes this.
  12. Oct 6, 2023 at 4:29 PM
    dirtnsmores
    Southern CA
    Nice congrats. That's exactly my thoughts as well!
    Weagle[QUOTED] likes this.
  13. Oct 7, 2023 at 9:38 AM
    Weagle
    Prattville, AL
    Yesterday I had a lot of Reservations about this product. I hated with a passion drilling into my new tailgate but I felt like it was worth it. Even though it worked as advertised I still had my doubts last night
    but this morning when I went to get some tools out of my truck bed, I can say this - it is absolutely worth it. Didn’t even realize how heavy that tailgate is but it is so much more convenient now.
  14. Oct 7, 2023 at 9:44 AM
    dirtnsmores
    Southern CA
    Haha same! I almost slammed it up hard when I left this morning forgetting about the lack of weight. I have kids that use the tailgate often and it was way too heavy for them before. Now it's a breeze lifting it up. I'm still cautious with them about bringing it down
