  1. Aug 18, 2023 at 11:08 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    PXL_20230819_000919749.jpg PXL_20230818_220806628.jpg Still have a more aggressive bed trim to do but got the new SS Built rear bumper installed. Just in time, we leave for home in OR Sunday.
  2. Aug 19, 2023 at 9:34 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    Please talk me out of replacing my water pump.
    I pulled the radiator. Here's the leaky old vs the new.
    I preventatively replaced the thermostat, which looked brand new.
    Now people say, "While you're in there, do the water pump." But now I'm tired and it looks like it's still a pretty big job since I need to remove the fan and like 15 hoses. Truck has 90k miles and I assume it's never been changed (I'm not the original owner). No sign of leaks.
    If I leave the pump, am I going to regret it?
  3. Aug 19, 2023 at 10:07 AM
    French Avocado
    Utah / Wyo
    Only when it fails!
    coTony, Tripleconpanna and MTRock like this.
  4. Aug 19, 2023 at 10:52 AM
    VWTim
    Corvallis, OR
    Agreed. If it doesn't show signs of weeping or makes noise, leave it alone!
  5. Aug 19, 2023 at 1:30 PM
    zeekevin
    zeekevin New Member
    with the radiator out, you might as well do it with the extra room you have.
    omgboost likes this.
  6. Aug 19, 2023 at 1:35 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I mean sound good my Miles are mostly highway so sounds right
  7. Aug 19, 2023 at 4:19 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Got the steelies rattle canned satin black…it’ll do! Tires are 295/70/18 IMG_7308.jpgIMG_7314.jpgIMG_7313.jpg
    07 Tundie, Ohannon7, D4x4TRD and 11 others like this.
  8. Aug 19, 2023 at 4:25 PM
    PhotoNerd
    Tony
    Waterford, CT
    I put away my laziness and pulled out the water pump. What a PITA to access! It WAS leaking; the gasket was dry and cracked. New/old:
    I broke the thermostat housing by trying to remove it with a hidden bolt still present. So I'm outta commission for a few days until that part arrives.
    I ordered a Haynes manual hoping it does a better job than randos on YouTube of illustrating all the bolts and hoses.
  9. Aug 19, 2023 at 4:32 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I had black steelies on my Taco. I loved the steelies. They are simple and look good.
  10. Aug 19, 2023 at 4:40 PM
    Shanet421
    San Diego,CA
    And easy touch ups!
    Bonus I already have the matching spare underneath!!!
    07 Tundie likes this.
  11. Aug 19, 2023 at 4:54 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    It's a good thing you found the pump problem now, they're no fun when they go out away from home. The last one that went out on me (non-Tundra) did it on the highway and it took the radiator with it. The pump seized and spun the fan off the shaft into the radiator. As for the thermostat housing......
  12. Aug 19, 2023 at 5:40 PM
    Red Sonja
    Red Sonja Mock Warrior
    Ben
    2007 Salsa Tundra LTD
    Bilstein 5100’s at top setting Eibach rears with Toytec 1.5” lift shackles 285/60 R20 Firestone Destination X/T 1.25” Spidertrax Spacers Custom 18” Magnaflow Exhaust(side middle exit) Vland LED headlights
    Swapped 35x11.50r20 Ridge Grapplers for 275/65r20 BFG’s. Got to shed 14 lbs at each corner. She’s feeling lively again.
  13. Aug 19, 2023 at 6:21 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Agreed do pump now.
    PhotoNerd likes this.
  14. Aug 19, 2023 at 6:52 PM
    homeyclaus
    homeyclaus New Member
    2013 Spruce Mica CM TRD
    Leer 100XL cap, Icon front susp and rear shocks, OME springs, WKOR sliders, RCI skids, Exp1 bumper
    Rear brake job: New pads, new shoes, new rotors, and new brake hoses, including extended length ones for the axle. Flush brake system rear lines. Was going to do the fronts, but since the pads are still at 40% I'll wait. But also replaced hoses, and flushed. Pedal is solid, much nicer.
    07 Tundie, Skew12, PhotoNerd and 2 others like this.
  15. Aug 21, 2023 at 9:00 AM
    YouFallWeHaul
    YouFallWeHaul New Member
    2010 Marine Blue DC 4x4
    I've seen the paint on the bed rails get progressively more chipped and worn down by the plastic caps. Was starting to rust pretty good in a few spots, and I didn't think painting would help much as it would just wear off again. Line-X didn't want to touch the rails, as they said the material would be too thick to place the caps back on. I sanded and Raptor-lined the rails, two thinner coats, and it came out great for a first attempt. I did a thicker stripe on the tailgate where its subject to a lot of bumps and bruises, and I kind of wish I had extended the liner material down further on the outside of the rails too.
