Fumoto Valve
Discussion in '2.5 Gen Tundras (2014-2021)' started by therealjonwick, Aug 18, 2023.
  1. Aug 18, 2023 at 1:22 PM
    AZBoatHauler
    So.Arizona
    As far as I know, @Cruzer is the only Tundra that’s been on the Rubicon. If others have done it, they need to speak up!
    GODZILLA, ATV25, bulldog93 and 2 others like this.
  2. Aug 18, 2023 at 2:01 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I did the Rubicon with IFS and I have the Fumoto valve, which was the least of my worries :rofl:
    GODZILLA, ATV25, bulldog93 and 4 others like this.
  3. Aug 18, 2023 at 2:24 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    There have been others but I believe I’m the only one to complete it in IFS, while avoiding bypasses except for Old Sluice
    GODZILLA, ATV25 and reywcms like this.
  4. Aug 18, 2023 at 3:35 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Sweet! I’m an east coast guy. Would have loved to get on the Rubicon, but my wheeling days are pretty much over.
    GODZILLA likes this.
  5. Aug 18, 2023 at 4:23 PM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    I have one on my 19 Tundra and my wife’s 21 Highlander and love them.
  6. Aug 18, 2023 at 5:19 PM
    AZBoatHauler
    So.Arizona
    Wait wait wait - you brag about wheeling and then tell us you’re an east coaster? :boink:
    GODZILLA, Jaypown, ATV25 and 3 others like this.
  7. Aug 19, 2023 at 8:43 AM
    Blue Thunder
    Washington
    I’ve run Fumotos in every vehicle for 20+ years and love them. They are the first thing I purchase after getting a new ride. Never had or have ever heard of one failing on many forums.
    I like nipples… but I like to put on a rubber (hose) and route the hot goo err oil to the drain pan.
    If I was going full @reywcms I would not use the nipple version for added clearance, but as you can see what I have is still tucked up away. IMG_4085.jpg
    Doesn’t protrude below the skid
  8. Aug 19, 2023 at 9:10 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Curious if anyone with a fumoto has drained the pan and then remove the fumoto. Im curious how much oil is left behind.
  9. Aug 19, 2023 at 9:14 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Once, not on the Tundra but on a motorcycle after an incident with a trailer, heh. Not the valves fault.
    Maybe three or four more oil drops came out.
    bulldog93 likes this.
  10. Aug 19, 2023 at 10:00 AM
    therealjonwick
    therealjonwick [OP] New Member
    JR
    2019 OR
    Was wondering this as well.
  11. Aug 19, 2023 at 10:09 AM
    AggiePhil
    College Station, TX
  12. Aug 19, 2023 at 11:08 AM
    therealjonwick
    JR
    2019 OR
    Seems like both work well. Thanks for that.
    AggiePhil[QUOTED] likes this.
  13. Aug 19, 2023 at 11:26 AM
    farnsrocket
    farnsrocket New Member
    Just ordered, thanks!
    When you 1st get on to their site, a 20% coupon code window pops up......saved $9 and shipping was only $4.50. :cheers:
  14. Aug 20, 2023 at 11:13 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Fumoto or no fumoto…. Drain your oil, put in a new filter. With the pan still able to drain, pour 1 quart or new oil in and watch what comes out. Put in a second quart and see what comes out.
    How anal does one want to get?
  15. Aug 20, 2023 at 11:33 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I love mine. Did an oil change Friday while I swapped the rear bumper. Between that and the *xxx somethingorother* filter house drain valve that screws in, I use 2 gallon milk jugs to drain into and got like 4 drops in the shop floor.
    RCI skids stay on and I just pull the filter trap door.
    bulldog93 and farnsrocket like this.
  16. Aug 20, 2023 at 4:02 PM
    Joe333x
    Joe333x Member
    Boston
    I dont understand the point of you post. I was inquiring how much oil is left in the bottom of the pan when a fumoto is used since all the crud stays at the bottom of the pan and the valves threads I would assume go in farther than the pans. If you poured fresh oil in with the valve still open, the oil on the bottom of the pan is still going to be there, thats why I was curious if anyone remove the valve after draining to see what comes out.
