  1. Aug 18, 2023 at 1:32 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Your challenge will be there are 4 screws instead of two like the regular console. However, the real challenge or road block actually, is that the Sequoia Info Center electronics is different. The connectors are the same but pins 4/5 inputs are different between the 2.
    Tundra uses 4/5 for Ambient Temp Sensor and Sequoia uses 4/5 to be able to display DTE, Average/Instantaneous fuel consumption, Cruise info....etc. That info comes from the Combination meter on Sequoia.
    JakeJake and shifty` like this.
  2. Aug 18, 2023 at 1:49 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I fuckin hate shopping for tires
    txagg likes this.
  3. Aug 18, 2023 at 1:51 PM
    I love it.
    I f-(king hate paying for tires.
  4. Aug 18, 2023 at 1:52 PM
    I just buy Michelins at Costco when I need them and they’ve a discount going. Haven’t seen a buy 3 get 1 free for a while though and last time I couldn’t even buy them due to the coronavirus shortage.
    txagg likes this.
  5. Aug 18, 2023 at 1:57 PM
    I need to buy a full set for our Highlander.
    Been looking at the MICHELIN CROSSCLIMATE2. I've had 'em in a TireRack cart twice now, but haven't pulled the trigger, probably looking at $1250 after everything. Gonna need to do that really soon. Just had to plug another hole we picked up on the way home from the local grocery store. No clue what got it, but it went in and pulled out and was losing 15-20psi/mile. Had to get out and air up a couple of times on the short trip home, with my finger covering the hole so it would hold the air I was putting in. Wouldn't you know it: Couldn't find a nail anywhere on the street to stick in the hole! Figures.
    Fortunately, it was at least an inch into the tread, so safe enough to patch for another few hundo miles.
  6. Aug 18, 2023 at 1:58 PM
    That's the first thing I checked; the vacuum hoses. This would be a massive leak, as I had drastically decreased braking as well. Shouldn't be the intake manifold; gasket is new.
    Plus, when I pulled the connector off the MAF it went into limp mode. So with that change I'm 90% sure it's the MAF itself.
  7. Aug 18, 2023 at 2:02 PM
    Everytime I get close to needing tires I start drooling over all of the wild AT and mud tire designs and I’m gonna upsize this time for sure and end up with near factory P rated low cost semi-ATs that are boring. Boooo me.
  8. Aug 18, 2023 at 2:06 PM
    Yeah, symptoms are pretty classic air metering/air intake fail. If you haven't replaced the MAF in the last 100k miles or more, I'd be pretty confident pulling that MF and replacing. Most LAPS carry the Hitachi MAFs.
    Advance Auto Parts is offering up 15% off for online order/store pickup right now, code RMN15, MAF may or may not apply.
    AutoZone is doing 20% off for ship-to-home, but you gotta order an absurd amount ($125) to be eligible.
    Yep, coupon works...
    bmf4069[QUOTED] and KNABORES like this.
  9. Aug 18, 2023 at 2:07 PM
    With as few miles as I drive per year I justify the extra expense that way. The KO2's on my truck have been installed over 4 years. I think I have 32,000 miles on them. They are starting to show their age but I've got some time. $1,200 every 4-5 years isn't bad.
    I'm also not going to stress over MPG since I don't drive that much. 285's just look better. I do go with load range C to save on weight.
  10. Aug 18, 2023 at 2:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Have you considered for troubleshooting purposes putting your Tundra MAF in the Sequoia ?
    McGeorge says their the same.
  11. Aug 18, 2023 at 2:15 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'm just going to keep blindly buying KO2s/ KO3s unless I move to Northern AZ, then I'll switch to KM3s.
    FirstGenVol likes this.
  12. Aug 18, 2023 at 2:37 PM
    Why the hell did I not think of that? Thanks for the idea Bubba! I'll do it when it's not hotter than the underside devils ballsack outside. Currently 105°.
    BubbaW[QUOTED] likes this.
  13. Aug 18, 2023 at 2:39 PM
    RA shows it for $80. I asked vatozone and they had one for $67. Probably off brand.
  14. Aug 18, 2023 at 2:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    That’s what I love about our “ballsack” vent chiller when sitting in drivers seat !
    bmf4069[QUOTED] likes this.
  15. Aug 18, 2023 at 2:45 PM
    SummitRacing has it for $57.99 but only 4 left: https://www.summitracing.com/parts/hta-maf0035
    Vatozone for Hitachi $101. 20% off if you do home delivery would get it close to RA before shipping.
  16. Aug 18, 2023 at 2:45 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
  17. Aug 18, 2023 at 2:47 PM
    DJenerated
    Dija
    The Lone Star State
    Both look weak AF to me :p
    Jack McCarthy, Sunnier and txagg like this.
  18. Aug 18, 2023 at 2:55 PM
    Oh damn, Pucks, is that you? :rofl:
  19. Aug 18, 2023 at 2:55 PM
    DJenerated
    Dija
    The Lone Star State
    No I just use real AT tires
    Cooper or General Grabber
  20. Aug 18, 2023 at 3:07 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Anybody ran Goodyear Duratrac's? I had a set of 33's on a truck. Was pretty impressed with them.
    DJenerated likes this.
  21. Aug 18, 2023 at 3:09 PM
    You have like 1 type of terrain out there. Come at me when you drive on something other than dust.
    :boink:
  22. Aug 18, 2023 at 3:10 PM
    I just need something that'll last. Current tires have ~25k miles on them and are already practically bald. Firestones I think. Although I think 1 tire is different from the rest, had to replace it with used, sidewall puncture.
    txagg[QUOTED] likes this.
  23. Aug 18, 2023 at 3:11 PM
    DJenerated
    Dija
    The Lone Star State
    Back on TW everybody seemed to rave about the Duratracs and the K bro 2's.
    I never used either and I've heard some bad things about the ko2's. I don't recall for sure but I think both have weak sidewalls.
    I love my cooper AT3XLT's.
  24. Aug 18, 2023 at 3:13 PM
    Can we team up and make a compound together in N. AZ? That's the only place I've found so far that I'd consider moving to. Those guys in Southern Arizona(aka the oven) are tougher than me.
    Tundra2 likes this.
  25. Aug 18, 2023 at 3:16 PM
    I’ve never had a set of Goodyears I like. Their rubber compounds always seem slippery and they wear fast. I’ve loved all of the Toyo and Yokohamas I’ve had. My Hankooks have been middle of the road. I would rate them better but my last set one developed a tread bubble. My dad runs exclusively coopers, has had great luck with them.
    txagg likes this.
  26. Aug 18, 2023 at 3:18 PM
    DJenerated
    Dija
    The Lone Star State
    My dyslexic ass read that is Flintstones :rofl:
    KNABORES and FirstGenVol like this.
  27. Aug 18, 2023 at 3:27 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I had the exact experience as you with goodyears previous to these. Only reason I bought them is discount made a deal I couldn't say no to. They were great in the rain. Only thing I can't verify is longevity bc I only had them about 20-25k miles before I sold the truck.
  28. Aug 18, 2023 at 3:43 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Where in Northern Arizona would yall prefer? I looked at Sedona the other day, and you might as well buy a place in Hawaii for that kind of money! I had no idea.
  29. Aug 18, 2023 at 4:32 PM
    Yabba dabba doooooo
    DJenerated[QUOTED] likes this.
  30. Aug 18, 2023 at 4:39 PM
    We have these. Supposedly 70k mile warranty. We're 25k in and are at about 40% tread remaining.