  16. Aug 21, 2023 at 9:27 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    JB WELD is you're friend!
    PhotoNerd[QUOTED] likes this.
  17. Aug 21, 2023 at 1:15 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Last week I had 3 different lungs nuts break the studs off when I tried to rotate my tires. They broke off at the base of the stud and after talking it over with a few friends and a trusted mechanic, I've concluded that the mag chloride CDOT uses on its roads all winter and spring could actually be my culprit. The corrosion was built up inside other lugs and on other studs as well. So I went to Amazon and ordered up a new set of lugs. This A.M. I cleaned all the studs and installed new lugs.
    Before-you can see rust on my old lugs
    After-color matched to boot.
    The old lugs with the chrome coating coming off and rusting.
  18. Aug 21, 2023 at 3:14 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Damn! Hopefully that's the worst of it!
    When I moved to East California (CO) a few years ago, a neighbor asked me why I was undercoating my Tundra and Land Cruiser (I spray the underguts of my vehicles with CRC Heavy Duty Corrosion Inhibitor at the end of the summer). I tried to explain to them that mag chloride is more corrosive than salt. They told me that "the stuff they put on the roads here is much safer." Bull sh*t! This excerpt is directly from a CDOT report:
    "While CDOT specifications state that magnesium chloride must be 70% less corrosive than sodium chloride, experimental results obtained by SAE J2334 indicated that MgCl2 is more corrosive than NaCl to the bare metals tested. Corrosion varied from only slight differences for some metals to 13 time more corrosion for SS41O."
    joseph_womack and Wynnded like this.
  19. Aug 21, 2023 at 5:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's also electrically conductive. CDOT was putting it on so heavy that the spray from passing vehicles was alighting on the insulators of an adjacent power substation and shorted out the entire place.
    AIL4fc9HoRKmsJGcE_5E_x6qgJVVXFRuzZpQ8w-k_1fd44430a42aa8a49b29144b8957ecbae49355ab.png
  20. Aug 21, 2023 at 5:07 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    In the winters I make a good habit of rolling through the spray wash bay's and trying to get all that crud off under all my family vehicles with a high pressure washer. I've heard horror stories of it deteriorating brake lines and other non metals as well.
  21. Aug 21, 2023 at 5:10 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    The funny part is even with the "best" management of snow and ice, it doesn't keep the denverites from shutting down I-70 every storm due to multiple accidents trying to get to the mountains. Slow down when the roads suck folks. It's a simple concept no matter how lifted your mall crawler is, or how sporty your AWD crv and rav4 are.
    I'll get off the soap box now and leave my rant alone. Sorry to derail the topic of fun stuff we like to tinker on. Let's continue to mod away...
    PolishedTRD and French Avocado like this.
  22. Aug 21, 2023 at 5:48 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Spent way to much on this
  23. Aug 22, 2023 at 5:23 AM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Sharp red color love it!
    Red Sonja[QUOTED] likes this.
  24. Aug 22, 2023 at 8:15 AM
    rphass17
    rphass17 New Member
    What brand did you end up going with?
  25. Aug 22, 2023 at 9:28 AM
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats NFab Light Bar w/ KC Lights 2010 Limited Grill mod topper bedrug Amazon tailgate handle with rear backup camera still working on mods
    Where does one get a set of steelies? I would much rather run 17-18" steelies than these 20" monsters I have now (at least make a few bucks in the process to put towards other mods)
  26. Aug 22, 2023 at 10:43 AM
    Shanet421
    San Diego,CA
  27. Aug 24, 2023 at 10:49 AM
    VWTim
    Corvallis, OR
    This will be for down the road, but scored a Sequoia transfer case for $50 yesterday.
    VictorG and others have posted excellent threads on converting the Tundra to use this center diff equipped transfer case to have AWD and locked 4WD available. With my HP goals and PNW weather, I'm looking forward to this.
  28. Aug 24, 2023 at 10:52 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Geez that looks heavy AF!
  29. Aug 24, 2023 at 11:32 AM
    VWTim
    Corvallis, OR
    I'll see when I get it separated from the core trans they gave me. At the drive line flange, it's only 1-1/2" longer than stock.
  30. Aug 24, 2023 at 11:43 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Just bought AJT designs 4x4 and climate control knobs.