  17. Aug 20, 2023 at 4:46 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yes they do!!!! :) I've been running Fumotos on my Toyotas for 15 years. 6 different vehicles (4 right now) and not one ever ever ever issue.
  18. Aug 20, 2023 at 4:53 PM
    2mchfun
    Got an idea for you. Buy a Fumoto and install it during an oil change. Then next oil change drain off about 6 quarts and grab a sample for analysis. Lastly, remove the Fumoto and drain the rest while grabbing a sample for analysis. Send in both samples to Blackstone and see what if anything is different.
  19. Aug 20, 2023 at 5:00 PM
    18" TRD Off Road Wheels
    Saw a video on a Taco, and there was a little bit left. In a 3.5 engine it worked out to something like 5% of the 6.2 quarts. With modern oils and 5,000 mile OCI I'm fine with that. With the slant the Tundra has on the plug it might be even less left behind.
    I just put the fumoto and jowett housing on my Taco, and I bet I could do my next oil change in a suit and tie. So good they should both be industry standard.
  20. Aug 20, 2023 at 5:06 PM
    #50
    Joe333x
    Joe333x Member
    Boston
    I don't really have a problem turning one bolt to drain the oil twice a year but if I did have one I would do it just for curiosity.
    2mchfun[QUOTED] likes this.
  21. Aug 20, 2023 at 5:19 PM
    #51
    2mchfun
    I'll try to remember that when I go to the valvomax.
    Joe333x[QUOTED] likes this.
  22. Aug 20, 2023 at 6:38 PM
    #52
    white_pro21
    white_pro21 New Member
    2021 super white TRD PRO
    I always wonder if there is any metal shaving would still stay at the bottom of oil pan with the valve on.
  23. Aug 20, 2023 at 6:59 PM
    #53
    You can always pop the valve out. 14mm deep socket on the long nipple model works.
  24. Aug 20, 2023 at 7:16 PM
    #54
    2mchfun
    Even with the factory plug, there is still the nut welded inside. At some point you gotta trust the filter to function as designed.
  25. Aug 20, 2023 at 7:18 PM
    #55
    pronstar
    pronstar New Member
    Robert
    Not a Tundra :-(
    2015 Silverado: 2.5” Kings front/rear. Icon Delta Joint UCA’s. Deavers. 17” Method 703 BeadGrips. 33” BFF KM3 2018 Suburban: 2.0” Fox front/rear. Dirt King UCA’s. Mall Cruiser.
    Your oil filter should catch anything large enough to be visible…but if you have visible metal in your oil then you likely have bigger problems to worry about, methinks
  26. Aug 20, 2023 at 7:18 PM
    #56
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Put a long metal tube over oil filter drain cock.
  27. Aug 20, 2023 at 7:23 PM
    #57
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I lost it in the very first deep snow. Have a piece of electric copper wire instead, much more durable and trusty ;)
  28. Aug 21, 2023 at 4:26 AM
    #58
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    I'd think if it were a metal shaving big enough to not fit through the (slightly) smaller diameter of the fumoto... Then you probably have bigger issues at hand
  29. Aug 21, 2023 at 5:31 AM
    #59
    SwitchThrottle
    2021 Barcelona CrewMax
    This.
    If you are really worried, you could throw a substantial neodymium magnet on your pan to try and lock in any ferrous metal, but then it will never leave the pan, so :notsure:
    bulldog93 and MedCityMoto like this.
  30. Aug 21, 2023 at 5:52 AM
    #60
    MedCityMoto
    This whole thing reminds me of those close-up videos showing how easy it is to fix a minor scratch on a car finish, and then zooms out to show a completely totaled crushed car. Hyperfixation on minor inconsequential details when there's glaring problems elsewhere that demand much more attention.
